  1. May 27, 2021 at 8:28 AM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    Ya, sure... the "wife's" purchases.... No boxes full of suspension or wheels or tie-downs.... Aha. lol
    1lowlife[QUOTED] likes this.
  2. May 27, 2021 at 8:28 AM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    Looks good, put one of those 60” tailgate light bars between. I have the tailgate light bar and it was a simple install.
  3. May 27, 2021 at 8:32 AM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    I have Pro-Loft 6 ton jacks just because, might be overkill, but I want to be safe then sorry.
    CappyKD[QUOTED] and jpod like this.
  4. May 27, 2021 at 8:51 AM
    CappyKD
    CappyKD Older, grayer member.
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    I'm with you on that.
  5. May 27, 2021 at 8:56 AM
    I just did my initial wax on my truck with the Meguirs Ultimate liquid wax. How do you like the Beadmaker?
  6. May 27, 2021 at 9:13 AM
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    Finished up the right fender liner & right front parking sensor after the front grille/bumper chrome delete last weekend.
    Good news… Front parking sensor replacement didn’t cause any errors after being disconnected for several days. I bought OEM and damn that little part is pricey!
    PSA, if you get new bumpers you may have to get new “liner extension seals” for the fender liner. In the pic you can see the old vs new where the the screws go in and the black rubbing when I initially tried to manhandle the old clip on :itllbuffout:
    BlueRibbon4x4 likes this.
  7. May 27, 2021 at 9:28 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Those are basically the jack stands I have and will be using this weekend to install my lift. I've used them once before. They seemed stable enough, didn't seem to have any issues.
    I'm concerned about death as well. But (I hate using that word when talking safety), if only the front of the truck is on the two stands, I'm not sure how much weight that is and I doubt I'll be crawling under the truck...just taking the tires off and installing the lift. Anyone feel this is a bad idea? Maybe I spring and just go have the shop put them on.
  8. May 27, 2021 at 11:35 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
  9. May 27, 2021 at 11:38 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Nice ! ..sent pm
    Good job ! ..both handles look good, I went with AJT to avoid taking door apart :)
    NICE ! Your 16 looks like it just rolled off the line ... beautiful !
  10. May 27, 2021 at 1:09 PM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    I like yours better than what I ended up doing.
    Bonus points for the bottle opener!!
  11. May 27, 2021 at 1:20 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Maybe we need to start a tailgate bottle opener club...
    iofr5mzd_zpswujuvflw_6782c9d9d01eb3e8d1deb0a6cfbaa9f4a90e1cd4.jpgir6kbp88_zpsgqpkncc1_8c1db8bd32ef3d735c5ab429389845bf198323d6.jpg f6jysai5_zpskwknrb5g_3d78080f03a281cd1c021152ddadac8aa8709e1f.jpg
    Wallygator, GAknight, Smarty and 9 others like this.
  12. May 27, 2021 at 2:04 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    If I need extra height, is it a bad idea to set the jack stands on a couple of 2 x 4's?
  13. May 27, 2021 at 2:23 PM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Exactly what I do anytime a wheel comes off I lay it under the frame just in case. I had a scissor jack fail on me when changing a flat several years ago slamming the rotor in the pavement. I learned my lesson that day.
  14. May 27, 2021 at 2:39 PM
    CappyKD
    Kirk
    Yes IMO. Buy bigger jack stands. The 4 Ton at Harbor freight with the locking pin are quite a bit taller than the lesser weight capacity ones. They are also wider to better support the weight.
    GELCW likes this.
  15. May 27, 2021 at 2:45 PM
    RobertD
    Robert
    DFW, Texas
    Can you share a link? I'm only seeing 3 ton jack stands on HarborFreight website.
  16. May 27, 2021 at 2:49 PM
    CappyKD
    Kirk
    RobertD[QUOTED] likes this.
  17. May 27, 2021 at 3:39 PM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    I was looking at this website. You must choose between short or long depth. Can anyone explain what this means? And I'm trying to understand the difference between all these USB charger standards - anyone know a good site that explains this (quick charge, 2.1, 2.4, etc, etc). I'd like to put one of these in but I'm not sure which to get. Thanks.
    MatD13 likes this.
  18. May 27, 2021 at 3:55 PM
    GaTundra79
    GaTundra79 New Member
    White 2021 SR5 4x4
    I'm planning on a tonneau cover, nice find on these. I'll definitely be adding them when I find my cover.
  19. May 27, 2021 at 4:30 PM
    Jalzate44
    Jalzate44 New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
    Got my custom CAT cover installed today.
  20. May 27, 2021 at 4:36 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Rolled the Softopper. Nothing significant, but I really like the way it looks with the sides up.
  21. May 27, 2021 at 4:55 PM
    RobertD
    Robert
    DFW, Texas
    Can they still cut the Cat thru that large open hole?
    I hope not. Looks good and is unique :thumbsup:
  22. May 27, 2021 at 5:27 PM
    Nice. Does he do aluminum and steel? Can you PM me his number? I still haven't received a reply from him. Thanks.
  23. May 27, 2021 at 5:59 PM
    TorinWallace
    TorinWallace Yota Addict
    2020 TRD Pro, DoubleCab, Army Green.
    CB Shim + Shackles | 305/70r18 KO2's | 18" Method NV's | Firestone Airbags | Tow Mirrors | Marlon Sleddeck | Spyder smoked taillights.
    Installed the Switch Pros switch panel with the SDHQ mount this evening, gonna wire everything up tomorrow.
  24. May 27, 2021 at 6:39 PM
    Jpd0144
    Jpd0144 New Member
    Jeff
    Louisiana
    21 CM Sport 4x4
    Installed a Undercover Flex after work today … took about 2 beers time. :cheers:
    Pretty straight forward. I did go over all of the factory screws for tightness. UPS had done a number on the box. Will likely recheck periodically after seeing some reviews. I’d imagine these get a good deal of bumpity bump on my Parish roads.
    Hope everyone has a great upcoming Memorial Day weekend! :oldglory:
  25. May 27, 2021 at 7:17 PM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Forgot to post this the other day. Reflective black vinyl flagC12013DA-1574-4EBF-ACC9-BC319989D4B1.jpgAnd installed a set of brand new durobumps I got off a guy for $100.
  26. May 27, 2021 at 7:23 PM
    daw5spd
    daw5spd New Member
    Dave
    Eastern Oregon (Greater Idaho)
    2019 Cement Off Road DC
    Undercover SE tonneau TRD Rear Sway Bar AJT trim pieces Console wireless charger Drivers side grab handle Meso lights
    Cinder blocks will collapse under a load. Please don't use them to support anything.
  27. May 27, 2021 at 10:24 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Put this on today, I like it.
    Wallygator, WILLINH, Jpd0144 and 5 others like this.
  28. May 27, 2021 at 10:27 PM
    French Avocado
    Utah / Wyo
    Link please?
  29. May 28, 2021 at 5:07 AM
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    Added the Toyota power tailgate lock and Rough Country's tri-fold hard cover last night. Worst part of the whole thing was the floorboard styrofoam on the passenger side. Not sure how those fasteners secure but I relieved it enough to get to the grommet.
    Wallygator, TNTundra16 and romad86 like this.
  30. May 28, 2021 at 5:47 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
