How to remove upper control arm from spindle?
Discussion in '1st Gen Tundras (2000-2006)' started by potoghi, May 27, 2021.
  1. May 27, 2021 at 4:00 PM
    potoghi
    potoghi [OP] Tundra4Life
    Hawaii
    United States
    Yeah the hammer I had was pretty small. I picked up a 4 lb hammer a little while ago which hopefully does this trick
  2. May 27, 2021 at 4:10 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    NO:
    YES:
    Darkness, Lil Steve, bmf4069 and 4 others like this.
  3. May 27, 2021 at 4:21 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    It appears your ball and shaft have partially separated from your socket.
    See what I did there, that's comedy!
    Now you go...:rofl:
  4. May 27, 2021 at 4:34 PM
    Dr Doobie
    Talkeetna,Alaska
    In all seriousness, it looks like you might be hitting it in the wrong place.
    You should be hitting it on the point of the uca and that shock of the hammer blow will release the threaded/tapered shaft.
    Randydw and potoghi[OP] like this.
  5. May 27, 2021 at 4:40 PM
    potoghi
    Hawaii
    United States
    Ill be going from made in USA tools to made in taiwan tools :thumbsup:.
    Darkness likes this.
  6. May 27, 2021 at 4:43 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Can someone draw a picture of what to do? Red Arrows will score bonus Earth Social Credìtz.
  7. May 27, 2021 at 4:46 PM
    Dr Doobie
    Talkeetna,Alaska
    That DeWalt will do just fine.
    Hit that uca on the end with some force, and the stud will pop down and separate from steering knuckle.
    Should,pop out!
    potoghi[QUOTED][OP] likes this.
  8. May 27, 2021 at 4:57 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
  9. May 27, 2021 at 5:05 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I haven't read the thread all the way so this may already be suggested, or OP may have already had success with another tool. Here's what I used.
    I figured I'd only need to use this very rarely, and so far I have. Ball joint seperator from harbus freight. Have, and not need versus wait for auto parts store to open as third shift. :smash:
    Darkness, w666 and 15whtrd like this.
  10. May 27, 2021 at 5:17 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    This^^^
    Flip the pickle fork, pound it in so it's applying pressure. Then screw the nut on the top of the stud so the nut is just barely above the threads, and hit the nut vertically from the top with the 4lb sledge. In the other photo it looks like you've been beating the ball joint portion horizontally from the side. Side force won't get you anywhere. The force has to be vertical.
  11. May 27, 2021 at 5:44 PM
    Dr Doobie
    Talkeetna,Alaska
    Side force in the correct place on the uca with bfh and it'll release. I've done dozens of them
    Never hit the stud!
    Geo4x4 and potoghi[OP] like this.
  12. May 27, 2021 at 6:08 PM
    potoghi
    Hawaii
    United States
    The stud looks like a really tempting place to hit ngl
    wandering_boy likes this.
  13. May 27, 2021 at 6:12 PM
    Dr Doobie
    Talkeetna,Alaska
    If It mushrooms or swells up from hitting the stud it will be more work for you.
  14. May 27, 2021 at 6:27 PM
    Dr Doobie
    Talkeetna,Alaska
    Is everything hanging freely? Jack stands under frame, or front cross member, or both?
    If the control arms and everything have pressure on them from supporting the truck, it will fight you
  15. May 27, 2021 at 6:39 PM
    I might be dethroned as head mangler.
  16. May 27, 2021 at 6:47 PM
    potoghi
    Hawaii
    United States
    I put my jackstands under the front cross member. Should I support it elsewhere? or is that a good spot to support the truck.
  17. May 27, 2021 at 6:51 PM
    potoghi
    Hawaii
    United States
    The rightful throne shall soon be mines.
    MS22, FirstGenVol[QUOTED] and 15whtrd like this.
  18. May 27, 2021 at 6:56 PM
    Hit This:
    With this:
    And make sure the suspension is at full droop unsupported so the spring is pushing the LCA and spindle down away from the UCA.
  19. May 27, 2021 at 7:00 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    You ain’t holdin’ yer mouth right
    As my grandpappy used to say
  20. May 27, 2021 at 7:20 PM
    #50
    Dr Doobie
    Talkeetna,Alaska
    Exactly, your hired!
  21. May 27, 2021 at 7:29 PM
    #51
    Dr Doobie
    Talkeetna,Alaska
    Yup,good spot as long as it is stable and safe. Go ahead and put one under that frame rail for added protection and follow the instructions that @KNABORES posted and it should separate.
  22. May 27, 2021 at 7:34 PM
    #52
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Lots of great advice here as usual. Since you're having such a tough time on this one, and I assume you plan on doing both, maybe you should add a little heat to the equation as some here have mentioned. You can buy a Map Gas kit for short money and it might really ease your pain. Heat the area circled while still using the fork and the 4lb. hammer. Good luck and keep us updated. :thumbsup:
    https://www.homedepot.com/p/Bernzomatic-Trigger-Start-Torch-Kit-TS4000KC/203368730
    potoghi[OP] likes this.
  23. May 27, 2021 at 8:41 PM
    #53
    You will be as soon as I change out my steering rack.
  24. May 28, 2021 at 2:45 AM
    #54
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Yep, that's it! Be sure to use plenty of PB Blaster applied under the castle nut. A couple of smart smacks with the 4 lb should do the job.
  25. May 28, 2021 at 4:59 AM
    #55
  26. May 28, 2021 at 5:46 AM
    #56
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I am literally sitting here refreshing this page waiting for @potoghi to give us an update...:popcorn::pccoffee:
    #Nailbiter...
  27. May 28, 2021 at 6:16 AM
    #57
    potoghi
    Hawaii
    United States
    I just picked rented some tools from autozone. It’s coming off today :mad:. I also got a pulley puller as a last resort effort.
  28. May 28, 2021 at 6:44 AM
    #58
    Fred
    Hand Protectors
    Getter dun Patty Cakes.
    N84434 likes this.
  29. May 28, 2021 at 7:04 AM
    #59
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
  30. May 28, 2021 at 7:08 AM
    #60
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
