Lower ball joint
Discussion in 'Suspension' started by el_taco, May 29, 2021.
  1. May 29, 2021 at 8:43 PM
    el_taco
    el_taco [OP] New Member
    What do ya think of my LBJ?
    Suspension is all stock with 158k. Truck is 2010 4-bie crewmax.
    Its been like this for a some time..not sure when it started. Mooving the boot i can see it is torn in that middle crease. I can see some grease still in there but it seems grease has been seeping some.
    Should i be concerned?
    Im in the middle of mooving houses and all my tools are in storage so i cannot address this any sooner.
    Being how the ball joint is 'sandwiched' or 'clamped' between that lower bracket and the spindle, should i be concered that if the LBJ failed that it will take out that whole front side?....like the first gens?
  2. Jun 3, 2021 at 7:00 AM
    el_taco
    Anyone?
  3. Jun 3, 2021 at 8:11 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    If your in the middle of moving, I would keep going, it won't leave you stranded.
    edit: It would take a collision for it to come apart.
  4. Jun 3, 2021 at 9:37 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The ball joint is in compression, versus the 1st gens where it's in tension. That means regardless how sloppy the joint gets, there's nothing trying to pull it apart. I wouldn't worry about it, wouldn't hurt to change it or reboot it eventually. Could pump some grease into it if you're feeling froggy too.
    Vang530 likes this.
