  1. May 22, 2021 at 3:26 PM
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    Looks great! I figure after a while in the Arizona climate with less-than-idea TLC I'm going to need a paint job sometime in the next 300K miles, and kinda like the idea of the bedliner route. Seems like it would handle desert pinstriping no sweat.
    But I'm curious – and this could be a dumb question – how heavy is it? Does it add a lot of weight to the vehicle?
    I also wonder if the micro-drag around the particles could function like the dimples on golf balls and improve handling and mpg. :der:
    Cummins3500[QUOTED] likes this.
  2. May 22, 2021 at 3:48 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Vacuumed and Feather Dusted the interior today. AeroSpace’d interior trim and Washed the inside windows. Been a while since the interior was done and she wasn’t too bad. This week will tackle the exterior Warsh and Wax.
    No sexy pics, but you can envision.
  3. May 22, 2021 at 4:09 PM
    Cummins3500
    Logan
    @NomadicFrog, thanks man, should take any pin stripping with ease. Not to mention touch ups will be pretty easy. My paint was trashed and cost was a deciding factor to go this route. I’d imagine it adds some weight to the truck but I’d guess it’s impact is negligible
    Darkness and NomadicFrog like this.
  4. May 22, 2021 at 4:23 PM
    I made the same mistake and it was a bitch to fix. That coupler only slides on the shaft one way, you've got to turn it to line up the splines like it was before. Not sure how else to explain it.
    Voss[QUOTED] likes this.
  5. May 22, 2021 at 4:36 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    The coupler would be the section at the floor board that connects the lower shaft coming from the rack and the steering column?
  6. May 22, 2021 at 4:55 PM
    No it's the part you drew the arrow to and wrote "only way." You've got to slide that up and then use it to turn the shaft until your marks line back up. You're correct that it only slides on one way. Took me a while of fighting that to realize the same thing. But now you've got to slide it on and turn the shaft. Sometimes you'll find it won't turn and I never could figure out why that is. Almost seemed random.
  7. May 22, 2021 at 5:14 PM
    Voss
    2003 AC TRD 4x4
    Ok thanks, I’ll play around and see if I can make it work but turning that portion would turn my steering wheel, wouldn't it? I would be lined up on the coupler if my steering wheel wasn’t slightly turned to the right. I turned that section to get my steering wheel to line up with wheels.
    I think I may have installed the steering column incorrectly. Need to figure out where true center is. One side has about half a rotation more than the other, I’m wondering if I didn’t install with the half turn towards wrong side.
  8. May 22, 2021 at 5:53 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Got all the parts for the front end suspension that hasn’t been touched.
    MOOG upper/lower control arms
    OEM upper/lower ball joints
    SPC camber kits
    I was only able to tackle passenger side upper arm and upper ball joint cause the press I got wasn’t the easiest to use and I could have used another adapter but didn’t have anything. I’ll do the other side and then the lowers next week after we are done camping. Don’t wanna get stuck in the middle of the job or waiting for a part cause I need my truck to pull a TT.
    oscardog86, chrisb, NUDRAT and 10 others like this.
  9. May 22, 2021 at 8:13 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    What tt?
  10. May 22, 2021 at 9:59 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    A rental. 2015 jayco white hawk ultra light. 24ft
    onesojourner[QUOTED] likes this.
  11. May 22, 2021 at 10:37 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    used it to move things to storage and pickup more drywall
    looked pretty here.. took a picture because fuck it. i like this thing
    1Silverback, 912, Thrussn and 15 others like this.
  12. May 22, 2021 at 11:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Removed small red wasp nest from top passenger door hinge a few minutes ago.
    Partial moon. Partial over cast. Can see for about a mile and a half in the clearings with the naked eye. Forest is mucho darker. I noticed while out there that the backwoods was eerily quiet, but front woods was abuzz with crickets, lightning bugs, and few other night noises. Usually the sound is reversed. Strange.
  13. May 22, 2021 at 11:56 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    My short term plans are changing and I'm seeing a need to setup my truck for some camping. Maybe even looking at needing it done soon. My obvious issues are powering my fridge and having a sleeping space inside the shell. The sleeping space I can figure out/ cobble together no problem. The power...
    I think I need a dual battery. I've seen some people put their batteries in the passenger side near the firewall. That sounds alright to me. I think I remember group 27? What type of battery should I be getting. Money is a concern, but so is being stuck in the desert with no fridge. I might be able to get a deal through work, but I don't know what size we use. I'll check that tomorrow. Likewise I might be looking at solar or something. I don't know if that's really needed for running a 12v fridge 24/7 when I'm still driving 50+ miles daily.
