Chrome delete ... now what??!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tam37, May 27, 2021.
  1. May 27, 2021 at 11:42 PM
    Tam37
    Tam37 [OP] New Member
    Tam
    Victoria, BC
    2016 White Tundra Limited; double cab
    Trying to figure out before I do my own mods
    453A4D0B-231F-4BA4-ACDB-6057F6EDE265.jpg 3B6D63D1-1C4C-463E-BDD0-A2BDF9FB1D8F.jpg So I’ve taken off pretty much the entire front of my truck - in order to get the corner bumpers vinyl wrapped; which led to getting the grill surround and hood bulge color matched, also vinyl - fak it looks sick - they did an amazing job.
    Foreseeing some difficulties putting it back together - especially since there’s some obvious previous mods or damage - soooo...cuz I kinda feel like I never want to do this again, what else can I modify while I’m rebuilding (I am confident that I’ll eventually figure it out)
    1. Upgrade fog lights and harness to LED ?
    2. Replace rusty hardware and missing bolts? Is there a kit for 10-12mm?
    3.going to plasti dip grill but what one that has the whole “tundra” thru out
  2. May 28, 2021 at 12:56 AM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Yep, it's definitely a PITA taking all that stuff apart but I have done it several times and it gets easier. The last pic you are showing is the inner fender well plastic piece. That is really the most aggravating part in the process. Several of us on this forum have broken the clips that hold it in place with the bumper end cap.
    As far as foglights, buy once, cry once. Check out the Diode Dynamic amber Pro Max fogs. $300 but well worth it. Plug and play and they are running a 15% off sale right now. I personally wouldn't worry about rusty bolts, they are under truck anyway.
  3. May 28, 2021 at 6:10 AM
    2mchfun
    Lasfit switchback bulbs here on fogs, love them. I would add hardware cloth behind the grill while in there, keeps bugs from clogging up the condenser, more efficient to keep the truck cool inside the cab and the engine.
  4. May 28, 2021 at 6:18 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Supercharger. You already have the front off and you said you don't wanna do that again. So might as well knock it out now.
  5. May 28, 2021 at 6:48 AM
    RobertD
    Robert
    DFW, Texas
    None of the Toyota grilles say Tundra, the pro grilles say Toyota. To get a grille to say Tundra you want DB Customs, Envy, or another company I can't think of. Most are all metal and will run you $800+ for the grille insert, just as an FYI
    Tam37[OP] likes this.
  6. May 28, 2021 at 7:55 AM
    15whtrd
    15whtrd Mr. Blonde
    Honestly, the grille and bulge are super easy to install. I’ve had mine off quite a few times. I’ve gotten quite good at it LOL. Freaking way Legos with a couple bolts. But since you say there’s some previous modifications or damage, I have thought about painting the core support black so you don’t see it when you look through the grille. Just taping off everything but the part you can see through the grille and spraying it.
    Your forward fender liner looks like someone peeled it back to possibly get to the headlight bulb or some thing. Looks like you could just pop that back into place.
  7. May 28, 2021 at 10:51 PM
    Tam37
    Tam
    Victoria, BC
    Tell me more about the supercharger - can’t seem to find reputable source here on Vancouver island.
    I put it all back together; but taking it apart again would be just that much easier....
  8. May 28, 2021 at 10:56 PM
    Tam37
    Tam
    Victoria, BC
    Super easy now that I get it! Just wondering if I can fit 33” tires with my stock 20” wheels seeing the cutting that was previously done - the right hits much closer than the left....????!!
    15whtrd[QUOTED] likes this.
  9. May 28, 2021 at 11:22 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Looks nice..
    Ditch those chrome mirror caps to white color match caps.
    Fairly easy to replace.
    I can't see your door handles.
    If they are chrome, and I'm guessing they are since your mirror caps are, get some color matched..
    Even easier to replace.
    See pic above...
    And to top it off, 2019 black TRD Pro LED headlights with an @iHacker harness.
    From this...
    713A8B9C-FDF8-4EAE-B363-D750EB6E34E7_zps_3e7d109e0a0e4a486ee75090b2bd555c143653b4.jpg
    To this...
    WILLINH, TickNvM and 15whtrd like this.
  10. May 29, 2021 at 12:15 AM
    Tam37
    Tam
    Victoria, BC
    Oh, the mirror caps, door handles and emblems will be black...not color matched. By the end of the weekend....
    Had to hook my battery back up after 3 days of not being mobile , but all the chrome on the interior will be adios too..just didn’t realize I had to take apart every single thing to make that happen. Looks like I’ll have to remove all four inside door panels, steering column, dash and console. It’s really too bad I can’t appreciate chrome..or rather why Toyota insists on still using it #firstworldproblems
    TucsonTundra1794 likes this.
  11. May 29, 2021 at 12:23 AM
    Crboy2016
    Crboy2016 New Member
    2016 MGM TRD off-road
    https://www.paradigmautoworks.com/
    they have done a whipple supercharger on a tundra.
    Tam37[QUOTED][OP] likes this.
