Best Gen-ECGS bushing tool
Discussion in '1st Gen Tundras (2000-2006)' started by FrenchToasty, Jan 4, 2020.
  1. May 25, 2021 at 5:09 PM
    #121
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    :rofl: That’s awesome. Makes me sad I didn’t leave my mark on the seal driver haha
  2. May 25, 2021 at 5:11 PM
    #122
    FrenchToasty [OP] The Desert rat, SSEM #5/25, 6 lug enthusiast
    Might be a new requirement! “leave your mark”
    Darkness, bmf4069, des2mtn and 2 others like this.
  3. May 25, 2021 at 5:12 PM
    #123
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I like it. Gives it some character
  4. May 25, 2021 at 6:15 PM
    #124
    Man that's a great idea. So disappointed I didn't sign it! I hope someome draws something immature on it next time.
    Darkness, bmf4069, CodyP and 2 others like this.
  5. May 25, 2021 at 9:13 PM
    #125
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Might need a quick PU coating to keep the signatures on there cause I feel they will rub off with the next use.
  6. May 26, 2021 at 4:58 AM
    #126
    Oh I'm sure I'll need to use it eventually. I'll put this on it.
  7. May 26, 2021 at 9:41 AM
    #127
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Haha. But it’s gonna be hard to find a corner on that cylindrical item.
  8. May 26, 2021 at 9:43 AM
    #128
    My geometry skills have failed me.
  9. Jun 7, 2021 at 10:19 AM
    #129
    MurphysLaw08
    MurphysLaw08 New Member
    2008 tundra double cab base longbed
    None
    Has anyone experienced this bushing going bad at stock height???
    I've got a some growling going on along with a small shake at the steering wheel at highway speeds. Truck has been stock height it's whole life
    At 230k now...
    Despite all that i still believe the bearing is bad. I'll get underneath my truck today and shake that axle around to see how bad the play is.
    Is there anything else I can do to diagnose the bushing as the problem?
    ****Edit putting it in 4 hi on the way home to see if the vibration stops
    FrenchToasty[OP] and JustJake like this.
  10. Jun 12, 2021 at 6:10 PM
    #130
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I did the clamshell bushing conversion today. Must've been my lucky day... everything went so smooooove. I was able to insert and center the ECGS removal tool on the first try and the needle bearing came out like butta. I tapped on the clamshell with a brass hammer to get it started/centered and then the ECGS insertion tool worked perfectly to fully seat it. Also installed a new OEM seal to finish it off. I wasn't having any issues with the needle bearing and it looked fine but I know it would have eventually worn with my lift. Glad I did it, peace of mind. :thumbsup:
  11. Oct 9, 2021 at 6:16 PM
    #131
    SUBSEVEN
    SUBSEVEN New Member
    Waterford, NY
    2002 AC TRD Limited
    Will do and thanks man. So glad I found this thread.
  12. Oct 9, 2021 at 11:25 PM
    #132
    I don't know why we haven't before , but can we pin this? @Bob sorry to tag you Bob but TJs and trexs names aren't tagging.
    Tundra2 likes this.
  13. Oct 9, 2021 at 11:27 PM
    #133
    @ColoradoTJ can we pin this? Sorry for the tag Bob, tjs tag was a new member pic.
    Bob and FrenchToasty[OP] like this.
  14. Oct 12, 2021 at 9:43 PM
    #134
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    So this forum is dangerous I'm was doing a simple cv boot replacement and I'm now I'm redoing the whole front end and suspension. Snice I'm in there I might as well does the bushing mod. Is the tool still available for rent or do I have to buy it?
    CodyP, KNABORES and des2mtn like this.
  15. Oct 13, 2021 at 4:49 AM
    #135
    SUBSEVEN
    SUBSEVEN New Member
    Waterford, NY
    2002 AC TRD Limited
    I'm getting ready to do mine any day. Parts should be here today and the tools I think are on the way. Can't wait until it's just done. Thanks again FrenchToasty!
    FrenchToasty[OP] likes this.
  16. Oct 13, 2021 at 5:04 AM
    #136
    Your next on the list, so if your interested, get your parts ordered and the tool should be available in a few weeks
    Tundra2 likes this.
  17. Oct 13, 2021 at 6:14 AM
    #137
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I never thought I'd need this thread, but one day!
  18. Oct 13, 2021 at 8:54 AM
    #138
    Dave8699
    Dave8699 Trackrat
    NJ
    Does anyone have a tool for sale that I can buy? If so I'll buy it and send it out also, better to have 2 set of tools to send out.
    Or has anyone made one that I can make also? Doesn't look like anything special.
  19. Oct 13, 2021 at 11:49 AM
    #139
    Dave8699
    Dave8699 Trackrat
    NJ
    @FrenchToasty do you have the measurements of the plate that pulls the bearing out? I figured I'm going to make one I'm not paying $50 for a tool and I don't have to much patience to wait for the loner tool.
  20. Oct 13, 2021 at 12:02 PM
    #140
    Let me look thru an old PM and see.
    Do you already have the bushing on hand?
  21. Oct 13, 2021 at 12:07 PM
    #141
    Dave8699
    Dave8699 Trackrat
    NJ
    Ordering as we speak but have some conflict in part numbers for seal.
    I see both part numbers ate different which is the correct number. Also are the seals on both sides the same?
  22. Oct 13, 2021 at 12:12 PM
    #142
    The seals are definitely side specific. I’ll try to look for that PN as well, it might be here in the thread
  23. Oct 13, 2021 at 12:16 PM
    #143
  24. Oct 13, 2021 at 12:24 PM
    #144
    Dave8699
    Dave8699 Trackrat
    NJ
  25. Oct 13, 2021 at 12:31 PM
    #145
    My bad, post 79 @KNABORES has the right part number, you do as well but it looks like you mixed up sides/part numbers
  26. Oct 13, 2021 at 12:37 PM
    #146
    Dave8699
    Dave8699 Trackrat
    NJ
    I'm I missing something ?
    47013 Right side/ passenger
    47027 Left side /driver
  27. Oct 13, 2021 at 12:46 PM
    #147
    East coast GS also sells the seals, but
    I’m pretty sure it’s the 13
    damnit I don’t even know now, looking back I see a member with the 27. I’d call the dealer to double check, sorry for confusing you more!!
  28. Oct 13, 2021 at 1:37 PM
    #148
    Dave8699
    Dave8699 Trackrat
    NJ
    So here is the part numbers for left and right if anyone needs them.
    @FrenchToasty when yiu get a chance if you can measure the size of the plate ill would appreciate it.
  29. Oct 13, 2021 at 1:47 PM
    #149
  30. Oct 13, 2021 at 2:24 PM
    #150
    Dave8699
    Dave8699 Trackrat
    NJ
    Thank you I really didn't need that many measurements but they help. Going to see if I can make some. I'll keep you posted when I get my parts incase you have the tool available.
