Welcome to the Official SoCal BS/ Shenanigans, Tundras and NEW GUY JOINED TO FIND MEET-UP Thread
Discussion in 'California' started by Sunnier, Dec 21, 2017.
  1. May 10, 2021 at 9:13 AM
    #9661
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Another personal experience with window suction mounts with heavier objects - temperature seems to play a roll in suction. Hot windshield suddenly gets the defrost vent with cold air? Bye-bye tablet.
  2. May 10, 2021 at 10:36 AM
    #9662
    Sunnier
    Sunnier [OP] Pity the warrior that slays all his foes
    Sunny
    San Diego, CA
    Long term I plan to create a metal mount that hugs the floor between and just forward of the front seats, bolted at each side with the front seat bolts, and a riser up to where I want the tablet.
    Before I do, I keep meaning to see if there’s a larger or taller console I can replace the original with, maybe from a Sequoia.
    des2mtn likes this.
  3. May 10, 2021 at 10:54 AM
    #9663
    des2mtn
    Shady Grove
    Tonto cover
    That's a very good idea, could mount other stuff too if it's sturdy enough. You've got my mind going haha..
    With a Sequoia/ DC console on an AC you might be able to stick a narrow radio something in this spot that looks okay. I'm limited on space back there because there is a duct that goes to my rear vents where the blue squiggles are.
  4. May 10, 2021 at 12:24 PM
    #9664
    Sunnier
    Sunny
    San Diego, CA
    :rolleyes:
    How tall is the part of the console between your seats? Mine is really low... not as tall as to be an armrest. What id like is a taller console = more storage.
    I’ve measured everything, and I’m “fairly certain” :rolleyes: the ham unit will fit if I can disconnect the metal box that holds the cup holders (I’ve already pulled out the cup holders). There should me no conflict with the depth limitations created by that vertical metal whatsit behind. But it seems I will have to take off the entire dash to remove that box, and only then will I know if it’s actually attached to the firewall and a main support of the dash... which I’ve read. Doesn’t look like it from what I can see. :fingerscrossed:
    I’m guessing if I head over to @Professional Hand Model ‘s build thread, I may find some pics to aid me in removing the dash, but searches specific to what I want to do haven’t led me anywhere helpful.
  5. May 10, 2021 at 1:13 PM
    #9665
    des2mtn
    Shady Grove
    Tonto cover
    PHM's thread is a good place to stop and learn periodically no matter what.
    My center console has lots of room and is deep, I like it. They come with a tray to hold plastic CD case but I took mine out. I've never seen an AC console so I can't compare the dimensions. I could use it as an arm rest if I wanted but it would be a tiny bit awkward. It's about half an inch lower than the armrest?
    I think the console comes up to about 15.5" from the floorboard. Arm rests come to around 16"-16.5". Here's some awkward pictures I just took, don't mind the junk everywhere.
    In regard to removing the dash, are you talking about#1 or #2 below? If #2, there are five screws located at the yellow circles, then you just gently go around and pry it out. There's four bolts that hold the head unit tray, removing that gave me more room to work when I added that ball mount. Not 100% sure on removing #1 though. I read that the air bag cover can't removed not that it should be in your way.
  6. May 10, 2021 at 1:20 PM
    #9666
    Sunnier
    Sunny
    San Diego, CA
    Thank for the pics of your console, looks taller than mine. But I’m not appreciating that area between the console and the dash (you posted earlier) because I don’t see a space I could mount my tablet high up.
    I need to remove #1 (and #2 but that’s easy, as you’ve depicted). I’m gonna drive it out on an errand. When I get home I’ll try pulling it apart.
    des2mtn[QUOTED] likes this.
  7. May 10, 2021 at 1:22 PM
    #9667
    Sunnier
    Sunny
    San Diego, CA
    ... I’ve ordered everything I can think of, done the chip board mod @Porschetech29 suggested (with cheerleading by @nishibot behind the scenes). I guess I’m about out of project related delaying tactics.... :angrygirl:
    Porschetech29, nishibot and des2mtn like this.
  8. May 10, 2021 at 1:33 PM
    #9668
    des2mtn
    Shady Grove
    Tonto cover
    Hope you're able to figure something out before the trip! I've always thought this area was too low, it's out of reach when I'm driving. Maybe these yellow circles would be a good place to mount a fabricated bracket that holds a radio/ tablet etc but then looks come into play.
  9. May 10, 2021 at 4:57 PM
    #9669
    SAGE63
    San Diego County
    I di not envy you guys opening up the can of worms
    des2mtn and Sunnier[OP] like this.
  10. May 11, 2021 at 3:31 PM
    #9670
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Any one interested in a bakflip mx4? I have mine for sale it’s still on my truck so can’t post a for sale listing. Crewmax and has adapters for bed rails.
  11. May 11, 2021 at 5:00 PM
    #9671
    Sunnier
    Sunny
    San Diego, CA
    Can me and your kids jump on it during the next trail run to test it’s durability?!!
  12. May 11, 2021 at 5:26 PM
    #9672
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Can confirm it’ll hold an adult. I’d like to watch the jump test though! :popcorn:
  13. May 11, 2021 at 5:57 PM
    #9673
    fisherman951
    Tony
    2017 crewmax 4x4
    LOL I’ve been curious to see some one on top as I think they say it holds like 300lbs
    Sunnier[QUOTED][OP] likes this.
  14. May 11, 2021 at 6:27 PM
    #9674
    Sunnier
    Sunny
    San Diego, CA
    So that’s my ... 115 pounds :rolleyes:... plus... um, where’s my calculator... how much do your 4.3978 million kids weigh, Tony?
    eccracer104 likes this.
  15. May 11, 2021 at 7:35 PM
    #9675
    HAMi
    HAMi New Member
    Charlie
    626
    2014 Tundra TRD 4x4
    Icon Stage 5 (front and rear) Icon Billet UCAs Icon RXT Leaf Springs Icon Six Speed Wheels FCK Ditch Light Brackets FCK Ditch Lights Tekonsha P3 Brake Controller ESP Truck Mount
    Not really in the market for one of these but for some reason I need to ask... reason for selling, and how much are you looking to get for it?
    Sunnier[OP] and eccracer104 like this.
  16. May 11, 2021 at 7:38 PM
    #9676
    fisherman951
    Tony
    2017 crewmax 4x4
    Going softopper. I have 1.56 million kids just ask @Sunnier. So when going camping or places my truck looks like this. So this top is useless for me. It’s a great cover but just switching things up.
  17. May 11, 2021 at 9:07 PM
    #9677
    Sunnier
    Sunny
    San Diego, CA
    I like that, if I
    I love all those fishing rods look like antenna at some alien movie film set.
    des2mtn and fisherman951[QUOTED] like this.
  18. May 12, 2021 at 12:16 PM
    #9678
    Sunnier
    Sunny
    San Diego, CA
    https://www.tundras.com/threads/13x13-jumper.88841/
    See? Now we need to jump on the backflip!
  19. May 12, 2021 at 12:17 PM
    #9679
    fisherman951
    Tony
    2017 crewmax 4x4
  20. May 13, 2021 at 10:36 AM
    #9680
    SAGE63
    San Diego County
    Well finally getting the +3 Shackles and 2 driverside and 1 passenger side shims installed today. Also having front and rear durobumps installed and Built Rite rockrails/sliders welded in. Already have 6112's at 2.5 upfront with Built rite UCA's and 5160's on the rear. James' crew at the Truck Shop doing the work.
    des2mtn, drobb and Sunnier[OP] like this.
  21. May 13, 2021 at 4:53 PM
    #9681
    eccracer104
    San Diego, CA
  22. May 13, 2021 at 4:55 PM
    #9682
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Looks like Hawaii
  23. May 13, 2021 at 8:01 PM
    #9683
    eccracer104
    San Diego, CA
    It is indeed!
    Aloha mother truckers! Haha.
    tundra_20, blktruck, nlaroy and 5 others like this.
  24. May 13, 2021 at 9:29 PM
    #9684
    Sunnier
    Sunny
    San Diego, CA
    You two getting mellow in advance of next week’s shenanigans is good for us all! Mother Trucker.
  25. May 13, 2021 at 9:37 PM
    #9685
    eccracer104
    San Diego, CA
    Going to be out in the desert lagging behind “I’m on island time!” :rofl:
    “oh wait, I forgot my tow haul boost button :burnrubber:
    tundra_20, nlaroy, des2mtn and 3 others like this.
  26. May 15, 2021 at 8:42 AM
    #9686
    brownmike
    brownmike New Member
    '17 CM 4x4
    Yup, same cars just badged for mitsu or plymouth. I just picked up ANOTHER colt as well, lol.
    If you can remote mount the base under the seat, then should be fairly easy to fab up a bracket for the faceplate. I would be interested in maybe making a bracket that slides into the cupholder slides (assuming the holder pulls completely out of the dash). I have a 3d printer and a cnc plasma cutter, gives me a reason to tinker!
  27. May 15, 2021 at 9:06 AM
    #9687
    Sunnier
    Sunny
    San Diego, CA
    Cool idea! Ideally I’ll get this worked out this weekend so that’s probably not a realistic timeframe to rope you into, but if I cannot do it the way I have in mind, it’d probably be worth it for me to use handhelds this trip and meet with you to see what’s possible. Alternately, @des2mtn”needs” a radio too. Hmmn, I think his doesn’t have the same pull-out cup holders.
    In any case, for your brain to start working the problem: the plastic cup holder insert pulls out (already removed) but a metal box remains. That box is well-mounted and would be perfect housing except my base doesn’t fit. As for mounting a face to something that slides in where the cup holder insert was... it’d need to be Hulk proof = hard hits and playful hucks won’t dislodge or break it. Whereabouts do you live? You gonna come play in Anza-Borrego next weekend?
    brownmike[QUOTED] likes this.
  28. May 15, 2021 at 1:58 PM
    #9688
    greentrbo95gst
    greentrbo95gst New Member
    Huntington Beach
    Anyone looking for perfect condition TRD Pro BBS forged wheels with K02's and TPMS? I am in Socal.
    TheBeast, newguy, Y0TA PR0 and 2 others like this.
  29. May 15, 2021 at 2:04 PM
    #9689
    Burkley
    Burkley New Member
    V.a.
    '16 double cab trd black
    None.. yet
    Nice looking setup! Ever on the east coast look me up
  30. May 15, 2021 at 2:05 PM
    #9690
    Franco4x4
    Franco4x4 New Member
    2019 tundra CM
    I'll be around next wkend. How many miles on them? Price?
