‘06 Frame Rust - sale value
Discussion in '1st Gen Tundras (2000-2006)' started by Staircase, Jun 3, 2021.
  1. Jun 3, 2021 at 7:04 AM
    Staircase
    Staircase [OP] New Member
    I have an ‘06 ext cab with 89k, unfortunately frame rust has caused my shop to not want to work on it anymore. I am wanting to sell. I will be open and honest with next buyer about issues. As to be expected truck runs great and body and interior are in really good condition for its age.
    Any ideas on a starting price? Not sure how to discount for frame issue.
    Darkness likes this.
  2. Jun 3, 2021 at 7:10 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Need pics of rust to really gauge its worth.
    RustyShackle323 likes this.
  3. Jun 3, 2021 at 7:17 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
  4. Jun 3, 2021 at 7:23 AM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    How many miles on this truck?
    One approach is to start with a dealer quote for replacing the frame and deduct that from a reasonable selling prices for a truck with a new frame. Next is a DIY frame replacement that deducts the cost of the parts from a reasonable selling price. At the other end of the spectrum is the cost of DIY repairs to the frame to make it s useful farm truck or something. No matter how you slice it, if shops wont work on it, the selling price seems to be in the $3K - $5K range*, less if it's a 300K mile truck and the drivetrain isn't worth a lot for parts.
    * Don't quote me, I ain't no expert.
  5. Jun 3, 2021 at 7:26 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Definitely good that you're planning on disclosing the frame rust to any buyers.
    Pictures will help us better advise you on a price.
    speedtre likes this.
  6. Jun 3, 2021 at 7:32 AM
    Staircase
    Truck still at shop now, will work to post pictures later, but I can only see this one physical hole near driver side door. I guess under front skid plate there is more according to shop.
  7. Jun 3, 2021 at 7:38 AM
    If you've got holes there, then there are likely worse places. That's a shame, sorry to hear. It's a parts truck if the rest of the frame is also in that poor of shape. Someone wanting to do a frame swap may be interested, but have to find a frame. Plus, many other components will be unusable due to rust and have to be replaced as well.
  8. Jun 3, 2021 at 8:05 AM
    Looks like whomever put that coating on top didn’t bother to take the time to get rid of the scaling on the frame first. That’s only going to exacerbate the problem with rust corrosion.
  9. Jun 3, 2021 at 9:08 AM
    andnyleswillriot
    Breckenridge, CO
    Even done “properly”, undercoating should never be used.
  10. Jun 3, 2021 at 9:16 AM
    Depends upon what you use. I’ve got POR-15 on my frame and it’s been holding up for 10+ years. Unless POR-15 isn’t considered an undercoat.
  11. Jun 3, 2021 at 9:55 AM
    Richid
    Richid New Member
    POR-15 is hygroscopic. Undercoating is merely topical.
    Undercoating is made to protect clean surfaces, it will trap moisture and accelerate corrosion if there is any existing rust. A hygroscopic paint will absorb and encapsulate any moisture so it will bond to rust.
    They should have used POR-15 instead of undercoating on the frame.
    15whtrd likes this.
  12. Jun 3, 2021 at 11:19 AM
    Staircase
    Whatever coating was used, I assume it was done at dealer, as there is a service record from 9/2013 for frame recall campaign, included foam plug kit and corrosion resistance kit.
  13. Jun 3, 2021 at 11:45 AM
    Professional Hand Model
    Fred
    Hand Protectors
    That explains the non-factory perfect hole next to your rust.
    Jack McCarthy likes this.
  14. Jun 3, 2021 at 7:23 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    its got value to someone. IF i didnt just buy another rotted out tacoma, i'd be buying this thing and getting a frame under it.. shes too young to die.
    (unless you happen to be local lol)
    GODZILLA, Darkness, bmf4069 and 2 others like this.
  15. Jun 3, 2021 at 7:33 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Whatcha want for the camper?
  16. Jun 3, 2021 at 9:10 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Where are you located? I’ve seen some in pretty rusty Tacoma’s/tundras sell for decent money here in Colorado.
  17. Jun 4, 2021 at 6:39 AM
    Staircase
    I live in Denver.
  18. Jun 4, 2021 at 7:32 AM
    SouthPaw
    2000 Limited 4x4 AC
    If it were me, I’d start it at $6500. Someone out there will be interested in swapping the frame and/or driving it as it.
    There was a 2001 Tundra for sale that I almost picked up. 3.4L, supercharged, 4x4, manual t-case, 190k IIRC, rusty frame, needed some additional work and it sold for $5500.
  19. Jun 4, 2021 at 7:35 AM
    Staircase
    Thanks for info, appreciate it
  20. Jun 4, 2021 at 7:53 AM
    empty_lord
    05 rollover special
    $3000-5000 would likely be realistic assuming it’s getting frame swapped.
    New frame from Toyota is ~3000 once you factor in the other little things.
  21. Jun 4, 2021 at 11:23 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    As a reference, Knowing the frame needed a bunch of work, I paid 2000 for mine last January (pre-pandemic prices, yes) and, although I didn't replace the frame, I spent the entire summer repairing it. Probably spent 2500 just in frame related parts and supplies.
    I hope the best for you and this truck, it really is too young to be parted out.
    shifty` likes this.
  22. Jun 4, 2021 at 3:29 PM
    Richid
    Richid New Member
    Maybe keep an eye out for one with a decent frame and sell them as a pair. There are many more with rotten frames around here, but every now and then one pops up with a replacement frame but bad engine/transmission/too many other issues.
    They don't sell for much around here as most are rusty and there aren't many needed parts. I'm still shopping for a bed, but I don't need it so I don't want a whole truck or to spend $1200 to then have to paint and bedliner it.
    Plus - like you, I'd feel bad about parting out a great truck just because of the frame.
    Best of luck with whichever way you go.
  23. Jun 4, 2021 at 3:45 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    If you can find a NEW one...
  24. Jun 4, 2021 at 4:10 PM
    empty_lord
    05 rollover special
    Toyota will still probably make it.. I mean mine was brand new
  25. Jun 4, 2021 at 4:17 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    As far as my research has shown Toyota has discontinued the Access cab, and Regukar Cab frames for individual purchase.
    They are still making the Double Cab frames.
  26. Jun 4, 2021 at 5:22 PM
    empty_lord
    05 rollover special
    Recall frame numbers
    Tundra2[QUOTED] likes this.
  27. Jun 4, 2021 at 5:36 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I can't find those anywhere on the internets.
    The only way I can find those is if people who have had frames put under their trucks provide the part numbers from their service record.
    I was able to pull up another members here using those, but it took some convincing.
    4WD V8, 2003 frame part number: 040002660C
    https://parts.mcgeorgetoyota.com/oem-parts/toyota-frame-sub-assembly-040002660c
    NUDRAT likes this.
  28. Jun 4, 2021 at 5:38 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    We should probably start compiling a list of all frame numbers and put then in the frame sticky thread.
    We would be able to cross reference part numbers across years, and provide links to people who are curious.
    I can facilitate this, but my free time is lacking lately.
  29. Jun 4, 2021 at 6:23 PM
    empty_lord
    05 rollover special
    I need to see if we can still get on the site. There’s a special site to get frame recall numbers
    NUDRAT and Tundra2[QUOTED] like this.
  30. Jun 4, 2021 at 6:42 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    If no longer able to access... we as "civilians" can compile a list through group participation, and cooperation.
    We already have one frame number. Must be plenty based on configurations. Should be able to cross reference 2WD/4WD, year, etc...
