No idea where outer tie rods should be
Discussion in '1st Gen Tundras (2000-2006)' started by bewildered, May 19, 2021.
  1. May 19, 2021 at 1:34 AM
    bewildered
    bewildered [OP] New Member
    blue 2006 tundra sr5 v8
    I have a 2006 tundra sr5 v8
    My problem is being without any mark or measurement after a teering Rack r & r. No idea where outer toe rods should be ! Help
  2. May 19, 2021 at 1:45 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I had no real measurements either when I completely redid the front end on mine, but I just kinda eye-balled it close to straight, and vertical. Torqued everything down to spec before I took off.
    I eye-balled my camber, and my toe. Scheduled an alignment with a shop 50 miles away, and drove it there. Did okay, and I didn't worry about tire wear over 50 miles.
    The shop realigned everything I had misaligned.
  3. May 19, 2021 at 7:33 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I remember my outer tie rods were 19 turns on the passenger side when I did them. Same truck 2006, it got me close enough to go get alignment the next day.
  4. May 19, 2021 at 8:27 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    It will be different for just about any truck. Mine was around 14 turns for one side and 17 for the other.
    Get some cardboard, or some plastic trays like the ones at fast food places. Put the cardboard or trays under your front tires. Get a measuring tape and with the steering wheel straight, measure how much distance there is from inside edge to inside edge on front tires (passenger to driver) as close to halfway up the tire as possible. A stock tire is around 30" tall, so maybe make a mark 15" up the tire. Measure the same on the back side of the tire.
    Now you'll have a base measurement. You can spin the inside tie rods to pull the back side of the tires in or push them out. Try to get the distance even so that they are parallel. Then you can drive to an alignment shop for fine tuning.
  5. May 19, 2021 at 10:48 AM
    bewildered
    Thank you very much. I guess all i
    needed was a little moral support.
    Have a great day.
    P.s. you da man !
    Darkness likes this.
  6. May 19, 2021 at 1:11 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
  7. May 19, 2021 at 1:16 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
