Tundra hood scoop
Discussion in '2.5 Gen Tundras (2014-2021)' started by Franco4x4, Apr 18, 2021.
  1. Apr 18, 2021 at 9:21 AM
    Franco4x4
    Franco4x4 [OP] New Member
    2019 tundra CM
    Has anyone bought this from sparks and had it color mated? Wondering what the price would be.
  2. Apr 18, 2021 at 9:34 AM
    BravoDeltaRomeo likes this.
  3. Apr 18, 2021 at 9:39 AM
    Franco4x4
    2019 tundra CM
    On spark parts it says the hood scoop doesn't come painted/color matched. I was wondering if someone has bought this and took it to there local shop to get painted. How much would something like this cost to paint.
  4. Apr 18, 2021 at 9:40 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Sounds like something you need to ask your local paint shop. I suspect prices can vary wildly depending on where you are.
  5. Apr 18, 2021 at 9:40 AM
    RobertD
    Robert
    DFW, Texas
    You can paint it yourself. An aerosol can of color matched paint will run you 25-30 and then you need some automotive clear which runs 15-25 depending what you get. The scoop is a pretty simple color so you should be able to do it yourself.
  6. Apr 18, 2021 at 9:42 AM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Hood scoop p/n 7618134900 - $394.77 (the one I looked at says "Hood L Color" so I assume it IS painted.
    A few other pieces are required as well.
    https://parts.longotoyotaofprosper.com/oem-parts/toyota-scoop-7618134900
    P.S. I've found them to be cheaper (only if I pick up locally.....check your dealer too. Order online with "pick up" instead of shipping, you'll most likely find it cheaper than the one you mentioned after you include their shipping price)
    619Tundra likes this.
  7. Apr 18, 2021 at 9:44 AM
    Franco4x4
    2019 tundra CM
    Yes the actual hood scoop.
  8. Apr 18, 2021 at 9:48 AM
    Franco4x4
    2019 tundra CM
    Was just hoping I would get some numbers from others that have done this before I order.
  9. Apr 18, 2021 at 9:54 AM
    Franco4x4
    2019 tundra CM
  10. Apr 18, 2021 at 9:55 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Figure out the cost of the scoop, shipped to your door, by the vendor of your choice.
    Then call a couple local shops and ask how much to paint.
  11. May 12, 2021 at 8:08 AM
    toyohtadude
    toyohtadude Old man with a young mind....
    Eric
    Austin, TX
    2017 Tundra CrewMax SR5 4x4
    So the plastic scoop without the parts included is cheaper than the entire metal hood? Holy crap!!!!!!
