  1. May 20, 2021 at 2:37 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Regular Wax on the body and clean it up as soon as possible.
    onesojourner[QUOTED] and Tundra2 like this.
  2. May 20, 2021 at 2:39 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I just wait for it to rain unless there's a juicy one just like I posted. The windshield wipers clean off most of the debrizzle from my line of sight.
    I personally haven't washed the truck since March of 2020. I do occasionally run it through the automatic warsher.
    I drive early in the morning going home so bug hits are unavoidable. They get real bad when it's a warm winter. Driving in the dark both ways, bugs a plenty.
    If I was anal about the exterior of the truck I'd never do anything else but warsh it.
    Just my two cents y'all.
  3. May 20, 2021 at 3:02 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I have a bottle of griots 3 in 1 ceramic that I am going to try this year. I think I will put a few extra coats on the bumper and grill.
  4. May 20, 2021 at 3:09 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I get that. You put the miles on everyday. I put my miles on in big chunks and then it gets to sit in the garage. I don't have an excuse to not keep up on it.
    Tundra2[QUOTED] likes this.
  5. May 20, 2021 at 3:18 PM
    Excuses are like assholes; everyone’s got one, and everyone thinks theirs is the best.
  6. May 20, 2021 at 3:26 PM
    That product works really well. I use it on both vehicles.
  7. May 20, 2021 at 3:31 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    102 miles a day Monday through Friday. :spending:
    If mine sat for more than a weekend I'd care more. :rofl:
  8. May 20, 2021 at 4:04 PM
    I thought it was "Opinions are like assholes, everyone's got one and they usually stink"
  9. May 20, 2021 at 4:52 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    My 2002 is getting a timing belt done (way above my knowledge, patience, and time atm) and I had them look at the brakes cause I am starting to get a shuddering after they are very warm. Now, I replaced the rotors and pads only 10K miles ago and they measured/checked and told me that yup, the rotors are warped. Maybe I went too el cheapo on the rotors?
    edit: the shop told me that tundras are well known for warping rotors. Is there any validity to this? I don't recall seeing that discussed here at all.
    Filthyphil likes this.
  10. May 20, 2021 at 5:04 PM
    Fred
    Hand Protectors
    Couple pics of the Exhaust Work I did when doing the JBA Shorty Headers. I removed each Cat Pipe and cleaned up the Flanges on both ends. Installed New Gaskets, as well. You can see where the Flange was getting thin/worn on the high side where water would dive into.
    Used Permatex HighTemp Gasket (not pictured) to fill that and seal from future penetration. Good shtuff! Shprayed everything with Black BBQ Ceramic Rustoleum.
    Did I mention I received Yard of the Month for May?:yes:
    Thrussn, MEWaters, hammeron and 9 others like this.
  11. May 20, 2021 at 5:12 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    When doing the brakes on these trucks, It's very important that the rear brakes be checked and adjusted. Many people ignore them and then the fronts do all the work. Also, lifted trucks need the LSPV adjusted for proper operation. I'm on my 3rd first Gen and never had a warped rotor.
  12. May 20, 2021 at 5:21 PM
    dvani
    dvani New Member
    Derek
    2006 Tundra DC
    Here's a few pics of my compressor installed... I forgot to mention that I used 3" x 6" 3/8" aluminum L angle that I cut to fit the radius of the fender pretty closely.
    CodyP, Voss, abcinv and 10 others like this.
  13. May 20, 2021 at 5:26 PM
    robabeatle
    AZ
    Thanks. At the time, I did adjust for a little more rear bias and felt an improvement in braking. I did not look at the rear hubs and so weak rear hubs could have the front doing too much work as you stated. Thanks, live and learn.
  14. May 20, 2021 at 6:14 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    https://www.tundras.com/posts/2003488/
    robabeatle[QUOTED] likes this.
  15. May 20, 2021 at 6:58 PM
    robabeatle
    AZ
    Thanks, my truck was equipped with the 13wl when i bought it so I feel set on calipers. Pretty likely that I f-ed up with not really digging into the hubs when I serviced the front. Otherwise, if I get shuddering in another 10K miles or so, I will be looking for better rotors.
  16. May 21, 2021 at 2:42 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Discovered on accident that when leaving the shit pit I can drive by about 120 yards of honeysuckles in full bloom grown onto a fence right next to the road on the side road to the back door.