    Battery isolator. Does the one in the link seam sufficient? I'm a little new to this stuff. Thanks. https://www.amazon.com/Dual-Battery-Isolator-KeyLine-Chargers/dp/B00WTAFR5W
    oscardog86, Darkness and Tundra2 like this.
  14. May 23, 2021 at 2:58 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Midnight bastardizations!
    Used a paint pen to mark my drill points. The non-wired end is .5 (½) a millimeter higher than the other end. Otherwise, looks good once I get shorter bolts, and make the other end.
    KarmaKannon and Darkness like this.
  15. May 23, 2021 at 3:22 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    It almost got washed! But then it stopped raining so now it just looks worse :rofl:
    NUDRAT, KarmaKannon and Tundra2 like this.
  16. May 23, 2021 at 4:18 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Bad changes?
    I think that usage would keep you and the battery charged. Dual batteries are more fun though.
  17. May 23, 2021 at 5:56 AM
    KarmaKannon
    Utah
    Some junk
    More camping is never bad.
    oscardog86, chrisb and FrenchToasty like this.
  18. May 23, 2021 at 7:44 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Finally been putting some proper miles on the truck. Ive decided bigger tires are gonna be mandatory. I dont like the noise at a constant 2200rpm which is where im at @70. 2krpm sounds good, but 60 mph is in the way out here. The other options are taller gears (is a 2002 a 7.5” front and 8” rear) or louder pipes. Loud and open is better than loud and muffled. A trans swap would be ideal. But without a clutch pedal mount, and computer something...
  19. May 23, 2021 at 8:46 AM
    Turn off overdrive? :notsure:
    Sirfive[QUOTED] likes this.
  20. May 23, 2021 at 8:48 AM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    Bought a second one today, or my wife and father in law did.
    An ‘04 Phantom Grey Pearl Double Cab limited with 163000 for $6000. My ‘space for two kids in the back’ problem is solved.
    Two known issues, Parking brake cable snapped after rear drums and shoes were done last month, and there is a fuel leak if the PO fills the tank all the way.
    Known service history: LBJ in 07 @ 40k, Frame 2014 @ 99k, Timing belt @109K, Airbag recall in 19, Brakes, including front calipers (brand unknown) in the last year. It has an aftermarket exhaust with no cats.
    Going to have a mechanic fix the parking brake so wife can register and inspect, then drive it a bit and start the to do list. I wont be in the country for another 6 months, once it’s shaken out and looking good I’ll get Jade ready and sell.
    Darkness, oscardog86, NUDRAT and 5 others like this.
  21. May 23, 2021 at 10:15 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    The truck got washed and stripped. Then it got clayed. I used griots 3 in 1 ceramic to seal it back up (X2). I polished the glass and sealed it with rainX. I am driving it to KC to cover it in bugs and see how the sealant does.
    Darkness, oscardog86, NUDRAT and 6 others like this.
  22. May 23, 2021 at 10:24 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I dont know how to find the post, but hard F on just disconnecting the drivers door. I need to disconnect the drivers back door as well, and i dont see a switch. Anyone got a pic of the beeper itself?
  23. May 23, 2021 at 10:43 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    I like the subtle shoeing.
  24. May 23, 2021 at 11:17 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  25. May 23, 2021 at 11:19 AM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    I have to do this. Is it easy?
  26. May 23, 2021 at 11:24 AM
    Super easy. Drain 4 quarts out and fill 4 quarts in through the orange tipped dipstick near the back of the engine.
    Drain with the engine cold though.
    NUDRAT and NWPirate like this.
  27. May 23, 2021 at 11:26 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    when will we see you on CL with a mobile featherdusting and needle oiling service
  28. May 23, 2021 at 11:47 AM
    Fred
    Hand Protectors
    Soon!
    You’ve just reminded me to Feather Dust my engine bay. Got her Warshed and AeroSpace’d today. Skipped the Wax On/Off due to spending time Warshing the MzPHMobile. Plus, its hot out there and didn’t want to Sun Damage my Hands.
  29. May 23, 2021 at 11:58 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Ditch lights on, and all the fixins'
    Fog lights probably need resistors/anti-flicker harness.
  30. May 23, 2021 at 2:40 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    What are we talking about here?
    Door chime?
