The Lightest AT tire?
Discussion in 'Wheels & Tires' started by TundraLLama, Apr 11, 2021.
  1. Apr 11, 2021 at 9:17 AM
    TundraLLama
    TundraLLama [OP] New Member
    Massachusetts
    2015 Black Platinum Tundra
    Color matched mirror caps and door handles TRD dual exhaust TRD shift knob TRD Pro FOX shocks Spray in LINEX bed liner TRD 18” wheels FOX TRD Pro suspension Michelin 275/65r18 LTX AT2 Soft top Roll up bed cover Go Rhino RB10 running boards TRD Pro LED blackout headlights TRD Pro LED blackout fog lights TRD Pro grille AJT DESIGN blackout vent/shift/cup holder Wireless charging tray Remote starter Upgraded alpine speakers, amp, dual sub box. Rear underseat storage.
    I currently have falken wildpeaks AT3 275/70/r18 E rated on my truck. I was just wondering if anyone knows what the lightest all-terrain tires along with decent performance? What is the benefit of an E rated tire? Is it needed on the tundra? Thanks
  2. Apr 11, 2021 at 10:10 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    E load is not needed on the Tundra, stockers are standard load. The issue- if you want larger than stock tires you are stuck with E load (275/70-18 for example).
    I just installed same tires (wildpeak) as you, they are 61lbs in 275/70-18 size. I came from Cooper XLTs, those were 54 or 55lbs. I returned them because they were defective and would not balance.
    Anyway, you will be able to find AT tires in the 55lb range in size 275/70-18. That is the lightest I have seen in that size. If that is still too heavy consider going back to 275/65-18 and you will find a ton of tires available, different load ratings available and they are much lighter, in the 45-50lb range depending on what you want/get.
    Tirerack or discount tire are great sizes to browse tires by size and the listings will give the weight of each tire, load ratings available, etc.
    Saltyhero13 and TundraLLama[OP] like this.
  3. Apr 11, 2021 at 10:30 AM
    BluegrassPro
    BluegrassPro New Member
    Jeff
    2021 TRD Pro
    Toyo at 3 in that size is under 50 pounds. I believe 49 to Be exact
    davescarp likes this.
  4. Apr 11, 2021 at 10:41 AM
    TundraLLama
    Massachusetts
    Thank you! Great info. I love the tires. But my MPG is in the mid 12s now. I’m not sure if I’d see a big bump if I went to the ridge grapplers. I need something decent in the snow as well.
  5. Apr 11, 2021 at 10:49 AM
    BluegrassPro
    Jeff
    2021 TRD Pro
    Best I’ve found.
  6. Apr 11, 2021 at 10:50 AM
    frichco228
    Frank
    Virginia
    That is about expected MPG with 275/70-18s AT tires, regardless of brand. I have seen as low as 12, usually am in the 12-13 range but I do a lot of city/short trips. It is better on highway only by about 2-3 MPG. Basically you lose 1.5-2mpg going with the larger than stock tire size. One other thing to mention- letting the truck warm up in winter, cool down in summer before driving really hurts the average MPG. The idling kills MPG average. If mileage is a concern, stick with 275/65s in standard load and you will see a few MPG improvement.
  7. Apr 11, 2021 at 11:10 AM
    NWPirate
    Zach
    WA
    Really happy with the Goodyear UltraTerrain, 55lbs on the 275/70. Great traction in all 4 seasons. I prefer E rated for towing/off-road.
  8. Apr 11, 2021 at 8:49 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I've had the Cooper AT3 XLTs for about 6K miles now and my MPG actually went up from 13ish to 14.3 overall. I drive like a grandpa now, and its like a game to see if I can get the overall average to go up instead of down. Been hovering at 14.3 for about a month now.
    I think driving habits have as much or more to do with gas mileage than tire size. Sure, if you go from stock to 37" mudders your MPG will obviously suffer, but going up one size doesn't have to equal MPG loss.
    TundraLLama[OP] and GODZILLA like this.
  9. Apr 21, 2021 at 4:43 PM
    TundraLLama
    Massachusetts
    I just read somewhere that the Toyo AT3 275/70r18 weighs 52 pounds. Can anyone confirm??
  10. Apr 21, 2021 at 5:36 PM
    Black
    2014 Tundra Limited CrewMax
    Tire Rack says 53.
    The Firestone Destination X/T is 49 lbs.
  11. Apr 22, 2021 at 8:49 AM
    frichco228
    Frank
    Virginia
    DT is showing 50lbs
  12. May 11, 2021 at 7:48 PM
    farm&forest
    farm&forest New Member
    2021 Tundra SR5 TRD-Off Road Double Cab
    Dobinsons 2-3" Complete Suspension Kit w/ medium Dobs Leafs, Decked Drawer System, Leitner Forged ACS Rack, Line-Xed bed and Line-Xed Tyger Blade Steps, Wet Okole seat covers, VLED lighting, soon to add Swith Pro and auxillary lights
    After a recent flat at odo mile 1500, I am skeptical of the oem SL Michelins for my applications...thinking of going to a higher ply AT staying in stock size 275/65r18...
    My local tire guy really likes the Falken Wildpeak AT3w (10ply, E), but I'm not sure I want to go from the oem 40lb to the 60lbs per tire. Is there a happy middle ground somewhere for a truck that does a little bit of everything in moderation?
  13. May 11, 2021 at 10:39 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Michelin LT rated tires are only 51lb. Much lighter than 60
    Saltyhero13 likes this.
  14. May 12, 2021 at 6:58 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    Bridgestone Dueler A/T Revo 3 in 275/70r18 is showing 50lbs.
    Firestone Destination X/T in 275/70r18 is showing 50lbs.
    Toyo Open Country A/T III in 275/70r18 is showing 52lbs.
