Mysterious battery drain
Discussion in '1st Gen Tundras (2000-2006)' started by SouthPaw, May 31, 2021.
  1. May 31, 2021 at 10:12 AM
    SouthPaw
    SouthPaw [OP] The headlight guy
    2000 Limited 4x4 AC
    I’ve been chasing a battery drain for almost six months now. I’ve had the battery and alternator tested multiples times and both always test good. I’m not sure how long it’s been doing this because previously I was driving the truck everyday and now, it only gets driven once a week at best.
    If I don’t drive my truck for a week or so, it’s dead. I’ve done a ton of parasitic draw tests and the results vary. Sometimes the amp draw is 0.13 and other times it’s .03. No single fuse seems to reduce the amp draw though. As of yesterday and this morning, the amp draw has been consistent with .05 which is ‘within spec.’
    This morning I tested the diode in the alternator and it passed within spec.
    Side notes:
    I have noticed that two times it has been dead, it was with a heavy snow or raining. I’ve read where the windshield leaks and will let water into the fuse box inside the cab but everything looks and feels dry. Also, my torque app has been showing a spike in voltage while driving. It will record the max value and it has been anywhere from 15v-18v for a half a second. I’m starting to get to the point where it’s getting passed my diagnostic skill level and going to take it in. I suppose I could toss on a new alternator for grins but I don’t want to throw parts at it either. @empty_lord or anyone else that has some suggestions, I’m all ears.
    I will start a log to keep record of it:
    05/30 - Battery installed @ 7:20pm
    Amp draw - .05a
    12.45v
    SOH: 100%
    SOC: 73%
    CCA: 747
    R: 4.02m-ohm
    06/01 - 12:47pm
    Amp draw - .05a
    12.35v
    SOH: 100%
    SOC: 55%
    CCA: 747
    R: 4.02m-ohm
    *started for 10min around 2pm*
    Test drive at 6:09pm
    Amp draw - .04a - removed aux fuse box
    12.38v
    SOH: 100%
    SOC: 63%
    CCA: 719
    R: 4.17m-ohm
    After test drive 6:44pm
    12.72v
    SOH: 100%
    SOC: 98%
    CCA: 742
    R: 4.04m-ohm
    06/02 - 7:10am
    Amp draw - .035
    12.37v
    SOH: 99%
    SOC: 61%
    CCA: 708
    R: 4.24m-ohm
    Battery charge test - 06/02
    Starting results before charge
    12.42v
    SOH: 100%
    SOC: 70%
    CCA: 740
    R: 4.05m-ohm
    2a charge from 3:37pm till 9:31pm
    Results
    12.94v
    SOH: 100%
    SOC: 98%
    CCA: 761
    R: 3.94m-ohm
    Retest: 06/03 - 8:17am
    12.65v
    SOH: 100%
    SOC: 98%
    CCA: 754
    R: 3.98m-ohm
    **Battery installed at 10:00am**
    Battery tested at 8:14pm
    12.61v
    SOH: 100%
    SOC: 98%
    CCA: 753
    R: 3.98m-ohm
    PROGRESS!
    06/04/21
    Restarted again this morning at 10:29AM
    12.54v
    SOH: 100%
    SOC: 90%
    CCA: 746
    R: 4.02m-ohm
    Amp draw: .030 without accessories
    Amp draw: .044 with accessories
    Drove to car wash and retested - 11:13am
    12.91v
    SOH: 100%
    SOC: 98%
    CCA: 749
    R: 4.00m-ohm
    Parked and everything back to normal including arming Viper.
