  1. May 29, 2021 at 7:49 PM
    #6781
    Nice....how long is the build time?
    WAtundra4x4[QUOTED] likes this.
  2. May 29, 2021 at 7:51 PM
    #6782
    Azblue
    The Dirty T ( ^_^)_且
    That blows. Actually sounds like how most of my projects end up going.
    FrenchToasty and TaquitoBandito like this.
  3. May 29, 2021 at 10:52 PM
    #6783
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Dog house is coming along!
    1lowlife, Azblue, Fotnot and 9 others like this.
  4. May 30, 2021 at 6:28 AM
    #6784
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Too long. ECD is mid September, but they are saying could slide to November. Current homes being completed have been running 10-12 months due to shortages. If Sept, it will be 10 months. It took them 4 months to break ground.
  5. May 30, 2021 at 6:56 AM
    #6785
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I see you’re putting a bigger door in there for when you need to spend the night out there. Good thinking… :thumbsup:
  6. May 30, 2021 at 7:51 AM
    #6786
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Just keep a eye out for dog hair built on that coil, HELLA dog house.
    kparrow[QUOTED] likes this.
  7. May 30, 2021 at 10:15 AM
    #6787
    WAtundra4x4
    Den
    Wet side WA
    A few more photos of the framing. Previous posts 6577, 6876,7025. Basement framing done and main floor. Concrete back deck poured. Waiting for main floor inspection before they can continue.
    3D02D170-5050-4A7D-B7F5-0892DB106477.jpg B80DA379-22A8-4DE9-AE4C-F4C8845CBBF7.jpg A8142252-E29A-420C-B558-B119A4B5DCB3.jpg F74FC8F6-5D9F-4548-9F89-50F2E4E9FDB8.jpg 1808C078-4FD5-4460-A896-3F4A81121BCC.jpg 33B6DDE4-729D-401B-9F33-ED827337188E.jpg CE5B1215-00B2-441C-B148-937415D009FC.jpg
  8. May 30, 2021 at 4:39 PM
    #6788
    Got our deck stained today. Here's a little before/after. I did the railing after I took the photo so it looks better now.
    BlueRibbon4x4, drobb, Fotnot and 9 others like this.
  9. May 31, 2021 at 9:57 AM
    #6789
    TaquitoBandito
    Joel (AKA Bif)
    Our lawn is mowed and our grass is finally covering the lawn in the front of the house - only took 5 years for the grass to fill in...
  10. May 31, 2021 at 10:04 AM
    #6790
    Pretty much finished the south/alley side of the Great Wall. I ran out of red heads to mount the rest of my uprights on the east and west walls that I share with neighbors. The corrugated went up relatively easy for being 12 footers. I will probably spray with vinegar and salt, and then get the quick reaction with hydrogen peroxide. Stoked to have some privacy; doesn’t change my habits but at least now people can’t see me!
    E8E726C8-F2F8-4A60-A336-CAD71976241F.jpg F520E8DB-BC7C-4019-B546-953FFC099EBC.jpg B5E72DA0-8C4A-4087-B237-E63F88038DC6.jpg 433A1C97-B89C-41A1-8CAB-19231ACCBD7C.jpg
  11. May 31, 2021 at 10:41 AM
    #6791
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Rebuilt my well pump this morning trying to figure out why it wont build to 50psi anymore. Still not reaching 50. I must have a leaking pipe going out to the well somewhere.
    Also included is a .gif of the local wildlife eating my hibiscus while I was working.
  12. May 31, 2021 at 11:54 AM
    #6792
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    In our Kitchen, I installed soft close drawer guides, soft close hinges & new hardware. I removed the Pre existing shelving in this lower cabinet and installed two Rev A Shelf pull out organizer units for our pots and pans. Definitely made it a lot easier to get at things.
    Before:
    After:
  13. May 31, 2021 at 12:30 PM
    #6793
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    got the rest of the garden in. Tomatoes, pumpkin, squash. Cool weather veggies are doing great.
    Need to finish the flower bed
    Major clean of the 70g aquarium
    Fotnot, TaquitoBandito and jewsNbrews like this.
  14. May 31, 2021 at 12:55 PM
    #6794
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    May be not as extensive as some other projects, but I had to get the garage into some order before I could actually do bigger projects. Glad I did it. Watched reviews on YouTube. Gave it a go.
    Before when I would work on a vehicle I would be moving everything around to pull it in now everything is already out of the way.
    By the way I am selling those rims hahah
  15. May 31, 2021 at 2:43 PM
    #6795
    3 rooms of whisker outlets covers to hide cables. Only a few pix
    Before / during / after
  16. May 31, 2021 at 5:11 PM
    #6796
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Dog house part 3.....painted, door is made, and dog door is on. Next step is to insulate and sheet the inside. Done for today though.
    58AC1EBE-A41C-4EE7-A632-D9EE2BC5F4AB.jpg 7547A298-5AFF-48A5-B737-2D14E9577A24.jpg E2244C5C-5D5B-41C6-8AC3-0846E1DECAED.jpg 16C47D81-31B5-4BE8-829F-1A658B869B21.jpg
  17. Jun 1, 2021 at 9:36 AM
    #6797
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    I need a pic of this dog please..:cool:
  18. Jun 1, 2021 at 11:08 AM
    #6798
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Doggie 1 and 2. Josie and Archie
    3FF0CBBD-9A99-4736-B1BA-0F5758A06750.jpg 2E007F6A-1B77-4AF8-9053-A33BE957628C.jpg
  19. Jun 2, 2021 at 11:39 AM
    #6799
    vl184009
    Vicky
    Southern, Ca.
