Bed Slide
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rando63, May 12, 2021.
  1. May 12, 2021 at 11:48 AM
    Rando63
    Rando63 [OP] New Member
    2019 Toyota Tundra
    Hello, I have a 2019 Toyota Tundra ext cab and was wondering if anyone knows if they have installed a bed slide and if there is anything I should look out for when drilling a 1/2” hole in 4 locations for the bolts in the bed the bolts are short, what should I look out for when drilling in the bed, gas tank, wires, etc.
  2. May 12, 2021 at 11:57 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    You could try doing a little groundwork and research yourself first.
  3. May 12, 2021 at 12:27 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    Look under the bed before drilling!
    Maybe you can suggest any single thing under there that you think would be OK to drill through?
  4. May 12, 2021 at 5:04 PM
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    I used a center punch in the bed, then would climb under the truck to look for the dimple and make sure it’s clear. A6C99982-6D55-42C2-B7EE-B8EFA8C09F56.jpg
    thearborbarber likes this.
  5. May 12, 2021 at 5:07 PM
    sea_weathered
    Pacific Ocean
    I also made flat straps under the bed, and painted the holes. for overkill sake.
    Wilzer, 15whtrd and eick like this.