  12. May 29, 2021 at 3:23 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
  13. May 29, 2021 at 3:38 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    Are your door handles white? I have been thinking of color matching mine to white from black. If white I may be interested in buying your take offs if you sell them.
  14. May 29, 2021 at 5:06 AM
    Dr. Frankenstein
    Dr. Frankenstein New Member
    Keith
    2017 tundra
    lifted 6 inches, 37 inch tires
    Just my opinion but I like the chrome. Its your truck and you make it look the way you want.eyelids.jpg
  15. May 29, 2021 at 6:22 AM
    1UP
    1UP Truck Gang
    https://www.tundras.com/threads/trd-magnuson-vs-harrop-supercharger-comparison.85554/
    Lots of folks like Magnuson b/c it's basically the TRD supercharger that Toyota had as an option a few years back. See specifically post #7. Keith from Dirty Deeds can help navigate this and is a trusted vendor on the site. I (and tons of others) got my exhaust setup from him.
  16. May 29, 2021 at 8:41 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    AJT makes getting rid of the interior chrome easy, unless you want to paint it all.
    AJT DESIGN (ajtdesign-llc.com)
    He he offers complete kits..
    Chrome Delete Kit (2014+ Tundra) (ajtdesign-llc.com)
    The console top pops right off.
    I added a piece of black heat shrink on the shifter shift to cover that chrome.
    ld8c5d7f_a0aa12ff4829eab47dbca4761aa977268ce031ba.jpg corwv1ob_zpsdajt4wcz_48bca738373a7ef907e01b257e866ba3bb5bd93d.jpg dh6nc8v6_zpseu3zve2d_30de934e2fd825be0dca800af4d3b56ae1b09955.jpg
    Delete/replace climate control chrome rings.
    He also has rings for dual zone controls
    He used to make an awesome steering wheel emblem cover, but Toyota sent him a C&D to stop making them.
  17. May 30, 2021 at 10:03 AM
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    After seeing your post I ordered the chrome delete too! Ended up getting the shift knob too! Waiting on the climate knobs to arrive. Looks good!
  18. May 30, 2021 at 3:33 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Good thing is we all like different things, I hate it but you may hate the all blacked out look or at least not prefer it
    TunBrun likes this.
  19. May 30, 2021 at 3:57 PM
    5150bronco
    5150bronco New Member
    Justin
    Bay Area, Ca.
    Thanks! Nice stuff.
    I’m working on finding the black parts from Toyota. I’ll check his out.
  20. May 31, 2021 at 12:35 AM
    Tam37
    Tam
    Victoria, BC
    Yes! I have this but the limited version isn’t compatible with the climate control knobs. I’m it’s quite the process to get each piece of the dash out lol now I see they have interior door caps...gunna have you do another order
  21. May 31, 2021 at 12:50 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    You can get the kit for the dual climate knobs from AJT, I have it on mine.
  22. May 31, 2021 at 2:14 AM
    Tam37
    Tam
    Victoria, BC
    Oh what?! I kept mine dismantled tonight so I could spray paint them tomorrow because I was choked about the remaining chrome on the dials lol . I’ll have to reorder but took >month to ship to Canada ...thanks for the info, cuz I needed to spend more $ for free shipping of the door handle overlays lol
    Toe404[QUOTED] likes this.
  23. May 31, 2021 at 6:08 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    One thing I've noticed with some of the color matched front end work is that IMO it's not very color matched.
    I'm not sure if it's the cameras or just the end result.
    Toyota offers color matched I believe for some serious coin.
    I'm going blacked out front grill for my "Grey Ghost". Stuff should a be here by next week.
    Anyone notice the color match to be slightly off?
    ATV25 likes this.
  24. May 31, 2021 at 6:20 AM
    parkerbows
    Jack
    your not wrong, I didnt expect perfection as I painted mine. but definitely more noticeable in a picture than in person
  25. May 31, 2021 at 8:46 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    I believe AJT has it labeled as “3 knob” or “dual climate”
    Don’t forget about the push to start button also!!
  26. May 31, 2021 at 8:52 AM
    5150bronco
    Justin
    Bay Area, Ca.
    Is there another alternative to AJT people are using?
    Beside OEM black ABS stuff. Thanks!
  27. May 31, 2021 at 9:11 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    MESO customs is the other popular brand
  28. May 31, 2021 at 10:16 AM
    5150bronco
    Justin
    Bay Area, Ca.
    Thanks! I am familiar with Meso from getting stuff for my Tacoma. Barely any stuff for tundra and he has a third-generation Tacoma so stuffs going to start from there.
  29. May 31, 2021 at 10:54 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    From what I’ve seen, AJT seems to have the most to offer when it comes to chrome delete packages.
  30. May 31, 2021 at 10:57 AM
    5150bronco
    Justin
    Bay Area, Ca.
    Perfect! That’s what I found other than going through Toyota parts department. Even go to the Toyota parts department can be a little tricky. Seems that when you go through the options that some options will say it only comes in chrome but it may come in black but seems to default to chrome. So I realize that you can get the exact color or at least find out if the color exist by plugging in the Vin number of a truck that has the actual parts
