Easiest way to get sub boost cable from panel to under pass seat?
Discussion in 'Audio & Video' started by redrum448, May 9, 2021.
  1. May 9, 2021 at 4:51 PM
    redrum448
    redrum448 [OP] New Member
    Borrowed this pic from another user but it works.
    So I put my sub boost knob in a blank spot on this panel and I cant see a way to get the cable under the console easily. I push the cable down but something blocks it.
    Is there an easy way to get it to under the center console without taking the console out?
    thanks!
  2. May 9, 2021 at 6:19 PM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    Probably not an easy way without taking the center console out, but taking the center console out is so easy, it's typically not worth considering an alternative.
    Dave
  3. May 9, 2021 at 6:23 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    You don't have to take the whole console out. Just remove the shifter knob and pop the top off it. Should be threads in the audio forum.
  4. May 9, 2021 at 10:28 PM
    redrum448
    I have popped the top...but when I start pushing the wire down something blocks it and it never show up on bottom
  5. May 12, 2021 at 5:14 AM
    redrum448
    Here maybe this is a better picture....
    I keep pushing a coat hanger down (in the blue area) trying to reach beneath the center console (red area) but its blocked.
    Anyone know for sure which area would be best?
  6. May 12, 2021 at 11:39 AM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    You'll see even with most everything out, there's still vents and wiring and other crap in the way, but I can't imagine with the front part of the console out that you can't drop something down the side and route it through to the front...
    Dave
