Need new tires….
Discussion in 'Wheels & Tires' started by Kantoosion, May 27, 2021.
  1. May 27, 2021 at 11:26 AM
    Kantoosion
    Kantoosion [OP] New Member
    J
    SD
    Inferno Crewmax
    I need new tires really bad on my 2016 4x4 trd off road. So bad that I can’t wait for my 3inch lift to be done. (Waiting on parts). What’s a good size to go with on stock suspension that will be fine on a 3/1 lift. I don’t want to buy tires twice. Or am I SOL?Thanks in advance!
  2. May 27, 2021 at 11:31 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome
  3. May 27, 2021 at 11:35 AM
    Kantoosion
    J
    SD
    Inferno Crewmax
    Thank you! My first post!
  4. May 27, 2021 at 11:37 AM
    RanchTracker98
    RanchTracker98 New Member
    2018 Cement TRD offroad
    275/70 r18 will probably suit you well
    Kantoosion[OP], Barrett50 and jdg1982 like this.
  5. May 27, 2021 at 11:43 AM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    THIS!
    In the meantime, if your lift is going in soon, NTB has a house brand called Crosswinds that are cheap. May hold you over for not too much $$$
  6. May 27, 2021 at 11:46 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I have a 2016 as well. 275/70-18 and 285/70-18 fit on stock truck with stock wheels, no issues. 275/70 has a ton of tire choices and are not super expensive. 285/70 has very few tire choices and cost more $.
    If you look around on this site there are plenty of pictures of trucks with 2-2.5 inch lift in front running 275/70s.
    Barrett50 likes this.
  7. May 27, 2021 at 11:50 AM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    I would push for 295/70/18 if lift is going on soon. Will just need some trimming/massaging in the fenders.
    toyofan87 likes this.
  8. May 27, 2021 at 1:32 PM
    Blue Thunder
    Washington
    What about getting some cheap take-offs from Craigs List to get you thru? Get them cheap and you should be able to recover most the $ by reselling them once your lift is complete.
    I wouldn’t want to compromise on the tires I want after getting a lift…
  9. May 27, 2021 at 1:35 PM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    Coopers
