DIY rock sliders
Discussion in '2.5 Gen Tundras (2014-2021)' started by helidave, Jan 12, 2021.
  1. Jan 12, 2021 at 9:24 AM
    helidave
    helidave [OP] Hellacopter
    flagstaff
    2015 DC 4x4
    Been working on these on and off for a few weeks. 3/16 mounting plates. 1.75" x .120 wall tubing. Not intended for hardcore rock crawling, but they're pretty beefy. 100% bolt on using existing holes. They sit about 1" above the bottom of the frame and wrap around the frame and clamp on the back similar to some other name brand sliders. Right side is almost done, still needs some gussets. Left side is all cut and ready to put together. slider03.jpg slider04.jpg slider06.jpg slider09.jpg slider12.jpg slider14.jpg
  2. Jan 12, 2021 at 9:31 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
  3. Jan 12, 2021 at 12:33 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I likey! I'm a fan of square tubing sliders. Yours look similar to the Demello Rock Crusher sliders.
  4. Jan 12, 2021 at 12:49 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Next time you're in Winnipeg....I'll take a set. :thumbsup:
  5. Jan 12, 2021 at 12:55 PM
    helidave
    flagstaff
    2015 DC 4x4
    I looked at a bunch of different sliders when I was designing these, and the demellos were one of them. I think the square will make a better step than the round outer tube. Plus I don't have a tube bender
  6. Feb 13, 2021 at 6:56 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    This is awesome! What model hobart is that you're using?
  7. Feb 13, 2021 at 7:18 PM
    helidave
    flagstaff
    2015 DC 4x4
    It's a 210mvp mig
    eick likes this.
  8. Feb 13, 2021 at 7:20 PM
    eick
    eick New Member
    I'm tempted to try something like this but I'd need a lot more practice.
    How much did the steel tube cost you? I'm thinking it's probably 6-7 dollars a foot if it's local, and you used about 35 feet maybe 40?
  9. Feb 13, 2021 at 7:27 PM
    helidave
    flagstaff
    2015 DC 4x4
    It was around $275 for 50' of tube and 20' of 3/16x4 for the mounting plates and gussets.
    eick likes this.
  10. Apr 5, 2021 at 9:14 AM
    helidave
    flagstaff
    2015 DC 4x4
    Finally making some progress.
  11. Apr 6, 2021 at 10:17 AM
    kevine0001
    kevine0001 New Member
    Kevin
    Nice job. Look very similar to mine that I made last year. Full length, bolt on, same idea.
    DoMoToyota, cuaround and YotaBro like this.
  12. Apr 6, 2021 at 10:30 AM
    helidave
    flagstaff
    2015 DC 4x4
    Yep, I remember seeing your thread
    kevine0001 likes this.
  13. Apr 6, 2021 at 10:32 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Those came out amazing...OP and Kevin's as well.
    Makes me jealous that I do not possess such skills.
    SPP
  14. Apr 7, 2021 at 12:32 PM
    kevine0001
    Kevin
    Youtube and a forgiving wife....
    BravoDeltaRomeo likes this.
  15. May 19, 2021 at 4:07 PM
    helidave
    flagstaff
    2015 DC 4x4
    About damn time!!
    *not sure about the grip tape. Might pull it off and bedline the step areas.
  16. May 19, 2021 at 4:20 PM
    slowpokepete
    Peter
    Hillsdale, NY
    those came out amazing.
    Nice work.
    SPP
    helidave[OP] likes this.
  17. May 20, 2021 at 6:43 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Try using a more narrow grip tape, I use a 1” wide tape, it provides plenty of coverage, and looks a lot cleaner.
    Sliders came out nice though!!
    helidave[QUOTED][OP] likes this.
  18. May 20, 2021 at 6:47 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Those look great, OP (and Kevin). Nice work! Making me wish I'd have spent the extra to make mine bolt on.
  19. May 24, 2021 at 8:08 PM
    kevine0001
    Kevin
    Very nice! I used grip tape on mine, full length of outside rail. So far so good, but I don't daily drive mine. But still, it definitely helps. If my wife had slipped and bashed her shin, I would have been in trouble to say the least.
  20. May 26, 2021 at 6:47 PM
    2mchfun
    Nice job OP! Why not make a couple of cross members go under oil pan and behind the transfer case, essentially connecting the left side to the right side with square tube? Makes a really solid assembly and helps prevent cat conv theft. Gonna build mine soon to try this method. Just sharing a thought.
  21. May 26, 2021 at 6:53 PM
    GaTundra79
    GaTundra79 New Member
    White 2021 SR5 4x4
    Those came out really good, nice work!
    And that's not a bad idea @2mchfun
    2mchfun likes this.
  22. May 26, 2021 at 7:32 PM
    helidave
    flagstaff
    2015 DC 4x4
    Not a bad idea, but not really necessary for what I'm doing with this truck. Plus I already have a skidplate that goes all the way back to the transfer case.
    2mchfun[QUOTED] likes this.
