Powder steering reservoir relocation
Discussion in '1st Gen Tundras (2000-2006)' started by bigbird, May 19, 2021.
  1. May 19, 2021 at 6:19 PM
    bigbird
    bigbird [OP] New Member
    Hello new here. I just picked up a 2002 sr5 access cab and am in the process of adding a duel battery. I need to relocate the power steering reservoir to make room. Was planning on moving it up front next to the windshield fluid fill neck. I tried doing a search but could not find the I.D. size of the two lines. Does anyone know what size lines they are and what type of hose i should get at the parts store? Much thanks
  2. May 19, 2021 at 7:56 PM
    The return line is 10mm, but good luck trying to find it; most people stretch 3/8” hose over it. The closest I’ve seen online would be 13/32”.
    I don’t know about the other line which is larger.
  3. May 20, 2021 at 12:47 PM
    bigbird
    Thanks for replying
