Ride height difference TRD vs Stock
Discussion in '2.5 Gen Tundras (2014-2021)' started by babyyodacuh, May 17, 2021.
  1. May 17, 2021 at 10:20 AM
    babyyodacuh
    babyyodacuh [OP] New Member
    I cannot tell and cannot find an answer by searching (not very good a searching either, :()
    anyway, while driving around I see TRD 4wd and they look to sit significantly different than my non-TRD 4wd. Is everyone running a level/lift or are my eyes deceiving me. I am wanting to know to decide how much of a spacer level to do
  2. May 17, 2021 at 10:21 AM
    Twowheelssoar
    Twowheelssoar New Member
    NC
    2021 Cement SR5 6-Seater
    They should be exactly the same, stock.
    babyyodacuh[OP] likes this.
  3. May 17, 2021 at 10:22 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    The TRD PRO is 2 inches higher than the other trims in front. Rear is the same. That is only for the actual TRD PRO Tundra, not a Tundra with the TRD off road package.
    And look at the pros/cons of a spacer lift. Can be ok on the street, but a NO NO if you wheel the truck. The suspension forum here has lots of good info about the different options for lift/leveling.
  4. May 17, 2021 at 10:24 AM
    They could have a leveling kit, Bilsteins, or even larger tires. Now if its a TRD Pro, they do sit higher than the rest.
  5. May 17, 2021 at 10:56 AM
    Twowheelssoar
    NC
    Should clarify, I was talking TRD Off-Road package vs. without. A TRD Pro is going to be level.
  6. May 17, 2021 at 12:14 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    I added 2 inch longer shocks up front to level my SR5 TRD off road.
    It now sits level and just like the TRD Pro.
    PS. You'd be surprised how much more of your rear view mirror can be used now instead of seeing your bed.
    babyyodacuh[OP] and Bigkitchens like this.
  7. May 17, 2021 at 12:26 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    As others have said above, non-TRD and TRD should all be exactly the same. Different wheels and tires ( for instance SR's steelies vs TRD alloy wheels and AT tires) might give it a visual different appearance, but should be the same.
    I have a spacer lift; a lot of guys will warn against it. I probably spend more time off-road than most with their expensive suspension lifts do (as in every day for work), and I have never had any issues, so I don't agree with them. However, for not a lot more $$ you can do Bilstein 5100s and you don't have to worry about them harassing you.
    Before you decide on a leveling kit, measure your truck. They seem to be all over the place for apparently similar trucks. I have a 3/1.5 and I am dead level. Some do 3/1 and are level, and some do 2.5/1.5 and are level. The TRD pro is 2" higher in the front with nothing in the back and is level. If I had 2" in the front with nothing in the back I would have been nose-high.
  8. May 17, 2021 at 12:57 PM
    babyyodacuh
    I ran a 3/1 on my 15 F150 with 35”. The 35 were to big IMO with that set up. I don’t really do a lot of “wheelin’”, I just need more ground clearance for where I do go hunting and fishing. I am going to dump the stock 20”s and get some 17 or 18” and probably a leveling kit. IDC what others say about how mine is set up. I know how I use it and it is not a road Queen but I am not rock crawling either.
    thanks for the input all!
    Joro43, 15whtrd and Boerseun like this.
  9. May 17, 2021 at 1:03 PM
    Boerseun
    Ferdie
    Sarasota Florida
    35"s can get you into rubbing. Mine is about 34.5". I kept my 20" wheels so I tried to get as much sidewall as possible because I don't like low profiles on a truck. If you go 18" wheels I would say a 34" tire is big enough. There is a relatively big difference between a 34" and 35" when it comes to rubbing or not.
  10. May 17, 2021 at 3:49 PM
    babyyodacuh
    Boerseun[QUOTED] likes this.
  11. May 17, 2021 at 4:29 PM
    GaTundra79
    GaTundra79 New Member
    White 2021 SR5 4x4
    Maybe a dumb question, but I see a lot of suspension lift kits come with a diff drop kit included - do they drop the diffs on the pros?
  12. May 17, 2021 at 4:55 PM
    15whtrd
    15whtrd Mr. Blonde
    Nope. From some of the pictures I’ve seen it doesn’t look like it really changes the angle of the CVs. But it does tip your diff forward changing the fill location and how your pinion rides in the oil bath.
    https://www.tundras.com/threads/when-is-a-diff-drop-needed.11593/
    GaTundra79[QUOTED] likes this.
  13. May 17, 2021 at 5:04 PM
    GaTundra79
    White 2021 SR5 4x4
    Thanks for the information!
    15whtrd[QUOTED] likes this.
  14. May 17, 2021 at 5:54 PM
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
    I call bullshit on this big NO NO if you wheel the truck. My last set up was pro Comp stage 1 which is a giant spacer. It was plenty capable off-road: whoops bumps rocks etc... eventually when my ball joints wore out I upgraded to SPC UCA and converted the front to full coil overs and granted it definitely handled better off road, but I’d say 60-70 percent of the 6” lifts you see on trucks are not full coil over but strut mount spacers. At the end of the day it gives you better clearance to accomplish most things off road. That is unless you want to Baja a $60k truck and jump your rig at the dunes
    Boerseun likes this.
  15. May 17, 2021 at 6:00 PM
    Joro43
    Joro43 New Member
    That’s my truck with a 3/1 pro Comp lift kit the previous owner installed. I wish he’d have opted for the 4/2. I just ordered a new set of BF KM3 in 295/70/18. Still debating on upgrading to the rough country full coil over 6” lift kit and going with 35/12.5/20 instead of the 295s
