Barrage of lights...suddenly!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by odaflo, May 29, 2021.
  1. May 29, 2021 at 12:23 PM
    odaflo
    odaflo [OP] New Member
    Deltona
    2019 Tundra XP FLEX FUEL
    I have a 2019 Tundra and I was driving this morning when boom....a bunch of light came on all of a sudden.
    Trailer brake error
    Pre-collision malfunction
    check engine
    yellow triangle with exclamation mark
    slip indicator light
    and another light that keeps blinking on and off...right above the slip indicator light
    There was no heavy demand or towing involved...normal driving conditions. Im at a loss. Does anyone know what this is or could be??
    I had to upload a video in Youtube because its too much to type....here is the link
    https://www.youtube.com/watch?v=HfkGc_J_PWs
    Thank you in advanced...God bless you all!!
  2. May 29, 2021 at 12:39 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Sounds like you may have had some rodents snacking on a wiring harness. You can check your battery, they’ve been known to cause weird issues when they go bad but not completely bad. Good luck!
  3. May 29, 2021 at 12:40 PM
    Welcome from NY.
    Try cleaning the emblem on the grille first. Is it raining?
    15whtrd likes this.
  4. May 29, 2021 at 1:03 PM
    Taco-Spike
    Two Trucks
    X2
  5. May 29, 2021 at 1:50 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    X3.
  6. May 29, 2021 at 2:46 PM
    Pinski
    Pinski New Member
    Mark
    Western New York
    2018 SR5 TRD Crew
    Volant (Corsa) cat back,tint
    I had the same thing happen last week. After five start up cycles it disappeared and hasn’t come back. I have 2018 50k hopefully it doesn’t come back. Mine ran fine, never knew there was anything wrong. Try a bunch of start/stops hopefully it clears it up for you like it did me.
  7. May 29, 2021 at 3:17 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    2019?
    Drive it to your dealer.
    15whtrd likes this.
  8. May 29, 2021 at 3:30 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    Why? At 39,425 miles you're out of the comprehensive warranty.
    I would pull the codes if possible and if related to the powertrain, maybe take it to the dealership as you should be covered until 60k, but I don't think this is "powertrain" related per say.
    Definitely sounds like it may be rodents.
  9. May 29, 2021 at 3:59 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    https://www.tundras.com/threads/2017-tundra-having-a-freakout.89697/
    Everytime I hear about this I immediately think low voltage.
  10. May 29, 2021 at 4:00 PM
    odaflo
    Deltona
    so update...
    Checked for damaged wires and no go
    pulled codes and I got 2
    P0172 System Rich
    P0175 System Rich
    I have a cold air intake that I installed about 1 month ago though?????
    someone I know said if I fix those codes (rich codes), meaning if I put original intake box back in all codes will dissapear...because somehow they are all connected...I found this questionable...can anyone confirm or have similar experience?....this is sooo frikin weird...I would have never thought engine codes can trigger trailer brake and pre collision codes????
  11. May 29, 2021 at 4:12 PM
    azs406
    azs406 New Member
    The codes stored by the other ECU's are typically engine control system DTC's. Your other ECU's are pretty much pointing the finger at your engine ECU saying, " He did it"!
    15whtrd likes this.
  12. May 30, 2021 at 5:58 AM
    JackwagonJim
    JackwagonJim New Member
    Purlear, NC
    Ill bet rodents too. Had the same thing. Rodents got the knock sensor.
  13. May 30, 2021 at 6:55 AM
    ZiaTundra
    ZiaTundra New Member
    Thought this was gonna be about UFOs
  14. May 30, 2021 at 8:01 AM
    azs406
    azs406 New Member
    I would disconnect battery for a while, let everything reset and then test drive. If the codes take several drive cycles to come back then you can pretty much rule out rodent damage.
    15whtrd likes this.
  15. May 30, 2021 at 10:01 AM
    odaflo
    Deltona
    So I went out on a limb and bought a new MAF sensor...surprisingly it only cost $89...and that solved allll that BS problem!!!!! infrikincredible!! Case closed..thanks guys!
