  1. May 15, 2021 at 8:44 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Gotta fab brackets. Sequoia has a larger condenser with the mounts built in.
  2. May 15, 2021 at 8:56 PM
    It’s super hard not to pin the skinny pedal!!!
    There’s always one guy on the commute to work that needs to be shown how it’s done, that’s why I just calculate smiles per gallon now. I try to be conservative but it feels to good when you let her loose!!!
  3. May 15, 2021 at 9:04 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Oh yea. Figured that much. Just like the fan because it’s like 4 bucks at the junkyard
    KarmaKannon likes this.
  4. May 16, 2021 at 12:25 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Wired my chase lights. It took a lot longer than expected, but I'm pleased with the results.
    jerryallday and jImmegart like this.
  5. May 16, 2021 at 4:10 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  6. May 16, 2021 at 7:34 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Anyone have the Spec on the Wheels Lugs Torque FtLbs.?
    OEM Acorn Nuts with Starfish Rims. For some reason, I can’t find it with all the others in the FSM. Thank you.
  7. May 16, 2021 at 8:09 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
  8. May 16, 2021 at 8:50 AM
    empty_lord
    05 rollover special
    Technically they’re not acorns, they’re shank style
  9. May 16, 2021 at 10:36 AM
    Pearl-snap
    Pearl-snap New Member
    Getting the wiring started in order to install a Kenwood DDX9907XR and a Master Tailgaters backup cam.
    it’s going to be fun trying to locate the Reverse, park, and VSS wires
  10. May 16, 2021 at 11:12 AM
    Fred
    Hand Protectors
    Got her out on some Open Highway, as yesterday was just neighborhood drives in case she broke down and could limp home. :rofl:
    She has changed a little for the better for sure.
    bmf4069, jerryallday, MS22 and 3 others like this.
  11. May 16, 2021 at 11:23 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Five Star Car radio was a big help when I installed new HU last year.
    When you say “park” are you meaning parking brake ? If so, the below video shows where to connect at back of radio without going to parking brake….simply looking for gnd.
    https://m.youtube.com/watch?v=gOk4fXL0XBU
    As for VSS, as of 2019, Kenwood put out update that does away with having to hook up VSS with in regards to car play. Apply latest update if needed.
    https://m.youtube.com/watch?v=Ji1wMHUgyIU
    Pearl-snap[QUOTED] likes this.
  12. May 16, 2021 at 11:26 AM
    Pearl-snap
    Thanks for the info on grounding the park wire. What I’ve read is that Kenwood did away with VSS and it helps the wireless CarPlay function. I was wondering if it is still necessary for the DVD player to work, just in case I want to watch a movie while waiting in the drive through lane at the bank :)
    BubbaW likes this.
  13. May 16, 2021 at 11:32 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    I'd have to get another bank if I had to wait that long :eek::D
  14. May 16, 2021 at 11:51 AM
    Pearl-snap
    :D:D:D Yeah, it can be 5 min or 30 depending on the time of day.
    As far as the video demonstrates, you can ground the park wire to any of the tiny screws on the back of the unit? Don’t want to unnecessarily complicate things, but I could also ground it to any bolt connected to metal supports?
  15. May 16, 2021 at 11:53 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Indeed, the screw to radio is shorter run obviously !
  16. May 16, 2021 at 12:12 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    or did the bolt rust / expand / split the mount from inside out?
  17. May 16, 2021 at 12:31 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    187329028_10159113853715275_677139059987_d230b1266af3741b5cc3aba463a58c3987916feb.jpg
    MC was the ticket... no dragging, brakes feel great. Gonna finish my skidplate and degrease the truck, but i dont want degreaser in my yard, so i have a tarp and collection bottle. Might do it at the self serve carwash closer to SA where theyre on city water.
    glad to have done the hoses, pads, and rotors as they were due, but also to find the rest of the flaws under the front end. Cv’s bushings, uca’s, etc. so, my next steps can be bundled.
    hammeron, oscardog86, bmf4069 and 4 others like this.
  18. May 16, 2021 at 12:35 PM
    Fred
    Hand Protectors
    Which Brand MC did you go with?
    Any pics of the old plunger for review?
  19. May 16, 2021 at 12:51 PM
    Is that even possible? If that was the case, I think a lot more people would be experiencing the same issue.
  20. May 16, 2021 at 1:08 PM
    CCCFCA50-8760-4234-88DA-FDD3A2902E19.jpg Good catch @NUDRAT, guess you are 100% correct…weird for that to happen.
    NUDRAT likes this.
  21. May 16, 2021 at 2:09 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    186472598_10159114265455275_419061169521_947a5d4780e0332c956ebfd0d5d423fde2baa5ac.jpg
    Raybestos. piston stuck in. Happened when bleeding, could tell when, but seals mustve been comprimised, cause brakes were dragging, and it got worse as it heated up. And it was even across the front, like both sides grabbed evenly.
    184580009_10159114278915275_175793536522_49e63993ff8873e056497e7786392849ce6d9176.jpg
    Made it down to the river, didnt drive in. Call it a win.
    hammeron, bmf4069, NUDRAT and 2 others like this.
  22. May 16, 2021 at 2:10 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
  23. May 16, 2021 at 3:12 PM
    Fred
    Hand Protectors
    Looks like your PCV is clogged considering that oil ring around the external. Or did you just replace it?
    NUDRAT likes this.
  24. May 16, 2021 at 3:19 PM
    PCV valve was replaced 6 months ago. I even blew on it to double check and it still worked. I'm guessing its a valve cover leak.
  25. May 16, 2021 at 3:21 PM
    Fred
    Hand Protectors
    Yeah. I thought I remembered that you replaced it. Good job. Now lets get that VC Gasket Job done! Or, is it the Cam Seals Leaking? Its all coming back to me now.
  26. May 16, 2021 at 4:02 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  27. May 16, 2021 at 4:02 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    always parking next to a tundra when I get the chance!
    hammeron, oscardog86, bmf4069 and 5 others like this.
  28. May 16, 2021 at 4:05 PM
    NWPirate
    Zach
    WA
  29. May 16, 2021 at 4:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Dumplins :hungry:
    If I'd had a better knife, and a place to store the meat I'd have turned around and cleaned it.
    It was a clean kill. That ditch light caught her mid body. A square impact, and a bunch of feathers floating down
    NWPirate[QUOTED] likes this.
  30. May 16, 2021 at 4:21 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Sounds like you had a hen you were dealing with :notsure:
