Life after leveling kit...
Discussion in 'Suspension' started by Geodude82, May 19, 2021.
  1. May 19, 2021 at 10:20 AM
    Geodude82
    Geodude82 [OP] New Member
    I recently started to install a 3/1 level kit, front spacers and rear blocks. I've gotten through the front spacers, so the front is lifted, looks great. But as with any mods, there is a snowball effect... since I changed that, what else is required?
    I found so far that I will need a front end alignment but could really use some guidance from your experiences. Do I need extended bump stops? Do I need to drop the differential?
    Thanks!
  2. May 19, 2021 at 10:35 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    toyofan87 and RdKing like this.
  3. May 19, 2021 at 12:12 PM
    I would the UCA’s while ur under there and a diff drop at 3”+ IMO
    bigger tires too
    Mr_Kane and toyofan87 like this.
  4. May 19, 2021 at 12:53 PM
    Geodude82
    I will upgrade the UCA eventually, but for now I was thinking near term. So you'd recommend bump stop extensions and a diff drop? Would dropping the diff effect the wheel alignment, wondering if I should wait to get the wheel alignment until after the diff drop or if it doesn't matter.
  5. May 19, 2021 at 3:53 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Has anyone had issues with the CV boots tearing with a leveling kit ( 2 1/2" ) ?
  6. May 21, 2021 at 7:48 PM
    cuaround
    cuaround New Member
    I have been researching this as well. Really want to level my 21 but don't want to have potential issues down the road like cv boots tearing or any other problems. Any info would be greatly appreciated.
  7. May 22, 2021 at 4:28 AM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    I had a 2001 that we bought new. Leveled it at 2.5" in the front and even with a differential drop kit it would go through boots in about 30K miles. I haven't been able to find any info on the 3rd generations. I have a 2019 Platinum that is getting leveled with 5100s at middle clip ( 1.5" ) and the wife will hang me if we have the same issues. :confused:
  8. May 22, 2021 at 4:51 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have a 3" lift, for 55,000 miles now, and I don't see any issues, cracks or tears.
    cuaround[QUOTED] likes this.
  9. May 22, 2021 at 4:52 AM
    Boerseun
    Ferdie
    Sarasota Florida
    I don't think you will have any issues with a 1.5" level.
  10. May 22, 2021 at 5:05 AM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    Thanks, you are the Man !
    Boerseun[QUOTED] likes this.
  11. May 22, 2021 at 5:11 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
  12. May 22, 2021 at 5:59 AM
    GaTundra79
    GaTundra79 New Member
    White 2021 SR5 4x4
    I had a lifted Tacoma, and it never had CV issues, just some vibrations in the driveline. So I've been really hesitant to mess with my Tundra. From what I've read, you don't really run into issues until you approach 3 inches (and some people not even then). I'm going to level it in the front, but keep it 2 inches or less.
  13. May 22, 2021 at 7:07 AM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    Good info, thanks
    GaTundra79[QUOTED] likes this.