    If the breeze is right I can get a nose full and alleviate my nostrils of burnt rubber (the carcinogenic kind) and fiberglass dust or whatever the hell material airbags are made of.
    :yes:
  17. May 21, 2021 at 5:08 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    lot of TX dust under that hood - perhaps a cap to keep that opening clean?
    dvani[QUOTED] likes this.
  18. May 21, 2021 at 7:03 PM
    dvani
    dvani New Member
    Derek
    2006 Tundra DC
    Not sure if TX dust is that much worse, but Idaho dust and silt gets everywhere! I believe that ARB makes a cap for the outlet.
  19. May 21, 2021 at 7:24 PM
    Also, if dusty conditions are part of life; you can remote the intake of the compressor if you want. I did such shenanigans on the 4runner install, mounted it high inside the passenger footwell; then it pulls clean and cooler cabin air. I will do something of the sorts when I mount my dual arb in the tundra
    chrisb, NUDRAT and KarmaKannon like this.
  20. May 21, 2021 at 7:54 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    It has to be similar if not worse. That flour type stuff is all around the west. I thought dust was bad and then I hit a real silt bed and my dust cloud past me. There's no washing that stuff off.
  21. May 22, 2021 at 3:21 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    20210522_051614.jpg 20210522_051633.jpg Ran her through the El cheapo light show car wash.
    Darkness, KarmaKannon, NUDRAT and 7 others like this.
  22. May 22, 2021 at 4:03 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Not long and you will be out there clay bar. It's worth it.
    CodyP, NUDRAT and Tundra2[QUOTED] like this.
  23. May 22, 2021 at 6:07 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    No.
  24. May 22, 2021 at 7:53 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Darkness, NUDRAT and FrenchToasty like this.
  25. May 22, 2021 at 1:04 PM
    Cummins3500
    Logan
    Got the ole girl back from her makeover. full monstaliner paint job, color is called dirt bag
    Huge shoutout to Barnett’s Economy Painting for knocking this thing outta the park. Pictures don’t do it justice. Did inside the door jambs, behind the cab, and what they could under the hood. The grill is probably my favorite part. I had em paint the flares, I’ve just gotta order my clips and seal before re-install.
    8DEB2F0C-3975-4953-AC1E-E74AEBA48A2E.jpg 15AD00A5-D7B1-478C-9A3C-761BC3AD0BE2.jpg 0727EF78-CEE7-432C-AD06-B6A404CAA189.jpg
    These headlights gotta go lol
    *peep the sequoia in the 2nd picture patiently waiting for rear air bags lol
    912, Kimosabe, oscardog86 and 19 others like this.
  26. May 22, 2021 at 1:42 PM
    biebs96
    PA
    Truck looks awesome. Reminds me of my 1st gen.
    where’d you get that rear plate frame? That is unique.
  27. May 22, 2021 at 2:28 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I usually don't like these because you loose the body detail lines. They end up looking like chubby versions of their former selves. I don't know if it's the color or lighting but this looks really great. I wonder if my 3rd gen 4runner could make a green color look as good as your truck. Very nice.
  28. May 22, 2021 at 2:47 PM
    Cummins3500
    Logan
    onesojourner likes this.
  29. May 22, 2021 at 3:12 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    So today I was super impressed with myself. I was doing so well. Changed the steering shaft seal and the entire steering column.
    Then I got stuck trying to figure out what I did wrong...
    once I had it all together, my steering wheel was turned a little to the right.(should be straight with wheels) there’s only 1 way for the steering column to connect to this portion from what I see...
    Figure this can’t be the mistake so maybe I messed something up underneath where the shaft connects to the steering rack when I was changing the steering shaft seal? I went to fix that connection but disconnecting and straightening the steering wheel, the bottom section is off from where I had marked it before. The top section can only attach at 1 location so the bottom is the only place I could rotate enough for my steering wheel to line up straight with tire direction.
    How badly have I messed up?...
  30. May 22, 2021 at 3:21 PM
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    I have heard that a few places, including here and my local mechanic. I had warped rotors twice in the first two years of owning the truck. More on that in a sec...
    That makes a lot of sense, and could be part of my problem (note to self to check the rears) however, the local mechanic suggested Power Stop KC2324-36 Z36. When I needed to turn the rotors after only about 11 months since the last time, I said screw it and got those.
    I've had them on for over a year now, no hint of warping.
