  1. May 21, 2021 at 11:51 AM
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    Started prepping for a trip to Moab:
    • I pulled off my ski rack and yakima rocket box 16 from the topper crossbars.
    • I re-tightened all the topper bolts clamping it on to the bed (if you haven't done this please do, mine were NOT as tight as they were 6 months ago).
    • I then moved my thick tailgate mat and placed it between the maxxtrax / shovel / milk crates and the front wall of the bed (where they are ratchet strapped forward).
    • I then loosened and retorqued the rear suspension (lower shock bolt, upper shackle bolt, lower shackle bolt) bolts.
    Took her for a test drive and even with the rear window down the truck is rattle / squeak free. Gotta love a truck that sees daily family duties / colorado off-road / camping use and has 0 unwanted noises or squeaks and rides better than new at 24k. Not to mention it lets me fully enjoy the DD 10" exhaust.
  2. May 21, 2021 at 12:05 PM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Would you mind telling me what you went with and/or going with? I’m in the same spot right now.
  3. May 21, 2021 at 12:41 PM
    nmjameswilson
    nmjameswilson New Member
    James
    Kansas City
    2021 Limited Nightshade Double Cab
    Yes I am lol .... He did not know what he had and I did not know they were discontinued lol.
    RobertD and RainMan_PNW[QUOTED] like this.
  4. May 21, 2021 at 12:54 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
  5. May 21, 2021 at 12:58 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    Thank you!
  6. May 21, 2021 at 1:13 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    EASY? hadn't started mine yet because I dread running the pwr through the door.
  7. May 21, 2021 at 1:42 PM
    French Avocado
    Utah / Wyo
    Sorry @1UP I forget that others do not have puddle lights already in the mirrors. Both of my Tundras have puddle lights (albeit so dim you do not really notice them) and it is an easy change. Your work is more complicated but you will enjoy the result!
    PS - I also always forget that there are 2WD Tundras. I do not think I have ever seen a 2WD because in the snowy Rockies no one would buy them.
    Hightide and GODZILLA like this.
  8. May 21, 2021 at 1:43 PM
    I went with Toytec Aluma 2.5 coilovers, SPC UCA's, Boss rear shocks with remote resis, and Toytec shackles.
    TucsonTundra1794 and CorsoTundra like this.
  9. May 21, 2021 at 1:51 PM
    snowman19
    snowman19 New Member
    Scott
    Cypress, Texas
    2019 White Tundra CM
    Katskin leather seats, painted engine cover, fuse box cover, Rigid 30" light bar in bumper, Method 605 wheels, Bak roll up bedcover, Rhino lined grill surround and bumper caps
    Added USB ports in center console, two up front, one in back...shout out to @Chelly for the two port 3D printed piece in back of console...awesome quality and customer service...thanks Stephen! Also added two Oznium 6mm led “bolts” for ambient lighting on center console..
  10. May 21, 2021 at 2:04 PM
    Rabidllamas
    Phil
    WA
    Thanks
  11. May 21, 2021 at 4:12 PM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Installed the OEM flat black tailgate letters today. @cutjob helped me take off the sr5 and iForce badges, so hopefully Sunday I’ll dip the Tundra emblems black to match.
    Wallygator, cutjob, Ostrich and 9 others like this.
  12. May 21, 2021 at 4:52 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    I had to run wires through the door wire bundle and it was much easier than I expected. I used a long zip tie to fish it through after popping out both grommets (cab side and door side) and both sides probably took less than 5 minutes of fishing for like 30 feet of wire on each.
    TunBrun likes this.
  13. May 21, 2021 at 4:55 PM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    During driving in snow in Colorado, yellow portion of switch back LED stopped working. It was a $10 a pair bought in Jan from eBay. Got new replacement for $20 from Amazon. Hoping they will last longer.
    BlueRibbon4x4 and Fotnot like this.
  14. May 21, 2021 at 5:17 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Husky Weatherbeaters
  15. May 21, 2021 at 5:25 PM
    nmjameswilson
    James
    Kansas City
    What are people doing to get these areas around the radio blacked out? I guess something that would work for the steering wheel too. Thanks all!
    mgm16trdpro likes this.
  16. May 21, 2021 at 5:30 PM
    CorsoTundra
    North GA
    Some are painting and others like me bought a new OEM black trim section. Sorry but I forget what the part number is.
  17. May 21, 2021 at 5:32 PM
    CorsoTundra
    North GA
    and ripping the whole dash apart to install it
  18. May 21, 2021 at 5:34 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Bed side decal.
  19. May 21, 2021 at 5:40 PM
    biebs96
    PA
    It’s funny that the two identical ports each have a different voltage displayed.
    ...this would kill me...
    also, what USB port is that?
    Fotnot likes this.
  20. May 21, 2021 at 5:40 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Got the 295/70 18's installed. Yoko X AT's, only rubs on the skid plate. Also put on the Prinsu yesterday, what a pain in the ass that was..
  21. May 21, 2021 at 5:44 PM
    biebs96
    PA
    I have these tires, you’ll be happy...Once they are balanced properly. They can be tough to get perfect.
  22. May 21, 2021 at 5:54 PM
    SEM Trim Black. I have pics in my build thread.
  23. May 21, 2021 at 6:47 PM
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    Which one exactly? Looked up SEM on Amazon and came across several finishes. Wasn't sure which one to get.
  24. May 21, 2021 at 6:50 PM
    39143.....I should have put that in the reply
    SchnauzerMan likes this.
  25. May 21, 2021 at 6:53 PM
    What's nice about it is that it is more durable than regular spray paint. It dries quick and does not have that strong or long lasting spray paint smell. I did 4 to 5 lights coats.
    TunBrun, Hightide and Djone27[QUOTED] like this.
  26. May 21, 2021 at 7:17 PM
    Angry Gunny
    Angry Gunny New Member
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    Mounted my ammo can.
    Wallygator, Ostrich, YotaBro and 6 others like this.
  27. May 21, 2021 at 7:22 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I like that alot, too bad my truck isn't a TRD.
    TucsonTundra1794 and batmandog like this.
  28. May 21, 2021 at 7:45 PM
    batmandog
    batmandog New Member
    Maryland
    2018 super white DC trd sport
    6" APS iboard running boards, Tyger 6" iBoard
    Tomorrow morning the Timbrens go in
  29. May 21, 2021 at 7:46 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    This^^^^
    Then vinyl wrap. Takes some time, but adds a little different touch. Here’s mine.
    nmjameswilson[QUOTED] likes this.
  30. May 21, 2021 at 8:23 PM
    1UP
    1UP Truck Gang
    I know this has been covered a billion times buy I'll ask since your sharing. Does the paint need a matte clear coat to really look and feel OEM?
