Stalled in drive after rolling backwards
Discussion in '2.5 Gen Tundras (2014-2021)' started by Applegate Tundra, May 14, 2021.
  1. May 14, 2021 at 7:29 PM
    Applegate Tundra
    Applegate Tundra [OP] New Member
    Aubrey
    2018 Platinum Tundra 4x4
    In progress
    Hi all. New here and seeking your knowledge.
    I wanted to test out the possible hill assist with my 2018 platinum 4x4 so I parked on a slope that was enough to roll back a bit. When doing so the truck did nothing at first but about 20 feet into the backwards roll it did a noticeable jolt and then stopped. Then it seemed like the motor shut off. No throttle response and check engine light appeared. I turned the key into the off position. Started it up and I feel like it took a bit longer than normal to start. Truck then performed normal, then I put it into gear and a left.
    any ideas? Does my tundra have a shut off feature like this. I should add that no check engine light remains once I restarted it.
    thank you
  2. May 15, 2021 at 4:12 PM
    Shifless Joe
    Shifless Joe New Member
    Mesa AZ
    2016 TRD Off-Road
  3. May 15, 2021 at 5:14 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Tundras do not have hill assist. How were you letting it “roll backwards” ?
  4. May 16, 2021 at 12:13 AM
    Applegate Tundra
    Aubrey
    In progress
    I was on maybe a 10% grade in drive at a stop. Took my foot off to see if it had a hill assist and let it roll back a bit with nothing happening. Then the shutter and then the stall.
  5. May 16, 2021 at 12:22 AM
    Applegate Tundra
    Aubrey
    In progress
    Thanks for the read. Seems like It’s “normal” ? Put me at ease a bit but still strange. I was just messing around with the truck to see what it could or couldn’t do and I ended up scaring myself thinking I just messed up the truck after owning it for two days.
  6. May 16, 2021 at 4:01 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I don't know what years have the hill start assist but this is from the manual in my 2021. Also a thing to note is that it helps when going from reverse to drive like when putting a boat in, I'm not so sure it helps when you are on a steep hill in drive and you let off the gas, I haven't tested that yet.
  7. May 16, 2021 at 4:14 AM
    timsp8
    NY
    Also this at the bottom.
    But I don’t think he was activating a start assist. I think he was already running and let it roll backwards. Truck probably shut itself off to protect itself and not tear anything up.
  8. May 16, 2021 at 4:40 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Yeah, that's what I thought, that he just wasn't in the right conditions for it to activate.
  9. May 16, 2021 at 5:23 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    This happened to me as well, somewhat steep hill. I probably should have put the truck into [R] before backing up but I'm used to driving a stick shift and would naturally have the clutch pushed in.
    Applegate Tundra[OP] likes this.
  10. May 16, 2021 at 8:40 AM
    Applegate Tundra
    Aubrey
    In progress
    Thank you for the responses everyone.
    LarryDangerfield likes this.
  11. May 16, 2021 at 9:42 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    That is insane. I'm looking inside my 1997 T100 for the buttons to engage all those features. But...........alas, nowhere to be found. Unless I overlooked. Here. You can look with me and tell me if I missed them.
  12. May 16, 2021 at 3:51 PM
    timsp8
    NY
    Take a look inside your 2017 Super White Tundra.
