I messed up and now I need help.
Discussion in 'General Tundra Discussion' started by TucsonTundra1794, May 11, 2021.
  1. May 11, 2021 at 4:33 PM
    TucsonTundra1794
    TucsonTundra1794 [OP] ASCM #6-11 I'll buy if you're willing to ship
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Ok, so I knew from the start when I purchased an open box item that I was going to have to put some work in. I purchased some steps from extreme terrain for my tundra, they only had them avaliable in open box and 1 said it was scratched and dented in several places and the other said missing non-essential hardware. I went for the missing hardware as that would be easy to aquire. Well they showed up and not only are you scratched up as well but they are missing some very Essential hardware. Particularly the brackets that connect the steps to the L brackets under the truck. Here is a picture of the missing pieces on the instructions (6mm double bolt plates) and here is where they go on the steps. Already contacted extreme terrain and the manufacturer, both said good luck. Can anyone help me locate something like this or give me some ideas to make the steps work without them.
    Thank you.
    Link to product
    https://www.extremeterrain.com/barr...590465467050880513&sgs=10008#AspotProductDesc
    BlueRibbon4x4 likes this.
  2. May 11, 2021 at 7:34 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I'd get some steel or aluminum 1.5" wide flat bar stock from Home Depot, and cut pieces to the inner width of that channel.
    Then you could either weld some studs onto the bar or just drill holes and use bolts with a lock washer and nuts or nylocs.
    Looks like you maybe could get a wrench on top of there when tightening. If not, you may have to weld them.
    You could drill holes and then weld the top of the bolts to the bar, which would be easier than welding studs on the bottom.
    The brackets look like their slotted so you can adjust the steps in or out a little, so as long as you put the bolts at 2", centered, you should be able to get it all lined up.
    This is a much better problem than missing the brackets themselves.
    Boerseun, Tundra234 and BlueRibbon4x4 like this.
  3. May 11, 2021 at 7:39 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
  4. May 11, 2021 at 7:43 PM
    Azblue
    The Dirty T ( ^_^)_且
    So you just need the flat piece of steel maybe with a bolt welded on? What side of town are you on? We could knock that out in my garage in a few minutes.
  5. May 11, 2021 at 7:52 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I'm central (22nd & alvernon) and I have no experience welding at all.
  6. May 11, 2021 at 7:55 PM
    Azblue
    Eastside (Speedway and Harrison). I have the tools.
  7. May 11, 2021 at 7:58 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Sweet! I'm working crazy hours right now but maybe we can work something out for next week? I'll pay too.
  8. May 11, 2021 at 8:00 PM
    Azblue
    Na, no payment. Just figure out what you need and PM me when ready.
  9. May 12, 2021 at 4:56 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    You're a good person
    Azblue[QUOTED] and hagrid like this.
  10. May 12, 2021 at 5:21 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
  11. May 12, 2021 at 6:06 AM
    Bammer
    Monroe, CT
  12. May 12, 2021 at 6:09 AM
    NoRcptn
    NorCal
    2017 Platinum
  13. May 12, 2021 at 6:57 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
  14. May 12, 2021 at 7:40 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    + a googol :D
  15. May 12, 2021 at 7:52 AM
    AZBoatHauler
    So.Arizona
    @TucsonTundra1794 i know he’ll accept some beers as a token of gratitude!
    Azblue[QUOTED] likes this.
  16. May 12, 2021 at 8:59 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    We have that in common! I'll grab some on the way over.
    Azblue likes this.