    You are a great dad, I am sure they will LOVE their new digs!
  20. Jun 2, 2021 at 7:45 PM
    #6800
    Half Assed
    Heartland Florida
    Dumpster dived for some new deck boards at a jobsite today.
    The carpenters told me it's Ipe wood. $6 a foot. I have 300 feet in the truck. :eek:
    There might be enough to build a new fence at my place too. I'm going to try and get the rest of it. :spy:
  21. Jun 2, 2021 at 7:53 PM
    #6801
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    Score! Ipe is great. Make sure your blades are sharp!
    BlueRibbon4x4, 1UPPER and RainMan_PNW like this.
  22. Jun 2, 2021 at 8:03 PM
    #6802
    Half Assed
    Heartland Florida
    I cut them with my circle saw to fit in the workvan and I already felt it bogging down when I was cutting the last few lol. I threw my miter saw in truck this afternoon for when I go back.
    jewsNbrews and TaquitoBandito like this.
  23. Jun 2, 2021 at 8:19 PM
    #6803
    Buckeye1977
    Buckeye1977 New Member
    Get it all!!
    Norfolk757 likes this.
  24. Jun 3, 2021 at 1:31 PM
    #6804
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I have a question for someone with experience with paint removal. I have some beams that make up our living room and actually go through the house and make up the balcony. I'd like to strip the blue paint in order to stain them.
    Here is a picture of part of the house with the beams on the balcony (just took a tree down).
    Here's an inside picture where you can see the beams in the ceiling and they go all the way through the house.
    I'd like to stain them to go along with our addition, which uses a walnut on the stairs to the right of the garage (bad picture). The goal is for the whole house to be the new siding.
    WAtundra4x4 likes this.
  25. Jun 3, 2021 at 2:35 PM
    #6805
    RainMan_PNW
    Casey
    Clark County, WA
    What age is the house? Could that paint be lead based at all?
    The best method is going to involve a lot of manual work... use a stripper like citristrip gel to get the bulk of it, followed by detail work with toothbrushes and sanders. But if it's lead based paint you'll need to take precautions before doing any sanding and will need to dispose of anything you strip correctly. Once you've got them stripped down to bare wood, then you're good to go.
  26. Jun 3, 2021 at 3:18 PM
    #6806
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Originally built in 1965, but I believe the blue paint was done back in early 2000's. I am pretty/very confident it isn't lead based.
    I was afraid of that. I was hoping for some simpler method. Thanks for the input. Very much appreciated.
    TaquitoBandito likes this.
  27. Jun 3, 2021 at 3:30 PM
    #6807
    1UPPER
    TEXAS
    Flux capacitor!
    I would reach out to dustless blasting and see if they have any local preferred contractors in your area. If you used a company that can do mobile media blasting you will get a better finish result and the save a lot of time! The interior beams look like Douglas Fur but it’s hard to tell for sure from the photos.
    The media blasting or dustless blasting can also make quick work or stripping or restoring wood to its original wood grain. They can use different material in the machine for different end results.
    https://www.dustlessblasting.com/applications/wood
  28. Jun 3, 2021 at 4:58 PM
    #6808
    TaquitoBandito
    Joel (AKA Bif)
    I think they stopped putting lead in paint in the 70's. Unfortunately, lead will leach through the paint layers so if they painted it with lead based paint and didn't correct it before the final painting in the 2000's, you may still have an issue. You can get a simple lead testing kit from Lowes or the Depot - that way you know what you are dealing with.
    NewImprovedRon and jewsNbrews like this.
  29. Jun 3, 2021 at 5:40 PM
    #6809
    1UPPER
    TEXAS
    Flux capacitor!
    I’m on the finishing touches remodeling four bathroom showers for a clients home. These are the before and after photos of the two kids showers. My tile guys definitely had a lot of work on these four showers. Ever niche, corner and edge of a tile transition had schluter trim details. This required a lot more steps and attention to detail. My clients have been very happy with the end results!
    Shower 3 before:
    C1C695C9-5A97-46FA-9CAC-E05767318D29.jpg 76180DA0-3099-4931-8014-E3844FCAD99B.jpg
    Shower 2 after: Changed out the plumbing for an adjustable shower head for kids and they grow taller. Install a new niche closer the shower bench. Installed a tile covered floor drain.
    8ECB29C5-C1E6-4FEF-B726-1AB0FB20796B.jpg 90B5E34D-F5FE-4236-B759-413A1FB9D727.jpg
    Shower 3 before:
    Shower 2 After: Relocated the plumbing for shower head to the side wall so water isn’t spraying towards the door opening. Added a large recessed tile niche over the shower bench. Removed the framed glass door and installed 3/8” frameless glass door and glass.
    Master Bathroom before:
    Master Bathroom after:
    Still have some paint touch ups to do but the hardest parts are all done.
    Bathroom 4 before:
    Bathroom 4 after:
  30. Jun 3, 2021 at 6:06 PM
    #6810
    Half Assed
    Heartland Florida
    My back hurts. :laughing:
    I'm guessing there's around 600 sq ft in the truck. Still more available, but it's not demo'd yet.