    Nitto Terra Grappler G2 in 275/70r18 is showing 52.3lbs.
    Source: tiresize.com
  15. May 12, 2021 at 8:23 AM
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    I am running the Bridgestone Revo3 Load Range E ... I have been using these for 20 years, great tires in the E range, not too heavy.
    I need the E tires because I drive on logging roads rocked with sharp crushed basalt, which easily puncture regular tires.
  16. May 12, 2021 at 9:20 AM
    Greyota
    Greyota New Member
    2020 TRD Pro CM
    295/70R18 Falken Wildpeaks Toytec Shackles Retrax PRO XR Amp Research PowerSteps Valhalla Cat Plates
    I just installed some General Grabber ATX 275/70R18 STANDARD LOAD. These are brand new, and Discount Tire had to call General to get them since they aren't listed on their site yet.
    They are on Tire Rack's site though and that says 44 lbs. I do not need E Load tires, so this is great for what I do.
    dpast88, Noeyes, Burkley and 5 others like this.
  17. May 12, 2021 at 11:16 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    After towing my trailer (4k lbs, another 500lbs in the truck bed of gear) with both OE tires and E rated tires, i have come to the conclusion that on pavement the SL tire is plenty stiff enough with max air pressure. With 50lbs in my rears, it feels fine. Maybe heavier trailers will affect it more.
    now offroad I’m definitely more cautious with the oe tires if ripping it on a rock
  18. May 12, 2021 at 11:33 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    I was literally just looking into these this morning. How do they ride? How is the MPG compared to stock? I really want to upgrade from my stock 275/65 but trying to avoid taking a big hit on MPG.
  19. May 12, 2021 at 12:00 PM
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    Not rocket science, but you can tell a lot about tire mpg just from tread design. Tires with continuous linear grooves around the full circumference generally have the best mpg and are quiet. Blocky Off-road tires with no linear circumferential groove get poor mpg and are loud, but grip well on loose materials. Mixed-use all-terrain tires that many truck users prefer can fall anywhere in between. The Bridgestone Revo3 has a continuous linear groove around the circumference (road-like with some all-terrain benefits), the Cooper AT3 has a nearly linear groove, the Falken A/T3W is less linear (zig zag groove), and the Grabber has zero linear (very blocky, off-road design). I understand that folks want their rigs to look superbad, but no one’s gonna see the tread when it’s rolling ...
  20. May 12, 2021 at 1:06 PM
    farm&forest
    What is the ~ max psi to consider for running SL tires?
  21. May 13, 2021 at 5:48 AM
    Greyota
    Greyota New Member
    2020 TRD Pro CM
    Well I've only had them on for 5 days, and a couple hundred miles so my experience is very limited. My observations so far:
    1. Ride - I really like the ride so far. Ride comfort is subjective as some prefer soft vs. firm, but I can say that these take the bumps better than the stock Michelin's and don't feel the least bit "squishy" for being a SL vs. E load.
    2. Noise - The miles I have driven so far have been a lot of interstate (75-85 miles per hour) and road noise is minimal. Yes, there is more noise there than the Michelin's, but on a scale of 1-10 the Michelin's are a 1 and I might put these at a 2 or 3 so still very quiet.
    3. Balance - 1 of the 5 took 6 ounces, the rest took about 2. That 6 oz one seems like a lot, and I am experiencing some shake above 70 so I'm going back on Saturday for a re-balance. Under 70 MPH they're very smooth.
    4. Steering input - Doesn't feel much different than stock to me
    5. MPG - Too early to tell since I only have a couple hundred miles so far, but I am down about 1 MPG so far. Certainly just going up 1 size accounts for about 0.5 MPG when the computer calculates MPG based on the larger size, the rest could be a variety of things.
    6. Speedometer - I used to be a few MPH off at interstate speeds, now it's right on.
    7. Aesthetics - I considered all the other sizes, for months, before picking this one and I can honestly say they look better in person than what the pictures can convey and I'm happy with the choice and don't feel like they're too small.
    GT87[QUOTED] likes this.
  22. May 13, 2021 at 5:55 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    There's also a standard load 295/70R18...the Nitto Terra Grappler G2.
    34.29" diameter and only 51lbs.
    Downytide likes this.
  23. May 14, 2021 at 6:54 PM
    AWilliams
    AWilliams New Member
    The house brand Discount Tire sells is Pathfinder and is light. 285 70 17 are 43#. My Nitto G2 are 285 70 17 P rated are 46#
  24. May 18, 2021 at 9:05 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    This one has caught my interest as well, they have been great on my wife's 4runner so been debating to downsize once these are worn.
  25. May 27, 2021 at 5:43 AM
    Greyota
    Greyota New Member
    2020 TRD Pro CM
    I feel like I should give an update on these. Discount Tire was unable to get these to balance correctly after multiple tries, so I ended up replacing them with Falken Wildpeaks. A little early to tell yet on the Falkens, but the initial impression is that they are more smooth than the Generals. The guys at my DT didn't have a lot of positive feedback from the Generals either, and said they had previous complaints about vibrations.
  26. May 27, 2021 at 5:46 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    I'm running 35's and I tried to get something with a D load range, they do exist but are rarely made. There is a KO2 with a D load range I'm determined to get to replace my E load range someday haha
  27. May 27, 2021 at 5:48 AM
    GaTundra79
    GaTundra79 New Member
    White 2021 SR5 4x4
    I have a buddy who has had issues with multiple sets from discount tire. Is there a possibility that they buy a lower grade of tire? Are tires even graded like that? He had a set of BFG KO2s, which can have issues anyway, and a set of duratracs. Both had issues from DT. He ended up getting a replacement set of KO2s, and the duratrac issue is still ongoing.
