2017 tundra having a freakout
Discussion in '2.5 Gen Tundras (2014-2021)' started by BLACKBEARD, May 27, 2021.
  1. May 27, 2021 at 4:08 PM
    BLACKBEARD
    BLACKBEARD [OP] New Member
    Marvin
    2017 Tundra TRD Off Road
    So I hit my brights today and my truck lost the gauge cluster and powered down. Only to come right back online. Anyone ever experience this?
  2. May 27, 2021 at 4:12 PM
    BLACKBEARD
    Marvin
  3. May 27, 2021 at 4:19 PM
    Have you checked your battery cables?
    2mchfun likes this.
  4. May 27, 2021 at 4:20 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    But the engine did not lose power. Is that correct?
  5. May 27, 2021 at 4:29 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    ditto on check battery connections and good ground. Could also be the battery needs to be replaced, are you on the original battery? Battery on its last legs can do some funky thing with newer auto electronics. Just went through some odd ball stuff with the wifes suv, crazy things like that vid. New battery and all is good again.
    2mchfun likes this.
  6. May 27, 2021 at 5:02 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    As mentioned, check battery and cables. My wife's Highlander did pretty much the same thing when the battery went out. It sat for a while and had just enough juice to start and back out of the driveway, then went crazy like that. New battery and all is good.
    BTW, I'm impressed with your 16.3 MPG on the dash, unless that was just a fluke from the gauge cluster freakout, haha!
  7. May 27, 2021 at 6:06 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    That's scary as hell, I would freak out if that was me.
  8. May 27, 2021 at 6:57 PM
    BLACKBEARD
    Marvin
    So battery cables are solid. Very minimal corrosion. Test shows alternator may not being doing it’s job. But this happened over again where the key would do absolutely nothing. Seems like there could be a gremlin in good ol Blackbeard after all
  9. May 27, 2021 at 7:12 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Maybe check for signs of rodent damage. Read about mice causing HVAC issues but not this exactly.
  10. May 27, 2021 at 8:51 PM
    BLACKBEARD
    Marvin
    Engine goes into almost limp mode for a split second
  11. May 28, 2021 at 6:03 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Low voltage issue. Battery, alternator, or both. If your on the original battery I'd start by replacing that.
    BLACKBEARD[OP] likes this.
  12. May 28, 2021 at 9:49 AM
    BLACKBEARD
    Marvin
    luckily the Ford dealership I bought it at has a bumper to bumper warranty that comes with the truck. So for $100 bucks they are going to fix whatever is wrong with it.
    T-Rex266 likes this.
  13. May 28, 2021 at 10:05 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Check grounding points in the engine bay, 1 may be loose and will cause a complete power draw.