    Retest - 10:12PM
    12.56v
    SOH: 100%
    SOC: 93%
    CCA: 764
    R: 3.93m-ohm
    06/05/21 - Retest 12:26pm
    12.47v
    SOH: 100%
    SOC: 78%
    CCA: 766
    R: 3.91m-ohm
    Battery test - 5:34pm
    12.50v
    SOH: 100%
    SOC: 83%
    CCA: 771
    R: 3.89m-ohm
    Battery test - 10:39pm
    12.47v
    SOH: 100%
    SOC: 78%
    CCA: 769
    R: 3.90m-ohm
    06/06/21
    Battery test - 11:13am
    12.43v
    SOH: 100%
    SOC: 71%
    CCA: 769
    R: 3.98m-ohm
    *good battery*
    Battery test - 5:07pm
    12.43v
    SOH: 100%
    SOC: 71%
    CCA: 769
    R: 3.95m-ohm
    *good battery*
    Battery test - 8:21pm
    12.43v
    SOH: 100%
    SOC: 71%
    CCA: 756
    R: 3.96m-ohm
    *good battery*
    06/08/21
    Battery test - 10:07pm
    12.38v
    SOH: 100%
    SOC: 63%
    CCA: 743
    R: 4.04m-ohm
    *good battery - RECHARGE*
    06/09/21 - Test drive, parked at 8:40am
    06/11/21 Battery test - 7:17am
    12.32v
    SOH: 100%
    SOC: 53%
    CCA: 714
    R: 4.20m-ohm
    10:15am
    12.32v
    SOH: 100%
    SOC: 53%
    CCA: 717
    R: 4.18m-ohm
    4:47pm
    12.35v
    SOH: 100%
    SOC: 58%
    CCA: 722
    R: 4.16m-ohm
    06/13/21 - 09:46am
    12.27v
    SOH: 100%
    SOC: 45%
    CCA: 706
    R: 4.25m-ohm
    06/13/21 - 12:12am
    12.32v
    SOH: 100%
    SOC: 53%
    CCA: 714
    R: 4.20m-ohm
    06/13/21 - 09:46am
    12.27v
    SOH: 100%
    SOC: 45%
    CCA: 706
    R: 4.25m-ohm
    06/13/21 - 06:55pm
    12.33v
    SOH: 100%
    SOC: 55%
    CCA: 718
    R: 4.18m-ohm
    06/14/21 - 02:39pm
    12.31v
    SOH: 100%
    SOC: 51%
    CCA: 701
    R: 4.27m-ohm
    06/19/21 - 02:27pm
    12.29v
    SOH: 100%
    SOC: 48%
    CCA: 695
    R: 4.30m-ohm
    06/20/21 - 05:58pm
    12.28v
    SOH: 100%
    SOC: 46%
    CCA: 698
    R: 4.29m-ohm
    06/27/21 - 05:47pm
    12.43v
    SOH: 100%
    SOC: 71%
    CCA: 755
    R: 3.97m-ohm
    *Good battery*
    06/29/21 - 09:13pm
    12.36v
    SOH: 100%
    SOC: 60%
    CCA: 728
    R: 4.12m-ohm
    *Good battery - RECHARGE*
    06/30/21 - 10:58am
    12.34v
    SOH: 100%
    SOC: 56%
    CCA: 714
    R: 4.20m-ohm
    2018 Silverado 1500
    Sitting for two weeks
    08/14/21 - 09:28am
    12.22v
    SOH: 100%
    SOC: 36%
    CCA: 714
    R: 4.18m-ohm
    08/31/21 - 09:31pm
    12.51v
    SOH: 100%
    SOC: 85%
    CCA: 750
    R: 4.00m-ohm
    *Good battery*
    09/02/21 - 08:06am
    12.34v
    SOH: 100%
    SOC: 56%
    CCA: 718
    R: 4.17m-ohm
    *Started and moved - 2min*
    09/02/21 - 08:11am
    12.89v
    SOH: 100%
    SOC: 98%
    CCA: 750
    R: 4.14m-ohm
    *Good battery*
    YardBird likes this.
  2. May 31, 2021 at 10:19 AM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    I have been in the same boat with my ‘03 since I have owned it. I initially thought it might be from the rats nest of trailer light/camper top wiring iterations. I’ve cleaned that all up. Everything tests fine, though electrical things remain a bit of voodoo to me. It has been to three mechanics, all of whom tried to diagnose but found nothing.
    Sometimes it is dead overnight, sometimes it holds a charge for a week. I can offer no help, but eagerly follow your hunt.
    SouthPaw[OP] and FrenchToasty like this.
  3. May 31, 2021 at 10:25 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Have you recorded humidy, temps, times, sunshine, clouds during parasite testing?
    I assume you do not have garage so your truck would be 100% exposed to the elements 100% of the time, and those factor in which could help you see a correlation between High Draw and low draw circumstances.
    High draw may be on Hot, Dry day.
    Low draw my be on Cold, wet day.
    Data points to see the trend!
    What happened about 6 months ago? Install aftermarket radio?
    This is the only thing "electrical" that's on your build thread from about 6 months ago.
