2021 Tundra SR5 Towing Horses
Discussion in 'Towing & Hauling' started by oliverceffylau, May 28, 2021.
  1. May 28, 2021 at 4:52 AM
    oliverceffylau
    oliverceffylau [OP] New Member
    I’ve read a few posts on here recently, and I’m looking for some general advice.
    I’m thinking of buying a new SR5 (not sure of the payload as I haven’t picked one out yet), but I’m curious if the general consensus is that it will be able to handle hauling 2 horses with a small/light bumper pull trailer?
    I know I need to crunch some numbers to be 100% sure, but I’m getting the feeling that some people would just recommend a full ton truck.
    I’m expecting to be towing on the weekends and will mainly be staying local (no regular cross country trips).
    I guess it comes down to whether the Tundra (in general) is suited to the task (maybe with some extras added i.e. WDH etc) or if I need to just consider a bigger truck.
    I appreciate all the help and advice!
  2. May 28, 2021 at 5:21 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It really depends on the length and weight of your trailer (included loaded tongue weight, if known). Can you post some more details about it?
  3. May 28, 2021 at 5:25 AM
    oliverceffylau
    I’m working off of the following assumptions:
    Trailer Dry Weight - 3000 lbs
    Horses Combined Weight - 3000 lbs
    The horses come in probably under that, but I figured it’s best to round up.
    I plan on driving the Tundra until it dies, but obviously I want to make sure that it can handle a fairly simple 2 horse set up.
  4. May 28, 2021 at 5:28 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I would think a Tundra should be able to tow ~6000 lbs as long as you can keep your tongue weight below your payload capacity (remembering that you have to also account for all passengers and gear in the truck in that number).
    SR5 should have a sightly higher payload that higher trims so it's probably your best bet within the Tundra family unless you can find (and live with) an SR.
  5. May 28, 2021 at 5:28 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    That would be right in the Tundra zone.
    Cpl_Punishment likes this.
  6. May 28, 2021 at 5:30 AM
    oliverceffylau
    Thanks to both of you. If I’m thinking about the longevity of the truck, would you also recommend air bags at some point?
  7. May 28, 2021 at 5:32 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I don't personally see the point of airbags but I know a lot of guys like and recommend them. I don't see the need if you're staying within the truck's capabilities. You will need a weight distribution hitch, though.
  8. May 28, 2021 at 5:37 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Airbags are great for eliminating the rear squat, but does nothing to alleviate the amount of weight on the rear axle. That would require a weight distributing hitch. But in all seriousness a dual axle two horse trailer, depending on how it is built, may not have massive tongue weight (with horses loaded) - in which case air bags would be fine. Best way is to check actual tongue weight and what the truck looks like, adjust from there. But nothing you describe so far concerns me with the Tundra.
  9. May 28, 2021 at 6:30 AM
    Fishhead
    Fishhead New Member
    I haul my wife’s horses all the time with zero issues.
    We have a Featherlite 9407 (3k pounds empty) and are within weight limits.
    oliverceffylau[OP] likes this.
  10. May 28, 2021 at 8:22 AM
    oliverceffylau
    Do you use a WDH and/or anything else when you tow the horses?
  11. May 28, 2021 at 10:26 AM
    Fishhead
    Fishhead New Member
    Not for our horse trailer or when I’m towing my tractor (similar weight). Just use the tow/haul button and use the S mode on the transmission that’s it.
    I do use a weight distribution hitch on our travel trailer but we take that all over the country.
  12. May 28, 2021 at 10:42 AM
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    That should really add some horsepower
