CV Axle LH-Side removal Question
Discussion in '1st Gen Tundras (2000-2006)' started by Glock 40, May 10, 2021.
  1. May 10, 2021 at 12:15 PM
    Glock 40
    Glock 40 [OP] I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Planning to replace my LH-side CV axle. Looking at my yota bible... it states to use a "slide hammer equipped with a special hooked adapter". Is this adapter + slide hammer necessary just to pop out that CV? I'm guessing there's a clever hack to get it off without that hooked adapter, correct?
    [​IMG]2021-05-10_01-07-28 by GhostCreekMine, on Flickr
    I have a bigass slide hammer FWIW... and looks like there's a hooked adapter of sorts in the box.
    [​IMG]2021-05-10_01-07-47 by GhostCreekMine, on Flickr
  2. May 10, 2021 at 1:21 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I used a screw driver and worked up to a pry bar on both OEM and Import Direct. Be gentle but it'll pop out. Hook adapter might be helpful to prevent mangling?'
    Expect some gear oil to come out if you don't drain the diff.
    Glock 40[OP] likes this.
  3. May 10, 2021 at 2:52 PM
    I stuck the tip of a long prybar in the gap and then gave it a few wacks with a mallet. I think I slightly increased the force each time and it popped right out on the 2nd or 3rd hit. No special tools needed.
  4. May 10, 2021 at 3:24 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Thank you gentlemen!
  5. May 10, 2021 at 5:49 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I use a block of wood and hit it with a hammer from down by the oil pan. You can hit, rotate a little, hit again, and so on. If you ever do that with a good CV axle be sure to use rags to meet it from contacting sharp things and tearing a boot and use a bungie cord around the hub side so it doesn't fly out and hit the ground. If you aren't reusing if then no biggie
  6. May 10, 2021 at 5:56 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Not specific to the Tundra, but I've always used a medium pry bar on the bottom side and grab the top side with my hand.
    Then I pull/put downward pressure with my hand while prying. I can usually get it to pop right out. Sometimes I have to rotate the axle until the c-clip inside lines up better.
    Rarely do I need a hammer, block of wood, etc.