    See if you can unplug this, and then do draw testing exactly how you were before.
  4. May 31, 2021 at 10:32 AM
    SouthPaw
    2000 Limited 4x4 AC
    So during the parasitic draw test, you remove each fuse to isolate the circuits. By doing so, I’ve removed the radio, remote start and aux mirror circuit with no change in amp draw.
    As far as weather goes, it seems to be dead on colder/humid weather but I haven’t been watching it that close. I do not have enough garage space, so yes, it sits outside.
  5. May 31, 2021 at 10:56 AM
    tdrich7
    tdrich7 New Member
    2006 Tundra DC 4wd SR5
    Best of luck with this - I've dealt with this issue on a different vehicle and know your pain. Hope you get it figured out.
    RitcheyRch and SouthPaw[OP] like this.
  6. May 31, 2021 at 11:06 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Have you replaced the battery? I’ve had sulfated cells cause weird drains but always pass
    Jack McCarthy likes this.
  7. May 31, 2021 at 11:40 AM
    SouthPaw
    2000 Limited 4x4 AC
    Yup, I’m on my third one lol. The last one was replaced in 12/2020 so it’s the only six months old. It’s tested good on multiple testers.
  8. May 31, 2021 at 11:46 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Check and clean all grounds and battery connections. These are the obvious which I assume you’ve done.
    Still think its the Alternator based on the spikes. Maybe disconnect the battery fully after its charged and bring it in the house until you need to start her up. This should rule out a phantom drain during the week.
    Original Alternator? Might be time regardless if its something else. Iirc you have 270k miles on her?
  9. May 31, 2021 at 11:51 AM
    SouthPaw
    2000 Limited 4x4 AC
    Yes, all cables are squeaky clean. Is their a diagram for all grounds? All obvious ones are clean and tight.
    Right now, the battery has been disconnected since yesterday afternoon after the parts store gave it a 100% charge and it passed with flying colors.
    I still may think I’ll throw one on there since they aren’t that hard to change nor expensive. She’s got just about 190K and it appears to be the original.
  10. May 31, 2021 at 12:00 PM
    Fred
    Hand Protectors
    Grounds:
    1) Next to Battery
    2) Fire Wall near Heater Core entry/exit
    3) 2 on either side of backside of engine between Firewall (skinnys)
    4) @FrenchToasty favorite ground on the Driver Side Block down low just below the Front o2 Sensor (Thicky).
    3) and 4) aren’t on any of the FSM Diagrams AFAIK.
    Your Alternator is Ground to the Block so pay attention to clean up the mating contacts and bolts/nuts. Maybe use some NoAlox.
  11. May 31, 2021 at 12:15 PM
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    Your chase and processes of elimination is on target and my first thought would have been alternator diodes leaking to ground. As previously mentioned and before you take it in and pay someone to start the process all over again, I would pull one fuse at a time and see if the problem shows up as a last effort.
    Good luck with your search.
    BubbaW likes this.
  12. May 31, 2021 at 12:30 PM
    If it were me, I’d use one of these Hall effect current clamp meters than can measure down to a milliamp.
    But then again, I’m just trying to find a good reason to buy one. :D
  13. May 31, 2021 at 12:37 PM
    Fred
    Hand Protectors
    Are you wearing a G-String in this pic?:rofl:
  14. May 31, 2021 at 12:58 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    More often than not, it's the aftermarket security system/remote starter. Dash cam "parking mode" capabilities are the other. Take a very detailed look there and let the truck sit with it disconnected.
  15. May 31, 2021 at 1:08 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I’ll never be able to look at an A-26 the same way again…..
  16. May 31, 2021 at 1:09 PM
    Traced mine down to trailer harness wiring for my 7 pin. Could be the trailer brake controller. These things are aftermarket and were not attached to the factory fuse box. I pulled the hot wire to the 7 pin trailer harness wiring and the draw dropped from 0.12 to 0.03. Haven't had a dead battery since. Haven't figure out which component is the culprit, but it's likely the aftermarket backup camera that was using the trailer harness +12v for a power source. I wired it into the backup light trigger for now so that it's only on when I'm reversing.
    SouthPaw[OP] likes this.
