Headlights won't Turn on Fuse and relay tested !
Discussion in '1st Gen Tundras (2000-2006)' started by Xjrast, May 29, 2021.
  1. May 29, 2021 at 4:07 PM
    Xjrast
    Xjrast [OP] New Member
    Hi everyone,
    I have a 2005 Toyota tundra my problem is my headlights wont turn on only the side orange lamps and the spotlights , have checked the relay its fane , the 10 Fuses wont recieve eltricity , if u guys know to solutions of the please Help thank you .
  2. May 29, 2021 at 4:17 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Both high and low beam don't work ?
    Do you have DRL's ?
    Curious what you mean by "spotlights" ?
    Xjrast[QUOTED][OP] likes this.
  3. May 29, 2021 at 4:52 PM
    Check the connector plugging into the back of the lamp, it may be burnt causing a short. Also, check to see if the high beams work, since that’s a separate wire feed.
    Actually, this may not be it since it doesn’t work on both sides from what you’re saying. No voltage at the fuse?
    Xjrast[OP] likes this.
  4. May 29, 2021 at 6:35 PM
    Xjrast
    I meant the Foglights and i dont have DRL , e tested the 3 red fuses ( 10) i dont get any voltage , i replaced the relay but nothing
  5. May 29, 2021 at 7:01 PM
    I’d recommend getting ahold of a wiring diagram. If you’re not getting 12v on the fuse that indicates the headlight relay to me. I would make sure that relay is getting energized. If it’s not, which I would assume here, I’d look further into what’s causing it by looking at the diagram.
    Here’s what my Haynes manual shows…
  6. May 29, 2021 at 8:24 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
  7. May 30, 2021 at 5:21 AM
    Xjrast
    My relay is getting energized , based on your guys suggest i will check the diagram and check the wires .
    Jack McCarthy likes this.
