Is it worth it to keep my truck
Discussion in '1st Gen Tundras (2000-2006)' started by Stuckinthistruck2002, Apr 7, 2019.
  1. Apr 7, 2019 at 11:44 PM
    Stuckinthistruck2002 [OP] New Member
    Ernest
    2002 Toyota Tundra
    I need rack and pinion ,transmission fluid change (possible used trans or rebuild a couple )window latches, door handles and a rear bumper. Doesnt leak oil brakes needed all around maybe 2 tires handful of rubber hoses. 213,000 miles low pressure on the gauge (could be gauge motor sounds and performs okay)and could use a new battery. is it worth it? It’s a handme down pickup probobaly need the truck to carry 1000 lbs in bed in the summer no more than 600 lbs in the cab never trailer.Kind of like the ease of loading a van but this truck has a bed low enough to load.I would have to add a camper to be able to compete with the ease of a van.I have a couple of 3/4 ton vans in my area with less issues and lower miles from 4000 to 5000 cash.Will this vehicle handle a little more or should I move up a little in payload?The truck is comfortable and more visually appealing than a van.Let me know a newer truck with a high bed is out of the question
  2. Apr 8, 2019 at 12:57 AM
    Aerindel
    Aerindel New Member
    Montana
    Well....when I bought mine it already had 300,000 plus miles on it, S title, needed brakes and new exhaust system and valve cover seals so...I at least would be be happy to trade trucks with you.
    joseph_womack, Sunnier and Black Wolf like this.
  3. Apr 8, 2019 at 6:25 AM
    Professional Hand Model
    Fred
    Hand Protectors
    They are great trucks. I tow and haul (up to 1600lbs) regularly. Sounds like you have a bit of work to do on this one, which is good if the price is right. They are easy trucks to repair and can be ridden hard and take the abuse.
    Black Wolf likes this.
  4. Apr 8, 2019 at 9:02 AM
    00TundraZ
    00TundraZ New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    i have done everything you mention above minus the door handles & bumper. My truck has 219,xxx on it and I have done all listed and more in the last 5000 miles. I do not regret it one bit. I plan to put a lot more into it.
    Just my $.02. I love these first gen tundras.
    Pearl-snap, Rex Kramer and Black Wolf like this.
  5. Apr 8, 2019 at 11:08 AM
    MIkeatthelake
    MIkeatthelake New Member
    2004 Tundra 4wd 6cyl
    Not much chance you will find any naysayers on here. We are all in for the duration.
  6. Apr 8, 2019 at 7:11 PM
  7. Apr 8, 2019 at 9:57 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Reading these posts makes me really miss my 2003 AC SR5!
  8. May 28, 2021 at 9:26 PM
    ToyotaJim
    ToyotaJim New Member
    Curious if the OP kept and repaired it.
    These trucks have a real cult following and are incredibly reliable long-term. At 200k miles, that truck is not even at half-life. For the price of a reliable replacement with similar abilities, I hope he just did the repairs. Kept maintained, these trucks could theoretically outlast their owners... Figure driving for truck duties, 10k miles per year, a 500k truck will last 50 years!
    bmf4069 and onesojourner like this.
  9. May 28, 2021 at 10:09 PM
    OP hasn’t been on in over 2 years
    bmf4069 likes this.
  10. May 29, 2021 at 5:40 AM
    Fred
    Hand Protectors
  11. May 29, 2021 at 6:03 AM
  12. May 29, 2021 at 6:05 AM
    Check the link in post #6. I said about the same thing, and here I am almost 3 years later.