  17. May 31, 2021 at 1:24 PM
    SouthPaw
    2000 Limited 4x4 AC
    I appreciate the advice. I’ve lost count on how many times I’ve done this test but 10 min ago, I pulled each fuse one by one again monitoring the amp draw. No single fuse drops it except the 15A dome light fuse. It holds steady at .05mA and when I pull the dome light fuse, it drops to .04mA so not a huge difference. Once I reinstall the fuse, it bumps up to .09mA (radio is getting energized I presume) and then after 3-4 seconds, it drops back down to .05mA. I’ve left my multimeter on it for 30min now and it’s holding steady at .05mA with no change.
    My truck does have an aftermarket trailer harness on it that I can see if I can do the same and remove the hot wire but according to my tests, it’s not getting a big draw from the battery or at least when I’m looking at it.
  18. May 31, 2021 at 1:24 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The Elec Wiring Diag(EWD) have grounding point drawings.
    I would also suggest checking your cabin gnds especially kick panel area, if you haven't already.
    Just curious if you ever fixed the one by your battery ?
    Multiple electrical issues first gen 2001 Toyota tundra
    @RainMan_PNW made EWD's available in General Discussion Section for 1st Gen and udder gens....Ultimate Wiring Diagrams Collection | Toyota Tundra Forum (tundras.com)
    MS22 and RainMan_PNW like this.
  19. May 31, 2021 at 1:25 PM
    SouthPaw
    2000 Limited 4x4 AC
    I think I will call the two shops and see if they have a way of double checking their work to make sure it isn’t something on their end. Both came with a lifetime warranty on parts and labor.
  20. May 31, 2021 at 1:31 PM
    mountainpete
    Also how did you wire your light bar? Is the relay connected to switched or constant power?
  21. May 31, 2021 at 1:37 PM
    SouthPaw
    2000 Limited 4x4 AC
    Here are few additional findings:
    When removing the “CARGO LP5A” fuse, the draw goes up to .06mA. Not sure if that is normal?
    This is looking the carpet behind the E-brake. It looks like it’s wet at the top but it’s dry. We have had heavy rain the last few days so I would assume if it was leaking, it would have done it now.
    Looking at the brake pedal assembly etc. They have some surface rust.
    Appears to be the OG alternator:
  22. May 31, 2021 at 1:37 PM
    SouthPaw
    2000 Limited 4x4 AC
    Separate fuse box with separate fuses. I have removed those fuses and no change.
    mountainpete[QUOTED] likes this.
  23. May 31, 2021 at 1:38 PM
    P-Factor
    P-Factor New Member
  24. May 31, 2021 at 1:40 PM
    SouthPaw
    2000 Limited 4x4 AC
    Yes I did get that fixed, thanks for the post. From my brief google-fu, it appears bad grounds don’t cause battery drains? I only briefly searched that so if that is incorrect, someone please correct me.
  25. May 31, 2021 at 1:41 PM
    Fred
    Hand Protectors
    No closer, but thank you. :thumbsup:
    P-Factor[QUOTED] likes this.
  26. May 31, 2021 at 1:42 PM
    Fred
    Hand Protectors
    Good grounds will help with charging and electrical efficiency.
    KK6PD likes this.
  27. May 31, 2021 at 1:47 PM
    Fred
    Hand Protectors
  28. May 31, 2021 at 1:56 PM
    Fred
    Hand Protectors
    Might be a good time to peel back the A-Pillar Gaskets and unscrew the metal plate underneath which is easy. Inspect those 4 clips and associated gaskets. Mine were failing. Not sure if they ever leaked, but they were on the way out. Used Butyl Tape to seal up. I did this after a new windshield. Check my build page for pics.
  29. May 31, 2021 at 7:22 PM
    SouthPaw
    2000 Limited 4x4 AC
    I’ll take a look. I think this week, if the weather holds, I’ll remove that cowl under the wipers and put a bead of marine silicone at the bottom to eliminate that, just in case. I hooked up the battery tonight and I’ll make a log over the next 2-3 days on the battery activity.
  30. Jun 1, 2021 at 6:42 AM
    Richid
    Richid New Member
    Just an FYI:
    I had this same problem with my old F250. All stock except a chip and remote start (even radio). In the winter, the truck would need a jump if it sat more than a week. This went on for a year until one day the alternator failed and the idiot light came on.
    It had passed all the tests without issue as well. Haven't had any problems since replacing the alternator, even after it sat for a month.
    Best of luck - it's a PIA to have to think about if it will start when you go to use it.
    SouthPaw[QUOTED][OP] likes this.
