Kings shocks gonna be delivered in 3 weeks
Discussion in 'Suspension' started by Merkopac661, Feb 9, 2021.
  1. Mar 11, 2021 at 10:29 AM
    Merkopac661
    Merkopac661 [OP] New Member
    White 2018 Tundra Sport 4x4
    Yep. It’s been so long the money I spent on them doesn’t hurt at all anymore. But yeah I can’t wait.
  2. Mar 15, 2021 at 10:48 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    I've been trying to hunt down a pair of Kings. All the responses I've got say 4-5 month lead time for Kings. Beyond being disappointed, I'm shocked. I already ordered new UCA's so I'm in a pickle. Do I scope out other manufacturers? Are they in the same situation?
  3. Mar 15, 2021 at 11:25 AM
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    There are a couple full and partial sets on marketplace and Facebook forums.
    JimboSlice413[QUOTED] likes this.
  4. Mar 15, 2021 at 11:31 AM
    irishpride114
    Travis
    But if you want new ones, order now. 5 months isn’t that long in the grand scheme of things.
    I hear really good things about ads. Mcm is suppose to be good in dialing them and customer service in general. Like Kings, they can valved how ever you want and have adjusters installed. They also came up with a shackle and rear spring combo that is suppose to be awesome.
  5. Mar 15, 2021 at 1:54 PM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    Are you ordering OEM replacement sizes or for something like a Pro Comp. I ordered mine last year through SoCal SuperTrucks and had them in two months. Mine were custom sizes too.
  6. Mar 15, 2021 at 1:59 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    $1000 with clickers for sale right now
    https://www.tundras.com/threads/kin...-clickers-1000-central-wi.84967/#post-2143054
  7. Mar 15, 2021 at 3:15 PM
    irishpride114
    Travis
  8. May 5, 2021 at 9:46 PM
    Merkopac661
    Ok so my kings finally arrived at 4wp. Think I ordered last June. Gonna get installed in next couple days hopefully. Ill post some pics and reviews after the install.
    alb1k and pandapro like this.
  9. May 5, 2021 at 10:42 PM
    pandapro
    pandapro New Member
    Boss offroad had a few unclaimed sets that were arriving at the end of this month as of a few weeks ago. These did not have the adjusters and were not the extended travel ones. Might want to check with them if you don’t need the extra travel or adjusters.
  10. May 6, 2021 at 5:32 PM
    JimboSlice413
    Bakersfield
    Thanks for looking out. After reaching out to multiple venders and seeing the road ahead, I preordered a set with Accutune. Its going to be a wait but at least I'm in line. I ordered a couple of days after that post and if I'm on the good side of the lead time estimate, I may see them at the end of next month.
    AccuTune Offroad and Vang530 like this.
  11. May 10, 2021 at 8:30 AM
    21SXmachine
    21SXmachine New Member
    Black 21 SX
    Whats the going rate?
  12. May 10, 2021 at 8:41 AM
    JimboSlice413
    Bakersfield
    For extended length with adjusters, I believe it was 2300 out the door.
  13. May 10, 2021 at 8:42 AM
    irishpride114
    Travis
    What was the reason for the extended lengths?
  14. May 10, 2021 at 8:44 AM
    JimboSlice413
    Bakersfield
    It's not much extension at all, somewhere under 2 inches. But if you go through the expense of new UCA's, which I have, you may as well take advantage of the benefit. They dont cost any more than standard length
  15. May 10, 2021 at 8:56 AM
    irishpride114
    Travis
    Interesting. I have aftermarket uca’s and kings front/back. When I got mine, extended lengths were more expensive and King told me they weren’t recommended when I did my consult with them.
  16. May 10, 2021 at 8:56 AM
    irishpride114
    Travis
    Interested to see what you think about them once they get put on and get used.
  17. May 10, 2021 at 11:25 AM
    JimboSlice413
    Bakersfield
    It's going to be a while but when I get them on I'll do a little write-up. I bought some pretty uncommon uca's and I'd like to give them a review all at the same time
  18. May 10, 2021 at 11:30 AM
    snivilous
    SW UT
    All Kings are "extended travel", the only difference is the "normal ones" have a spacer inside from what I've read that limits droop. So regardless which Kings you buy, everything is the same just one has a spacer to limit the droop which can be removed.
  19. May 10, 2021 at 12:19 PM
    JimboSlice413
    Bakersfield
    There was a thread on this where a forum member posted an email from King regarding the two versions. There is a spacer and the shafts are a different length. The shaft part number was given and can be purchased directly from King
    irishpride114 likes this.
  20. May 10, 2021 at 3:00 PM
    #50
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Not quite. King does not have a standard and extended length shock available for every vehicle. For some vehicles, a "-EXT" Extended Travel version does not exist. NOT all standard shocks have a internal spacer that can be removed to be converted into an Extended Travel shock. Some can, but not all.
  21. May 10, 2021 at 3:32 PM
    #51
    snivilous
    SW UT
    Guess I should've clarified, all Tundra Kings. Though it sounds like the shafts may be different too (though not sure the point of the spacer then?).
  22. May 11, 2021 at 9:07 PM
    #52
    Merkopac661
    DB0D6A24-DA9E-48A6-9D3C-71617B7BD683.jpg AF22F670-EECD-44A6-BF7F-E89D4DEE9DEA.jpg 3E44A3BB-34DF-44C0-B0DB-84CE3F3037A6.jpg 3356A39E-060A-4260-84CF-9C94E3F167FD.jpg CEB01DDF-F63B-4A69-8361-F9EB63C49353.jpg FINALLY
    El Two, ColoradoTJ and saybng like this.
  23. May 11, 2021 at 9:08 PM
    #53
    Merkopac661
    Gonna paint the swaybar black
  24. May 11, 2021 at 9:21 PM
    #54
    Merkopac661
  25. May 11, 2021 at 9:25 PM
    #55
    Merkopac661
    It rides nice. Definitely sucks up the bumps. I’ll mess with the clickers and see what’s up with that. They look badass
