Tundra towing conflicting information
Discussion in 'Towing & Hauling' started by Advocate505, May 20, 2021.
  1. May 20, 2021 at 3:32 PM
    Advocate505
    Advocate505 [OP] New Member
    2020 Tundra crewmax 4x4 TRD Limited
    I have a 2020 Tundra crewmax 4x4 TRD Limited. It is the iForce v8 5.7 liter with the tow package. I am buying a travel trailer and keep finding different numbers online for towing. Many say 8800, some say 9200, some 10200. The dealer said 10200 but I wanted yet another opinion! I'm trying to decide on a travel trailer, that needs a truck max towing at 9400 to pull, with a fully loaded trailer. Any help is greatly appreciated!!
  2. May 20, 2021 at 3:38 PM
    18" TRD Off Road Wheels
    Look at the stickers in your driver side door jamb. If you are not sure what they mean, post up pics of them and we can translate, but it's pretty easy to read.
    onesojourner likes this.
  3. May 20, 2021 at 3:40 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Payload is going to be your issue. You likely will have a payload of 1200-1300 lbs, check the sticker on your door jamb. A travel trailer of that size will have a tongue weight of ~940 lbs. That'll leave you ~300 lbs for the rest of your payload that needs to include driver, hitch, and any other supplies/passengers being transported in the truck.
  4. May 20, 2021 at 3:45 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    Like @AzureNightmare said, the door jamb is going to be the best source of information. All the numbers you have found are correct for different variations of the Tundra, CrewMax vs. Double Cab, 4WD vs. 2WD, etc. I believe the 8800 is for the smaller V8, the 9200 and 10200 are for the 5.7 in different configurations. Check your sticker for the final verdict.
  5. May 20, 2021 at 3:45 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Look at the sticker inside the driver door jamb. The toyota rating of 10200# is for a regular cab short bed truck.
    Also a tundra has a low payload capacity, typically between 12-1300lbs. There are 6000lb campers that will cause the truck to exceed payload rating.
    A campers hitch weight is an empty, without propane tanks, battery (s), or the weight distribution hitch. Those 3 items add around 200lbs, plus ten passengers in your truck, and gear. You could easily be down to 700lbs of payload left for the camper hitch weight.
    Keep in mind your 2020 does not have the traditional air to fluid transmission radiator to keep trans fluid cooler (removing in 2019), so you could be running 260 degrees or more when towing. 302 degrees is the trans temp warning light setting.
  6. May 20, 2021 at 3:49 PM
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    Owners manual + door jamb stickers will answer your question, OP.
    Found mine was TWR of 9800 lbs. after finding model code USK56L-PSTSKA (with Tow Package) on the door jamb and using the chart in the manual.
    Yota303 and Cpl_Punishment like this.
  7. May 20, 2021 at 4:07 PM
    Advocate505
    Thank you all! Called 2 dealers and got different answers, but looking at the sticker and checking the manual I'm at 9700lbs towing. Appreciate the help!
    gosolo and IndianaGeologist like this.
  8. May 20, 2021 at 4:41 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    9400 lbs is a big trailer for a half ton. I wouldn’t want to take that on a long road trio in a tundra
    Cpl_Punishment likes this.
  9. May 20, 2021 at 5:06 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
  10. May 20, 2021 at 5:09 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    What travel trailer are you buying?
    9400 dry? Your tongue weight is gonna be over 1200 pounds and that’s pretty much all of your payload.
  11. May 20, 2021 at 5:17 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I'm not sure you followed what the guys were telling you. That max tow number only works in some mystical situation with some magic trailer.
    The reality is that your travel trailer will most likely have a tongue weight over 12% the gvw of the trailer. You will be over weight on your rear axle and maybe your front with that big of a trailer. If it was a one time thing I would say go for it. You need a smaller trailer if you want to stay legal.
  12. May 20, 2021 at 5:17 PM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
  13. May 20, 2021 at 5:17 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    All you need to worry about is payload/tongue weight. If you in the green on those weights (taking into account all that you carry as mentioned above) you will be good to go. Actual tow capacity does not mean too much on a half ton truck because you run out of payload long before you hit the tow capacity.
  14. May 20, 2021 at 5:28 PM
    belanger9
    Edmonton, AB
    A bunch
    It works if you're only towing the trailer and have no other stuff in the truck. So with 2 vehicles going the Tundra can take the trailer and the other can take all other people and gear. But the typical family taking 1 vehicle would run out of payload with a 6000 lb trailer roughly.
  15. May 20, 2021 at 5:43 PM
    SchnauzerMan
    Southern New Mexico
    2019 SR5 CM 4x4
    Not true because they are related and if towing capacity didn't matter, there wouldn't be a limit. The general rule is to have 10 -15% of the trailer weight on the hitch (the Tundra manual says no less than 9%). 9,700 x .09 = 873 lb, which means he would have very little cargo capacity left. I also agree with others - I think that would be too much trailer for a Tundra or any 1/2 ton. The issue is not just if the truck can handle it, it is a safety issue.
