2wd - Strut Rod Bushing - Part Confirmation Please
Discussion in '1st Gen Tundras (2000-2006)' started by hammeron, May 13, 2021.
  1. May 13, 2021 at 3:03 PM
    hammeron
    hammeron [OP] New Member
    2002 Tundra v8 Blue 2wd
    Was having a UBJ + LBJ pre-surgery consultation (PHM style) with my baby and
    was bummed to see that I will now want to replace the strut rod bushings when I do the
    ball joints.
    If it's not one thing, it's another....
    I'm pretty sure these are original equipment, because I purchased at 115k.
    I do not want to replace the struts, I just want to replace the bushings, if that is
    something a part-time, weekend warrior wrench-er can do at home, safely.
    RockAuto has them cheap, if these are indeed what I need. Please confirm.
  2. May 13, 2021 at 3:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It's possible, but at 115k I would at least look at the cost of bilstein 5100s. You can reuse your coils. Mark the drivers side with a piece of tape so you don't have to remember color codes.
    You'll have to take the coilovers out anyways.
    @Darkness @bmf4069 @Professional Hand Model
    3.4Tundra, hammeron[OP] and Darkness like this.
  3. May 13, 2021 at 3:36 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I would just replace the shock and be done. Buy shocks, pull the whole assembly, take it to a shop and have them swap the shocks out for you. Then you just put them back in. If you can change a tire you can do this. If you need step by step let me know, 2wd is easier.
    To do the bushing you need to remove the whole assembly anyway and I can't be sure that the bushing you're looking at fits properly. You're looking at the same amount of work.
    3.4Tundra, des2mtn, bmf4069 and 4 others like this.
  4. May 13, 2021 at 3:55 PM
    What @Darkness said, but if you want to go el cheap, then order a Bilstein 4600 bushing and have the old one pressed out and the new one pressed into it.
    I went this route, total cost was $40 per side.
  5. May 13, 2021 at 4:27 PM
    hammeron
    thanks all, i am ok with buying new shocks, pulling the assemblies and taking them
    to a shop.
    it's my work truck and was hoping to skate by, el cheapo.
  6. May 13, 2021 at 4:38 PM
    There is a way to change shocks without using spring compressors, but it involves loosening the LCA CAM alignment bolts, disconnecting the LBJ/stabilizer links and doing a controlled release of the spring with a floor jack securing the LCA IIRC. The center bolt for the shock would be disconnected as well. There’s videos of it out there.
  7. May 13, 2021 at 4:45 PM
    hammeron
    way above my comfort zone, i am just barely competent enough to do the ball joints and that is pushing the envelope.
  8. May 13, 2021 at 5:30 PM
    You picked the right choice as it'll end up being cheaper than trying to replace the bushings.
