Pics of 275/70/18 with a lift?
Discussion in '2.5 Gen Tundras (2014-2021)' started by MEGALODON18, Oct 23, 2019.
  1. Nov 11, 2019 at 12:53 PM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    275/70/18 BFG ko2 with 6112's @ 1.3" in front. Nothing in rear6112_1.3inch 01.jpg
  2. Nov 19, 2019 at 9:45 AM
    gupster88
    gupster88 New Member
    Brett
    Charleston, WV
    2019 Toyota Tundra SR5 TRD Off-Road
    Love this setup. Did you keep this lift or did you go to 6112s? Thought I saw another post where you had 6112s on...
  3. Nov 19, 2019 at 2:10 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Correct i went to 6112s on top setting and added 35s
  4. Nov 21, 2019 at 6:20 AM
    gupster88
    Brett
    Charleston, WV
    Gotcha. Thanks, did you like the 3-1 lift? I'm sure the 6112s are better though.
  5. Nov 21, 2019 at 7:35 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    It was nice, til i joined here and quickly realized it wasnt what i needed, for my usage.
  6. Nov 21, 2019 at 7:53 AM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    I'm at 2.5 on 6112, with a Coachbuilder shim on drivers side only, with 5160's and Coachbuilder +2 (1.25") shackles in the rear with Nitto Terra Grappelrs. On stock suspension I felt the 275/70's looked great. But now with the lift and being on this site all the time I want wheels and bigger tires :(
  7. Nov 21, 2019 at 8:25 AM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    I think it looks awesome like that ...
    kparrow and justfortun[QUOTED] like this.
  8. Nov 21, 2019 at 8:27 AM
    TundraDude18
    'Merica
    '21 Limited CM
    Personally, I think it looks great.:thumbsup:
    My trucks used to be lifted 6 inches [ALWAYS]. I finally went to leveled and forget it. Next time, I'll probably just stay stock. [As I age, things change ...]
    easleycrawler and junior[QUOTED] like this.
  9. Nov 21, 2019 at 8:52 AM
    NHSSTundra27
    NHSSTundra27 New Member
    Jesse
    2015 SR5 CrewMax
    None Yet
    285/75/18. 2.5 front 1.5 rear. Falken wildpeak AT3Screen Shot 2019-11-21 at 11.51.39 AM.jpg
    superdenk and justfortun like this.
  10. Nov 21, 2019 at 10:15 AM
    whiskeydrink
    whiskeydrink Asst to the Regional Manager
    West TN
    2019 QS SR5 Offroad
    275/70r18s. 5100s on top setting. Quite a bit of rub after the install, until we modded the stock skid plate.
    justfortun likes this.
  11. Nov 21, 2019 at 1:00 PM
    Riggs711
    Riggs711 New Member
    2018 Limited Crewmax
    Pardon me if this is a dumb question but, it seems some of you are rubbing the skid plate and others aren’t. This is all with 275/70-18. Is this due to the different tires or inconsistencies in the skid plates? Would aftermarket wheels with a different offset negate the need to mod the skid plate?
  12. Nov 21, 2019 at 1:05 PM
    cmc6070
    cmc6070 New Member
    2008 Crew Max, TRD Off-Road, Radiant Red
    I have 275/70/18 Ridge Grapplers with a 3/2 level, I think they look great...
  13. Nov 21, 2019 at 1:32 PM
    whiskeydrink
    West TN
    2019 QS SR5 Offroad
    I think spacers or offset will keep the wheels off the skid for sure, but even with stock wheels and no spacers all we did was slightly bend the skid plate. It took all of ten minutes and was no big deal.
  14. Nov 21, 2019 at 1:52 PM
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    No exactly 275 70 18 but here is 275 65 20 which is only 1 inch taller in overall diameter. 3.5" Front lift and 1" Rear
    TRDSPORT118 and justfortun like this.
  15. Nov 27, 2019 at 10:37 AM
    jerzeedivr
    jerzeedivr New Member
    2015 Tundra SR5 TRD CM.
    N-Fab Nerf Bars, Maxliner 3D Floor Mats
    Thanks! I have a 2015 SR5 CM and wanted to be sure Cooper XT3 XLT LT275/70/18 would not rub with No Lift.
    Lake.Life24[QUOTED] likes this.
  16. Nov 27, 2019 at 11:11 AM
    AZBoatHauler
    So.Arizona
    They might hit the "skid" plate at full lock but that can be easily reshaped and/or trimmed. I trimmed about .75" off each side of the skid to get rid of the rub with my 275/70/18. Took longer to take it off and put it back than cutting it.
  17. Nov 28, 2019 at 7:09 PM
    sigh824
    sigh824 New Member
    Nice man, I'm gonna run Method NV with TOYO AT2. Had the same set up as you on my Tacoma except 285/70/17 with 6112s
  18. Dec 3, 2019 at 4:33 PM
    AdventureAddict
    AdventureAddict New Member
    Josh
    19 Cement Limited TRD off road
    Clean!!!
    AZBoatHauler[QUOTED] likes this.
  19. Dec 3, 2019 at 7:25 PM
    AZBoatHauler
    So.Arizona
    Thanks. I keep debating pulling the last badge and decal... :monocle:
  20. Dec 3, 2019 at 7:34 PM
    #50
    AdventureAddict
    Josh
    I didnt trim anything and have no rub at all with 275/70/18 KO2s on stock trd off road rims
    jpod likes this.
  21. May 10, 2021 at 4:36 AM
    #51
    dakotatundra
    dakotatundra New Member
    @MistrRoboto Is the rear stock height with your 5160? TIA
  22. May 10, 2021 at 6:32 AM
    #52
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Stock height in the rear - but also stock rear suspension. I didn't touch the rear... just the 6100s up front.
  23. May 10, 2021 at 9:43 AM
    #53
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    bilstein 5100 middle setting
  24. May 10, 2021 at 9:52 AM
    #54
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    If you want a superior ride, and your bed is empty, run two PSI under what you run the fronts.
    You can always add to the rears when getting ready to load up or tow.
    15whtrd likes this.
  25. May 10, 2021 at 9:56 AM
    #55
    15whtrd
    15whtrd Mr. Blonde
    I run about 10 psi less in the rear when unloaded. Seems to get the right amount of tire bulge and contact patch. I am running E rated tires though. I run between 45 and 50 psi in the front and then match the rears at 8-10 psi less. Works for me at least
    Nowhereman[QUOTED] likes this.
  26. May 10, 2021 at 6:38 PM
    #56
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    275/70R18 Falken Wildpeaks on Methods +18 with Bilstein 6112s @1.9” on front and stock height in the rear. With the offset on the wheels they did rub. I hear gunned the mudflap and moved the holes in the plastic front inner fender. No issues now.
  27. May 10, 2021 at 7:41 PM
    #57
    dakotatundra
    This looks great. How does is sit? Level or slight rake? Any thing you would do different?
  28. May 11, 2021 at 5:23 PM
    #58
    Nowhereman
    Al
    Monterey Bay area
    Sits just like my cement unit, I used Rough Country s for the leveling of the front and I got the satin black pieces for the grill surround and hood bulge.
    It rides real nice and I don't get a rear view mirror full of my bed cover.
