Lost MPG 320 to 210 per tank
Discussion in 'New Member Introductions' started by Yoter Motor, May 22, 2021.
  1. May 22, 2021 at 7:59 AM
    Yoter Motor
    Yoter Motor [OP] New Member
    Jesse
    2010 4.6 DBL Cab Tundra 4x4
    3 inch leveling kit 33 inch tires K&N air filter
    I Bought my 2010 Tundra Brand new, only owner, been a great truck! But I lost over 100 miles per fill up for no apparent reason its always got good gas mileage for a 4x4 V8 and I've driven it from California to Alaska and back and all over the west Coast! It has 110,000 MLS on it a 3 inch leveling kit that was installed when I bought it and I have always ran 33 12.5 tires on it and a K&N filter thats it, about a month ago I drove 3 hours to pick up a empty 16 ft car trailer and half way home the MPG dropped dramatically, when I got home I reset my mileage and filled the tank and sure enough only 210 till next fill up and this has been going on for over a month and havnt towed the trailer since I bought it so what can it be I do all my own fluid changes and even rebuilt the hole front end last year at a local Les schwab, I have no engine lights on and my truck isn't a flex fuel plus its summer time so the winter fuel issue isn't the problem I live in a modern temp climate 30 miles from the ocean and have owned 8 different Yotas this Truck is my Favorite and I want it back to Normal before I move from Cali back to Alaska nxt Month
    Prostar 190 and Metro14536 like this.
  2. May 22, 2021 at 8:04 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You were probably getting 5-6 mpg pulling the trailer. The ecu adjusted per what it was seeing the engine use. When you filled up it still thinks you’re getting that mpg. Reset it and you’ll be fine.
    WILLINH likes this.
  3. May 22, 2021 at 8:09 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    At 100k time for spark plugs if you have not changed them already. They can certainly impact MPG/performance but not as drastic as your experience. Think Danny is right, likely the towing MPG impact.
    15whtrd, rockmup and Metro14536 like this.
  4. May 22, 2021 at 8:13 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    You can do a double-check test by filling up and noting the odometer reading. And then re-noting it when you fill up. Do the simple math. It would be good to also be checking the fill up quantity of gallons.
  5. May 22, 2021 at 8:18 AM
    Blue Thunder
    Washington
    I can drive an entire tank at 60mph, getting 17-18mpg and the computer will still calculate my range at ~13mpg when I fill-up. Don't stress about the computer, it's always wrong. Do some hand calculations from a few tanks of gas and make sure there's a real problem.
    rockmup likes this.
  6. May 22, 2021 at 8:41 AM
    frichco228
    Frank
    Virginia
    one other thing you can do is reset computer- - actually disconnect the battery for 30 minutes. It will clear that mileage estimate and start over from scratch based on your driving.
    1lowlife likes this.
  7. May 22, 2021 at 9:01 AM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    I don’t use the trip computers they aren’t exactly accurate. I always calculated by hand
    slowpokepete and Half Assed like this.
  8. May 22, 2021 at 9:50 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Aaaahhhhhhl Grasshopper very smart!!!!!
    You probably also use a Hewlett Packard calculator.
    TundraDude18 likes this.
  9. May 22, 2021 at 10:05 AM
    SouthWestGA
    I wear flip flops so I can count past 10 haha
    Also if you’re towing anything the mpg is affected
  10. May 22, 2021 at 12:37 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska. What part of AK will you be heading to?
  11. May 22, 2021 at 3:07 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I think the guys covered it pretty well earlier. If your hand calculated MPGS still show a big drop, let us know. There are some really smart folks on here that will help you figure it out.
  12. May 23, 2021 at 2:28 AM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Welcome from Phoenix
  13. May 23, 2021 at 7:02 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal.
  14. May 24, 2021 at 2:51 AM
    Welcome from Ohio
