CMC or Alignment? Whats the issue?
Discussion in 'Suspension' started by GoldenGoon89, May 28, 2021.
  1. May 28, 2021 at 7:33 PM
    GoldenGoon89
    GoldenGoon89 [OP] New Member
    Houston,TX
    2018 CM -1794 BLUEEE- 4x4
    Hey all,
    I need some advice on what to do with this, as it did not turn out as i had planned.
    Here is the specs as follows.
    2017 tundra 4x4 CM. JBA HD UCAs. Eibach adjustable shocks stage 1 front lift with coilovers.
    285/75/18 duratrac tires. Fuel 18" +20.
    Well I got everything installed today and had it aligned. I knew there was some rubbing on the front fender well, Was going to heat it up and push out of the way. Got home from my alignment and realized that i am now rubbing on my body mount.
    Numbers looked good on the report sheet that I was given.
    Is this from my alignment? really not sure what the next step is?
    BMC/CMC? or Find someone else to do the alignment?
    Thanks!
  2. May 28, 2021 at 8:05 PM
    Post your alignment sheet but you will probably need a chop due to the offset.
  3. May 28, 2021 at 8:37 PM
    GoldenGoon89
    Houston,TX
    Will do! I’ll post in the AM.
  4. May 28, 2021 at 8:41 PM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    Do you have pics?
    GoldenGoon89[OP] likes this.
  5. May 29, 2021 at 5:30 AM
    GoldenGoon89
    Houston,TX
    Here is the alignment sheet.
  6. May 29, 2021 at 5:31 AM
    GoldenGoon89
    Houston,TX
    Drivers side.
  7. May 29, 2021 at 11:43 AM
    Joro43
    Joro43 New Member
    BMC for sure based on the pictures. Just hack the corner off
  8. May 29, 2021 at 1:56 PM
    GoldenGoon89
    Houston,TX
    That’s exactly what I’m about to do. Going to grab some cutting tools now.
  9. May 31, 2021 at 9:56 AM
    GoldenGoon89
    Houston,TX
    Any more opinions from anyone?
    Thanks!
  10. Jun 6, 2021 at 7:35 AM
    rbros
    rbros New Member
    2021 White Limited TRD
    Was it rubbing the body mount before the alignment?
  11. Jun 6, 2021 at 9:05 AM
    GoldenGoon89
    Houston,TX
    yes it was.
