starter suck
Discussion in '1st Gen Tundras (2000-2006)' started by ahappyguy, May 17, 2021.
  1. May 17, 2021 at 8:11 PM
    ahappyguy
    ahappyguy [OP] New Member
    Guy
    2000 4.7 V8
    Removed the 3 bolts on starter and unable to pull starter out - will not budge.
    Any tricks to loosen it up - already spray it with Blaster penetrating oil a couple of times?
  2. May 17, 2021 at 8:20 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Whack it side to side with a rubber mallet.
    JBSTOY likes this.
  3. May 17, 2021 at 8:26 PM
    ahappyguy
    Guy
    2000 4.7 V8
    I whack it many times - called Toyota service and he said to loosen the engine mounts and jack the engine - what would that do to?
    Though getting to those nuts is a challenge and don't see a way to jack up the engine - to much stuff in the way?
  4. May 17, 2021 at 8:54 PM
    TILLY
    Massachusetts
    Not sure why they would tell you that, pretty sure there are only 3 bolts that hold the starter, and you already removed them. Here's a few vids which might help, good luck
    https://youtu.be/Ilek4gjhRF4?t=4
    https://youtu.be/FoakaNILKZM?t=1
  5. May 17, 2021 at 9:01 PM
    ahappyguy
    Guy
    2000 4.7 V8
    Thank you and I viewed those before I took it apart - though no one ever mention about difficulty in pulling it out and could not find a reason for that happening. Will go back at it tomorrow if it stops raining - very strange...
    It stop working as I was out in the field pulling a trailer .
  6. May 17, 2021 at 9:04 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Maybe this will lighten your mood, lol...
  7. May 17, 2021 at 9:04 PM
    TILLY
    Massachusetts
    Good luck tomorrow, and let us know how you make out.
  8. May 17, 2021 at 9:04 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    All you can do is get something very thin but somewhat strong (chisel?) between the block and starter to try and start it to seperate. Lowering the trans won’t do jack. They might of been thinking removing transmission (they commonly get stuck on the dowels)
  9. May 18, 2021 at 4:59 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Hoping you get the old starter removed. Suggest upgrading to the HD Denso Starter which actually costs less than the light duty.
    Darkness likes this.
  10. May 18, 2021 at 2:51 PM
    ahappyguy
    Guy
    2000 4.7 V8
    Thank you, sprayed it with more Blaster penetrating oil. Have a friend who is a mechanic said electrolysis between the cast steel and aluminum head of the starter - probably welded them together. Used a thin pry-bar and hammer open up a pinch - still will not move. Already had purchase the 2.0kw starter for $99.89 from Napa with lifetime warranty.
  11. May 18, 2021 at 2:55 PM
    Fred
    Hand Protectors
    Maybe heat her up a bit with a torch. Be careful of the wire harness.
  12. May 18, 2021 at 3:01 PM
    ahappyguy
    Guy
    2000 4.7 V8
    Thanks, Yes and no - too much plastic, wires, hoses next to and in contact with it - will give it another day first. See if the penetrating oil will do the trick.
  13. May 18, 2021 at 3:12 PM
    TILLY
    Massachusetts
    Guy, stuff some rags into the intake ports, you don't want anything falling down into them. Good luck with the soak.
    bmf4069 and BubbaW like this.
  14. May 18, 2021 at 3:36 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Use a large punch (1/2" extension will work in a pinch) and try and tap on the bolt ears to rotate it left and right. See if that helps break it free.
  15. May 18, 2021 at 3:56 PM
    ahappyguy
    Guy
    2000 4.7 V8
    Yes, had the ports cover with two towels took them off for the photos. Only can get to one of the ears, the other one has a plastic cover over it - will see if I can get it off tomorrow.
  16. May 18, 2021 at 4:01 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  17. May 18, 2021 at 4:24 PM
    marsbar
    marsbar New Member
    Bob
    CO
    2018 DC Long Bed SR5 O.R.
    Leer cab high topper, Toytec Aluma 2.0 kit, + 1.5 shackles + deaver 3 leaf add, SPC UCAs, SPC LCA bolt kit, 295 70 18 Revo 3 tires.
    any chance you can apply power to it briefly? that may help pop it loose if if there is tension in the starter gear...
    or 2x4 + sledge - looks like you have access.
  18. May 18, 2021 at 7:17 PM
    empty_lord
    05 rollover special
    Likely won’t do anything other than risk the engine turning over and letting shit into the cylinders I’m afraid. Best practice here is rust penetrant and a little bit of heat.
  19. May 18, 2021 at 7:24 PM
    Also isn’t the coolant supposed to be pink? If you look at the passenger side puddle, do you notice anything else hanging out in there?
  20. May 18, 2021 at 8:11 PM
    terrward
    terrward New Member
    2004 DC SR5
    Heat it with some map gas and give’r a few good whacks with a 3lb sledge. You’re replacing the starter anyways so you don’t have to be gentle.
  21. May 19, 2021 at 9:28 AM
    ahappyguy
    Guy
    2000 4.7 V8
    Thank you all - finally the starter is unstuck - from the small bar to a wonder bar then my son 39, 6'2" 275 lbs. and a three foot crow bar broke it loose.
    ahappyguy
  22. May 19, 2021 at 9:30 AM
    TILLY
    Massachusetts
    :thumbsup:
