  1. May 30, 2021 at 10:00 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    link?
  2. May 30, 2021 at 10:06 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    The “head” of the shifter is thinner than the TRD shifter, but is just about as long from front to back and it has more body girth from top to bottom. It feels good in your hand
    “that’s what she said!”
  3. May 30, 2021 at 10:13 PM
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    So I wasn't able to start my sound upgrade but I was able to resume my sound mat install on 1 of the front doors. So far 4 rolls down of SoundShield to cover 3 doors inside and outer skin. Will keep you guys updated on the final count. O and FYI guys Big Big improvement on the doors when they close and road noise and on a side note if I was to just keep my stock sounds the matting made a big difference with the performance. Bass is better and the vocal as well.
    WFD473, Wallygator, CoCotton and 11 others like this.
  4. May 31, 2021 at 12:12 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    How hard was it to get all the sound deadening on the inner part of the door??
    TucsonTundra1794 likes this.
  5. May 31, 2021 at 4:47 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    I had him pose like that for a pic. Gun was unloaded and ammo was in his pocket. He's trained with a revolver to walk with the cylinder open, empty, and pointed downrange.
  6. May 31, 2021 at 5:49 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Haha. Well played. Thanks
  7. May 31, 2021 at 5:53 AM
    GoldenGoon89
    GoldenGoon89 New Member
    Houston,TX
    2018 CM -1794 BLUEEE- 4x4
    Installed lift, wheels/tires, UCAs all this weekend. Thought I was done but I’m rubbing on the cab mounts. Getting ready to disassemble and go up one more clip setting..
  8. May 31, 2021 at 6:20 AM
    Twowheelssoar
    Twowheelssoar New Member
    NC
    2021 Cement SR5 6-Seater
    Looks good. What’s the offset on those wheels?
  9. May 31, 2021 at 6:30 AM
    GoldenGoon89
    Houston,TX
    Thank you!
    From what I was told, they are +20. Could be wrong though.
    Twowheelssoar[QUOTED] likes this.
  10. May 31, 2021 at 9:30 AM
    TundroLoco
    TundroLoco New Member
    Angel
    2018 tundra SR5
    Your search on Amazon for this.
    Megatronix UPS Add-On Shock Sensor To Factory OEM Car Alarm Security Systems
    1. [​IMG]
    Wallygator, CoCotton, Jpd0144 and 3 others like this.
  11. May 31, 2021 at 10:10 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Finished my Readylift 3/2" install this morning. It took me all Friday evening, most of the day Saturday and probably a few hours on Sunday. Today is just torquing a bunch of bolts to spec, so not too bad.
    It's a bigger job than I thought. I would've saved time on day 1 had I purchased a floor jack. I went and purchased on Saturday morning.
    All in all, I'm extremely glad I did it myself and am very satisfied with the look. I haven't driven it yet. I still need to take it down to get the alignment done and I'm not going to drive it until then.
    I'm convinced had I taken it to a shop they would've cut corners. There were a lot of places where I considered it but persevered and did it the right way. Probably the worst part was installing the front differential spacers. The area is extremely tight.
    Here are a few pics.
    3" front lift. Rear still at stock.
    Most of these pictures are with 3" in front and rear still at stock. The one just below this is the finished product - 3" front, 2" back.
    This (by far) is my biggest mechanics job to date. Youtube videos convinced me I could do it myself, particularly the 3 part series from DIY Tundra Mods on Youtube. Many thanks to him. I think he's on this forum.
    I still think it looks a little high in the front. I'm hoping that possibly the alignment might bring it down a tad.
    Jego, dpast88, Wallygator and 20 others like this.
  12. May 31, 2021 at 2:25 PM
    ATOYOTA
    ATOYOTA New Member
    Ceramic coated her today
    152C5F06-C7C9-46CC-8942-70CF058AE9EB_1_201_a.jpg E587FD6A-C5EC-4B59-9D80-1D6B5B280D81_1_201_a.jpg
    Jego, AggiePhil, 3xYOTA and 26 others like this.
  13. May 31, 2021 at 2:27 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Started my AJT chrome delete. Just need to do the climate knobs, push start, and 4x4 pieces. I ruined my factory shifter plate as I drilled through in 2 areas and had a few close calls with my drill almost knicking the top area of the console.
