Supercharger problem
Discussion in 'Performance and Tuning' started by Ryman42, Jun 1, 2021.
  1. Jun 1, 2021 at 4:43 PM
    Ryman42
    Ryman42 [OP] New Member
    2010 platinum tundra
    6” lift 35” tires
    So I just had a shop put on my supercharger. He finally got it all back together and got the bully dog tuner hooked up. He said when he started it wasn’t happy and it sounded like it jumped a tooth on the timing. He said he wasn’t sure if it was manually turning over the motor or what happened. Has anyone had something like this happen after they put on a sc. my truck does have 215k but it ran perfectly before it went in and I never had any weird noises or anything. It just super sucks!
  2. Jun 2, 2021 at 3:01 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Potentially tough position man...keep us posted...sending good vibes your way!
  3. Jun 2, 2021 at 3:31 PM
    Ryman42
    6” lift 35” tires
    Thanks man. I need some good news to come my way. I thought I was getting it back Friday, it wasn’t done. Monday was a holiday, then Tuesday I find out that it doesn’t sound good when he started it. I’ve been waiting all day to hear from him and still nothing. I just don’t know how anything could happen to the timing. It didn’t even need to be touched. If he doesn’t get back to me today im going to have it towed to another shop.
    HulkSmurf14 likes this.
  4. Jun 2, 2021 at 3:31 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  5. Jun 2, 2021 at 3:44 PM
    Ryman42
    6” lift 35” tires
    I know right….lol
    I’ve already hit him up about the tune and getting the ecu flashed. I just hate to bug the guy. I’ve never heard of anyone have this kind of problem when the installed theirs. Plus I don’t know how manually cranking over the motor would make it jump a tooth and the timing. It doesn’t make since to me.
  6. Jun 2, 2021 at 4:33 PM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Hopefully the mechanic didnt romp around in it over the holiday weekend without the proper tune or drop a socket inside... worst case just sayin.
    Otherwise I dont see how timing is effected personally. Worst case a really bad vacuum leak upon initial start up or something not connected.
  7. Jun 2, 2021 at 4:50 PM
    Ryman42
    6” lift 35” tires
    I’m pretty sure he’s more professional then that.
    I did just get off the phone with the actual tech working on the truck. He said that it didn’t actually start up. He said after the first basically the motor locked and can’t turn it a 1/4” each direction. The guy said he he got the camshaft cover off and it wasn’t anything to do with the timing. So now he’s going to the bottom to see what’s going on there. I suggested the flywheel or transmission he said he wondering that as well. I’m really hoping they didn’t drop something by accident. He said they would of seen it by now if they did. He said it’s his number one priority in the shop to get it running and back to me. I’m kinda stressing, but that’s what beer is for.
  8. Jun 2, 2021 at 4:57 PM
    TX210Tundra
    Positives vibes going your way :cheers:
  9. Jun 2, 2021 at 5:36 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Sounds like something was dropped in the intake. Besides removing the stock intake manifold, you don't go into the engine in any way, so there's nothing that mechanically moves and also directly interfaces the engine. Even if the blower was totally seized up, the engine would still be able to turn over. I would think it would still spin backwards if something was dropped into a cylinder unless something got super fucked or something further down the line broke as the piston tried to go to top dead center and then abruptly stopped, which seems unlikely if it only did part of a revolution.
    Good luck, be interesting to hear what it was. On the "bright" side at least you didn't do it, so it's entirely on them to fix it.
    2mchfun, T-Rex266, BigAl and 3 others like this.
  10. Jun 2, 2021 at 6:46 PM
    I would be stressed too, but it ran fine before it got to the shop, so the shop will make it right.
  11. Jun 2, 2021 at 7:01 PM
    Ryman42
    6” lift 35” tires
    Yeah, it ran fine before going in. I know it’s totally on the shop. I just thought it would of been a simple process, that’s not the way it’s working out. lol
  12. Jun 14, 2021 at 1:00 AM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    @Ryman42 How did it work out? Hope all is good.
  13. Jun 14, 2021 at 1:30 AM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    interested to know too.
  14. Jun 14, 2021 at 1:45 AM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
  15. Jun 14, 2021 at 3:37 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
  16. Jun 14, 2021 at 3:40 AM
    Adam New Member
    Hopefully he is too busy doing burnouts with his truck at this point to post.
    BigAl, YotaBro and HulkSmurf14 like this.
  17. Jun 14, 2021 at 4:43 AM
    TXTundra2722
    2015 Black Tundra
  18. Jun 16, 2021 at 10:31 PM
    AZTundra
    Paul
    Phoenix, AZ
    Any updates? :pccoffee: :boink:
