Drivers Side Left Ball Joint Failure
Discussion in '1st Gen Tundras (2000-2006)' started by MA2000TundraSR5, May 19, 2021.
  1. May 19, 2021 at 2:27 PM
    MA2000TundraSR5
    MA2000TundraSR5 [OP] New Member
    Mark
    2000 Tundra SR5
    None
    Hi anyone have info or advice for this catastrophic failure of my drivers side left ball joint
  2. May 19, 2021 at 2:49 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    What info you looking for Mark….how best to fix it ?
    Throw some pics up of what you’re confronted with or perhaps little more info.
    and Welcome to the money pit !
    N84434 likes this.
  3. May 19, 2021 at 3:12 PM
    Upper or lower? Welcome to the forum.
  4. May 19, 2021 at 4:05 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I’ll take lower for $50.
    Weagle, Cg13055, onesojourner and 2 others like this.
  5. May 19, 2021 at 4:18 PM
    Sounds like you didn’t get the recall letters to replace the LBJ.
  6. May 19, 2021 at 4:30 PM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    What recalls do 01 have?
    I called my local dealer they said my tundra had no recalls, 310k
  7. May 19, 2021 at 4:33 PM
    I'll take ghosted for $100
    Cg13055, bmf4069, NWPirate and 2 others like this.
  8. May 19, 2021 at 4:57 PM
    glowblue
    glowblue From time to time
    VA
    I know I’m on the wrong side of town, but I’ll wager it all on catastrophic thread failure for the win, Alex.
    Cg13055 and Darkness like this.
  9. May 19, 2021 at 5:54 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    I'll take that bet. :popcorn:
  10. May 19, 2021 at 8:31 PM
  11. May 19, 2021 at 9:03 PM
    NWPirate
    Zach
    WA
    It's probably already been done, so there isn't an active recall.
    Have them dig into the past work (early to mid 2000's) and see if it's been taken care of.
    des2mtn and Jack McCarthy like this.
  12. May 19, 2021 at 11:36 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You mean like this????
    Mine happened when NTB forget to put the cotter pin in the spindle going into the lower control arm.
    Nut came off and the spindle popped out while driving..
    IMG_5913_zps8vypcyjt_5dbe7c55d4bbe9f5bce8185f4ddd8e716d5c2a9f.jpg IMG_5914_zpshihahuhw_4ea52c330146740cf3f08a3a0cef799f073c08d0.jpg
    irhunter, Darkness, NWPirate and 2 others like this.
  13. May 20, 2021 at 5:11 AM
    Just the LBJs and the rear crossmember are the only ones I recall. Bunch of TSBs to upgrade and replace things like your calipers for vibration during braking for example, but those are only covered under warranty.
    Cg13055 likes this.
  14. May 20, 2021 at 5:42 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Second this. I had LBJ recall work done way back in 2007.
    NWPirate[QUOTED] likes this.
  15. May 20, 2021 at 9:57 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Recall Number
    07V013000
    Recall Date
    01/19/2007
    Component
    SUSPENSION:FRONT:CONTROL ARM:LOWER BALL JOINT
    Summary
    ON CERTAIN TRUCKS AND MINI VANS, DUE TO POSSIBLE IMPROPER FINISHING OF THE FRONT SUSPENSION LOWER BALL JOINT, SOME BALL JOINTS MAY EXPERIENCE AN INCIDENTAL DETERIORATION OF THE INTERNAL LUBRICATION. THIS MAY CAUSE THE BALL JOINT TO WEAR AND LOOSEN PREMATURELY, WHICH COULD RESULT IN INCREASED STEERING EFFORT, REDUCED VEHICLE SELF-CENTERING, AND NOISE IN THE FRONT SUSPENSION.
    Consequence
    IN EXTREME CASES, IF THE VEHICLE IS CONTINUOUSLY OPERATED IN THIS CONDITION, THE LOWER BALL JOINT MAY SEPARATE FROM THE KNUCKLE AND COULD CAUSE A LOSS OF VEHICLE CONTROL.
    What Owners Should Do
    DEALERS WILL REPLACE THE FRONT SUSPENSION LOWER BALL JOINTS. THE RECALL BEGAN ON FEBRUARY 28, 2007. OWNERS MAY CONTACT TOYOTA AT 1-800-331-4331.
    Cg13055 likes this.
  16. May 21, 2021 at 3:26 PM
    MA2000TundraSR5
    Mark
    2000 Tundra SR5
    None
    Hi there I’ve just been very busy withFamily and some other matters however my understanding about the recall is it didn’t affect the 2000 tundras just 2000 to 2007
  17. May 21, 2021 at 3:39 PM
    tacoguybill
    tacoguybill The Burrito Bandido
    Saaaan Diaaago
    06 DC SR5 4x4 174k, 04 Sequoia SR5 4x4 105k
    Did you experience any warning signs prior to the failure? I’m getting some crazy noises and wondering if I’m being paranoid enough to justify replacing mine
    Anna's05Tundra likes this.
  18. May 21, 2021 at 5:42 PM
    tyler-brown
    tyler-brown New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    20201020_080415.jpgor sometimes like this
  19. May 21, 2021 at 9:30 PM
    SouthPaw
    2000 Limited 4x4 AC
  20. Oct 15, 2023 at 7:20 PM
    GiGiLV
    GiGiLV New Member
    Jamie
    2004 Tundra SR5 4WD TRD
    Hi everyone. Just joined the LBJ failure club today. Shoulda stuck with my Chevy's IMG_20231015_143135.jpg IMG_20231015_124556.jpg
  21. Oct 15, 2023 at 7:35 PM
    Former GM lifer here: GM has its host of problems. Let me guess: you missed the memo to only install OEM lower ball joints?
    Weagle, tacoguybill and dbittle like this.
