Super 60k Service
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tierhog, May 18, 2021.
  1. May 18, 2021 at 11:33 AM
    Tierhog
    Tierhog [OP] SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Well... it's on the rack. 59k
    Oil change, diff fluid change, Trans drain and fill, Brake fluid change, Tcase fluid replacement. Brakes (Rotor and pads).
    Might as well get the points lol
  2. May 18, 2021 at 11:43 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Are you doing this yourself or is a shop/dealer doing it? If so, how much are they charging? I need to get this done soon.
  3. May 18, 2021 at 12:14 PM
    Tierhog
    Shop is doing it. Denso parts only.
    $860. Bit stiff, but given the amount done.. it is what it is. I wouldn't dare touch the Trans and getting a bit long in the tooth to be laying on a concrete slab for half the day
    Keep in mind, these are California prices.
  4. May 18, 2021 at 12:16 PM
    gdiep
    Syracuse, New York
    That's a great price if you're getting new rotors and pads too.
    rockmup and Tierhog[OP] like this.
  5. May 18, 2021 at 12:19 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Agree, with pads and rotors and saving a day on your back, well worth it. Especially considering this is probably the most expensive maintenance and repair you have likely done with a toyota.
    MT Madman likes this.
  6. May 18, 2021 at 12:37 PM
    Taco-Spike
    Two Trucks
    I'm younger and don't mind being on my back working on my vehicles myself. But if you want to knock out another thing fairly easy and don't have to be on your back, MAFS and throttle body cleaning, only $20 in cleaner ($10 each cleaner) and an easy DIY, knocked out my Tacoma and my lady's Focus in under an hour a few months ago
    Tierhog[OP] likes this.
  7. May 18, 2021 at 1:25 PM
    Rocko9999
    Rocko9999 New Member
    Did you need brakes at 59k?
  8. May 18, 2021 at 1:28 PM
    Tierhog
    It is by far the largest maintenance day since new.
    So far only oil changes and air filters. Not anymore. If you take those past services st about $80 x 5 (50k )miles, plus an air and cabin filter ($50)
    450+ 860= $1,310 ÷ 6 years (almost) 218.33 per year excluding tires. Not bad.
  9. May 18, 2021 at 1:31 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Humm.. in my '16 all I ever did was oil changes and had just rolled 100K miles. Did change out the brakes at about 60K like you. Never did anything else though. Ran like a champ.
  10. May 18, 2021 at 1:33 PM
    Tierhog
    Yes and no. Not trying to be cryptic. I had some wheel wiggles under moderate braking over 35-40 mph to about 65mph. No squeaks or pulling. Had 7mm of Pad left, but wasn't going to try and true a Rotor or two at 60k and deal with the new pads bedding on a thinner Rotor to.be back in the shop with the wiggles again. Rather see him at 120k and do it over again..lol
  11. May 18, 2021 at 1:35 PM
    Tierhog
    It's an individual decision. Just following the book. Toyotas always run like Champs, but they need fresh fluids..
    NewImprovedRon likes this.
  12. May 18, 2021 at 1:46 PM
    rt_tundra_co
    rt_tundra_co I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    Why are the rotors needing replacing after 60k? Do you do a lot of heavy towing? Or as you just having them machined?
    Rocko9999 likes this.
  13. May 18, 2021 at 2:09 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    i think its because of the known vibration issue with these trucks and generally unspectacular OEM brakes.
  14. May 18, 2021 at 2:13 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    What about air filter, cabin air filter and coolant?
  15. May 18, 2021 at 2:16 PM
    Tierhog
    The AF was quoted in the cost per year and done at 30k. I'm likely to change again once at 60k by myself, purchasing through Amazon. Same with cabin. I can't screw that up..hahaha
    Coolant is 100k per the book.
    omgboost[QUOTED] likes this.
  16. May 18, 2021 at 2:17 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Oh I’m not knocking you for doing yours. Just giving my experience. I had just bought the rear diff oil to do mine but then someone hit me and totaled it. Probably do it a lot sooner on my new one.
  17. May 18, 2021 at 2:20 PM
    Tierhog
    That was the variable. At 60k if I machine the rotors, my fear is ill likely return to some run out in 15k. Then I'll have to replace rotors. Also I would have replaced the pads a second time. Why not replace all and get another 60k or so of flawless service. Seemed the risks weren't rationalizing the math.
  18. May 18, 2021 at 2:25 PM
    Tierhog
    Oh I see your logic, but.. everything was or would be due in less than 1k. It was and is currently convenient and in the case of bulk services, financially beneficial.
    Yeah.. someone could plow into me on the way home. It would suck, but outside of insurance, I can't prevent the unknown. I'm not silly about it though. I don't prepay my tags 6m in advance or anything.
  19. May 18, 2021 at 3:27 PM
    omgboost
    East Coast
    Somehow I thought coolant was 60k.
  20. May 18, 2021 at 4:21 PM
    Tierhog
    Thankfully no. It's 100k and I think the plugs are 110k.. then 120k do everything all over again...ugh
  21. May 18, 2021 at 4:23 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Just do everything a little early in 50k intervals, thats the way im going. Early cant hurt.
    Tierhog[QUOTED][OP] likes this.
  22. May 18, 2021 at 4:27 PM
    Tierhog
    I typically do that..like today. Bracketing several services either on time or slightly early reduces labor costs and down time
  23. May 18, 2021 at 6:09 PM
    rt_tundra_co
    '15 SR5 CM TRD
    I missed your post about having a shake already on the rotors. Nothing drives me nuts more than a car with not straight rotors. I'm seriously considering putting drilled rotors on my wife's car because OEM and smooth just doesn't work for her draggy brake foot.
    I have a buddy who has an '07 with 300k miles and he's on just his second set of OEM rotors and he tows somewhat frequently.
  24. May 18, 2021 at 7:31 PM
    Tierhog
    I'm bedding them in now. Time will tell. I'll take another 60k. Hopefully this is a semi permanent fix.
  25. May 19, 2021 at 4:28 AM
    mibpf
    mibpf 2021 TRD Pro Lunar Rock
    That is a great price and well worth it.
  26. May 19, 2021 at 4:47 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    I installed the rear sway bar on my truck about a month ago and took a nap when I was under the truck.
  27. May 19, 2021 at 5:54 AM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Good shade under there from my experience.
  28. May 19, 2021 at 7:13 AM
    Tierhog
    I did that install. After I got off my side, my back popped and it actually felt pretty good. I decided on a nap afterwards too. The only difference was my lazy boy and a glass of GF (scotch) over ice. I don't remember whether the nap was due to the work or the drink....but we'll earned it was!
    Bammer likes this.
  29. May 19, 2021 at 7:28 AM
    Tierhog
    From one airman to another (90-94) I trust you engage in some heavy reading, research, comparisons, and then rehash it here, only to then tirelessly find the best deal. I did so. Ended up back into standard Denso rotors and pads. I know most have great success with hawk,EBC,etc. I rarely tow or haul aside from a car or two and flagstone etc. I'm sure that buddy of yours likely resurfaced them at least twice at 150k before junking them. The runout is unavoidable. With 7mm I could have ignored it easily until 100k but I HATE steering wheel shimmy under braking. I'm intrigued at slotted or vented rotors but I don't use the truck to raise the risk profile of cracking (slotted) or price increase. I was bummed at changing them out so early, but am on the fence as to whether I have a thermal issue. I'll probably do some more reading.
    rt_tundra_co[QUOTED] likes this.
  30. May 19, 2021 at 7:53 AM
    Tierhog
    rt_tundra_co likes this.