    Next things to complete:
    -Rest of the AJT chrome delete
    -Install my Ditch Light and Light bar switch in the lower dash
    -aFe Cold Air Intake
    -Valhala's Shield mid and rear plates
    -Coachbuilder +3 shackles
  14. May 31, 2021 at 2:52 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    CLEAN and looks great De-badged!
    ATOYOTA[QUOTED] likes this.
  15. May 31, 2021 at 2:55 PM
    Steve18
    Steve18 New Member
    Virginia Beach
    2016 Black 4Runner Trail and 2021 Black Tundra TRD Pro
    Today I realized that when my moonroof is slide all the way open the wind deflector electronically raises/lowers depending on the speed of the vehicle. Anything over 45mph is lays flat, and anything below it raises up.
  16. May 31, 2021 at 3:03 PM
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    @Toe404 The rear doors wasn't hard at all. The front doors was a bit of a bitch because the opening at the lower part is smaller. If you have small hands your good but big hands and forearms is gonna sting a little. But it's worth it man. Big difference on this mat too. I belive it's better than Dynamat really. I've used that stuff on old projects and I have to say by far this brand is 10x better. Just my 2 cents really. Patience is the key too. Don't rush the job and take your time. Each door takes me about 3 hours and that's because I strip it of all the clips and wires plus that glue.
  17. May 31, 2021 at 3:11 PM
    lonedrake
    lonedrake New Member
    Minnesota
    2020 TRD sport
    Got my Ics fab and Ram iPad mount installed a couple of weeks ago. Might be my favorite mod so far. The bolts were a little tricky getting them in. I kept thinking “am I doing this right” Sure beats propping the iPad behind the wheel and trying to make sure it doesn’t fall down.
  18. May 31, 2021 at 4:18 PM
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    Used the truck Friday to shuttle 3 little girls to the zoo. Saturday, shampooed the seats to get out the ketchup the girls spilt the day before...
    I did get my ESP underseat storage put in.
  19. May 31, 2021 at 4:21 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Was planning to do a bracket for a fire extinguisher inside, but I think this might be a bit better for now.
  20. May 31, 2021 at 4:23 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    Radium Springs oil catch cans with the Stillen CAI. Had to improvise a little. Also installed the Valhalla's Cat protection plates. This is with a pro comp lift. Also done the Katskinz with heated and cooled option. Installed a fire extinguisher for just in case
  21. May 31, 2021 at 4:45 PM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    :101010:
  22. May 31, 2021 at 5:21 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Haha, I did the same in regards to the shifter plate. There wasn’t a whole lot of purchase with the lock washers on the plastic in some places, so I hope it all holds together.
    RoniusMaximus[QUOTED] likes this.
  23. May 31, 2021 at 5:21 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Agreed!
  24. May 31, 2021 at 5:25 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    I like this idea. Do you think if you flipped the red pin upside down, it would fit under a tonneau? Or can you even switch it?
  25. May 31, 2021 at 5:26 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    IMG_20210531_202048_412.jpg IMG_20210531_202048_434.jpg So fresh and so clean
  26. May 31, 2021 at 5:30 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Yup! I think it should fit under the tonneau if you flip it upside down.
    https://www.amazon.com/dp/B07V4VK4S6/ref=cm_sw_r_cp_awdb_imm_CKQDBRNGNHWHA690CKEZ?_encoding=UTF8
    https://www.amazon.com/dp/B08LG1N99S/ref=cm_sw_r_cp_awdb_imm_WYSYRP91R6M7QA2WRYN8?_encoding=UTF8
    I had to drill the holes on the fire extinguisher bracket so that way it would fit the Allen bolts provided by the t slot nuts.
    Wallygator likes this.
  27. May 31, 2021 at 6:16 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
  28. May 31, 2021 at 6:33 PM
    Bigsense78
    Bigsense78 New Member
    Columbia Gorge, OR
    2018 Tundra Platinum
    20210531_171146.jpgARB Diff Breather
    SAGE63, Wallygator, CoCotton and 15 others like this.
  29. May 31, 2021 at 7:14 PM
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    Went with a poor man's fuse box. When I bought the truck, I thought to myself, I'll never need to do this. Well, air bag compressor, dash cam, bed lights, 3w liner window mod,and damn it, I need one.
    Jcmf52, Wallygator, Ostrich and 8 others like this.
  30. May 31, 2021 at 8:42 PM
    5150bronco
    5150bronco New Member
    Justin
    Bay Area, Ca.
    Are you going to black out the head unit of the dash? The two big sides of the dash that is…
