New to forum need advice on step bars
Discussion in '2.5 Gen Tundras (2014-2021)' started by rockledgetundra, Jan 15, 2020.
  1. Feb 29, 2020 at 8:40 AM
    degs
    degs New Member
    2020 MGM Crewmax
    I snagged a pair for $170 from Amazon...
    Hammerdog likes this.
  2. May 16, 2021 at 6:34 PM
    Tundra-dude
    Tundra-dude New Member
    2020 Tundra SR5 CrewMax
    Can you tell me how the drop compared to these two options? I’ve been told the side steps have a greater drop than running board. Supposedly easier step with the Podiums. I’m looking at these same two options. Also, on the Rhino what finish did you end up getting? Thanks for the help.
  3. May 16, 2021 at 7:12 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Two words....Predator Steps..
    nuff said
  4. May 16, 2021 at 9:15 PM
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
    6B4D143C-D945-478E-BD65-71C79082DE7A.jpg These are the Iron Cross Patriots been running these for over a year holding up good bought them direct from Iron Cross and saved money. I personally don’t care for running boards but it makes it easier for people to get into the truck and saves on the door dings.
  5. May 17, 2021 at 5:01 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    I second that vote, beefy, well made, easy wide steps into cab... Looks killer!0424211438.jpg
    Nowhereman likes this.
  6. May 17, 2021 at 7:28 PM
    Albino Predator
    Albino Predator New Member
    2020 White Tundra
    Had the OE predator step bars, but went with Go rhino RB20's.20210514_164702.jpg 20210515_103859.jpg
    Kratos and TNTundra16 like this.
  7. May 17, 2021 at 8:08 PM
    Tzvia
    Tzvia Just an old woman in a pickup truck.
    Los Angeles County
    2019 5.7L Limited TRD Off Road 4x4
    Just a Bed Rug and Snugtop XTRA Vision
    My mother is all of 4'11" on a good day LOL and 92, and I had been using a little folding single step that I kept behind the front seat for her to use. While my truck came with the 'predator' steps, one off road excursion took care of those :oops: (they have no place on a 4x4 IMO) but she liked them. What to do? I compromised with Go Rhino RB20's in the standard finish. They look great, and she can get in fine. They are wide enough for her to be able to step onto them with confidence, grabbing the handle as she gets in (and I stand behind her just in case). My truck is the standard TRD OR, not lifted, but with her stature and age, it was impossible for her to get in without some kind of step or platform. If they were like 2 inches lower they would be perfect for her, but wouldn't last long when I go on vacation (if I ever get one...). And I can always break out the single step, which I keep handy.
    GELCW likes this.
  8. May 17, 2021 at 8:31 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    30B74405-8E85-4E0E-AA47-2B03BDC623C3.jpg Tyger blades.
  9. May 18, 2021 at 9:19 AM
    Heisenberg
    Heisenberg New Member
    2020 Tundra TRD Sport
    Westin HDX
  10. May 24, 2021 at 5:52 AM
    RichLec
    RichLec New Member
    Does anyone know where I would be able to buy just the passenger side OE predator step bar? Wife mangled one over the winter and I am looking to replace it.
  11. May 24, 2021 at 7:12 AM
    MICKs18yota
    Ohio
    2018 Tundra SR
    On OE you can go through a dealer and you should be able to buy exactly what you need however I’m afraid it will probably be as much as a complete set I would check with Sparks and see what they can get you.
  12. May 24, 2021 at 7:18 AM
    Rippyro
    Rippyro New Member
    2014 Tundra 1794 - Sunset Mica Bronze
    I've got the stock plastic ones on mine that work great, but I'm looking to upgrade to metal. I recommend something that doesn't have the small individual steps personally. They look good, but just aren't as user friendly/functional as a flat step IMO.
    I'm either upgrading to the gorhino rb20 or the tyger blades.
  13. May 24, 2021 at 7:55 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    I like my Nfab side steps.
  14. May 24, 2021 at 10:50 AM
    2mchfun
    Many for sale in used pairs on marketplace by people changing to sliders. You can also likely get just in one from salvage truck, might need to look around for awhile. Another idea, check with some body shops in your area. Im sure someone will be or has been t boned, that leaves the body shop either knowing how to buy just one or else having an extra.
    RichLec[QUOTED] likes this.
  15. May 24, 2021 at 6:57 PM
    Convertedman
    Convertedman New Member
    Scotty
    Cumming, Ga
    2021 CM 4 wheeler Limited Cavalry Blue
    6in Ready lift, Toyo 35/12.50/20
    9A1E3D9F-4CB3-47B5-B5F3-139A21183B62.jpg I would definitely recommend the nfab podiums! Put them on mine last month. My wife “5’2”” is totally happy now.
  16. May 24, 2021 at 7:19 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    If you are not driving off road and if your wife is short as the OP states, I recommend going with a dropped step and not a slider or slider-like step that is only slightly lower than the sill of the truck. A drop step helps more to get in if you are short.
    These are the dropped steps that come with the TSS in the gulf states. Not good for off road, but helpful to get into truck.
    On a side note, I want to replace them with sliders eventually.
  17. May 24, 2021 at 7:20 PM
    Cement20
    Cement20 New Member
    Landon
    SL,Ut
    2020 Cement Tundra Crewmax Sr5
    -ThrashedOffroad Send-It Suspension -ThrashedOffroad Billet UCA -ThrashedOffroad 6 switch pod -ICON stage 2 leaf springs -Coachbuilder 1” shackles -TimbrenIndustries Bump stops -RocktrixWheels 18x9 RT111 Teardrop matte black wheels -NittoTire 35x12.50r18 RidgeGrapplers -Ironman4x4 RAID Front bumper -Diodedynamics fog,bumper,ditch,chase and rock lights, interior LED Swap -RCIOffroad engine, transmission and cat skid plates -SbFilters Cold air intake -Victory4x4 bed mount Molle -Katzkin Graphite leather -ESPtruck plastic CrewMax storage compartment -ScreenProtech interior screen guards -Tufskin raised 3D Solar octane lettering -JamHandle door assist in orange -Unfocused Offroad Safety orange lighting bumpers
    I understand the substantial price on the Amp steps. I got them and love the clean tucked in look when not in use!!
