Replacing Instrument Cluster Plastic?
Discussion in '2.5 Gen Tundras (2014-2021)' started by prevent, May 10, 2021.
  1. May 10, 2021 at 12:27 PM
    prevent
    prevent [OP] New Member
    2014 5.7L Tundra SR5 DC
    TRD Catback Stillen CAI DAP Tune Tow Mirrors Light sensor Dashcam TRD Pro Grill LED Interior lights + DRL’s
    When I took my Tundra in for service last year during covid, their valets were spraying disinfectant everywhere when entering the vehicles. Apparently it was ammonia based because this is how it looks now, even after cleaning…
    I’m assuming this thin plastic is basically shot and can’t be cleaned in a way to remove the discoloration… so is it possible to replace just this plastic and not the whole instrument cluster?
    What are my options here?
    I haven’t talked to the dealer yet, but since this happened a full year ago I’m sure they’ll deny any wrongdoing. If I wasn’t so lazy and tried cleaning it off right away I’d be in much better shape if I complained then, but I dont expect to get far being like “Hey, you guys damaged my truck last year and I’m only bringing it up now…” :(
  2. May 10, 2021 at 12:34 PM
    Rocko9999
    Rocko9999 New Member
    Why did you wait? I would have had them fix it asap. Try Meguiars plastic polish.
    15whtrd and Tundra234 like this.
  3. May 10, 2021 at 12:38 PM
    prevent
    I figured it was just some dried residue that would come off when I got around to cleaning it, and I didn't try cleaning it until now.
    I'll give that polish a shot.
  4. May 10, 2021 at 12:44 PM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    If you know of a good auto detailer give them a shot at cleaning the dash plastic. Those guys usually know the latest and greatest for tough issues like yours. Worst case scenario you get your car cleaned but the plastic is still a mess.
    Rocko9999 and prevent[OP] like this.
  5. May 10, 2021 at 3:09 PM
    Rocko9999
    This is a good solution especially if you know someone you trust. Call and ask what they would charge just to polish it.
  6. May 10, 2021 at 3:38 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m sure if you really went to town on it you could polish that back to life. Maybe even take the cluster out so you can have it on a bench or your lap. Similar to polishing headlights. Start with something simple like Maguires plastix to see if it even makes a dent. If that’s not cutting it, you may have to get more aggressive with a grittier compound. I always start with the lightest polish I can. If that’s not taking scratches or imperfections out, I step to a heavier grit. Once you get to the grit that seems to be effective, then you have to polish yourself back in steps to the finest polish. Finer scratches to take out heavy scratches.
    i’d also be willing to bet that you’re not the only customer that this happened to. You might want to just show them and see what they say. Explain your situation, even go as far to say that you didn’t feel like coming in if it wasn’t necessary during Covid. Now you want your shit fixed LOL
    prevent[OP] likes this.
  7. May 10, 2021 at 5:05 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
  8. May 10, 2021 at 6:06 PM
    NWPirate
    Zach
    WA
    I changed mine out on my last Tundra (2015). Previous jackass had stickers all over it, leaving scratches. I don't remember what the oem part cost, but it was well worth it and a piece of cake to swap it out.
  9. May 10, 2021 at 6:58 PM
    NumberOfTheDay
    NumberOfTheDay Gloves are on, scene is safe.
    SR5 TRD 4X4 OFF-ROAD Barcelona Red Double-Cab
    3/1, 295 70 R18. Some Color Matching
    This is the way. The clear plastic on the Tundra cluster is super easy to scratch even when trying to clean with micro fiber. I had no luck with polishing. Changing is the way to go just be super careful when you install it's also really easy to break.
  10. May 10, 2021 at 6:59 PM
    prevent
    Wow, thanks guys. Now that I know what the thing is called I was able to track down some instructions on removal and it does seem pretty simple (taken from another thread here): http://www.hypertech-inc.com/ProductManuals/InLineSpeedo/730119_VSS_Instlltn_Prcdr.pdf
    Great idea on the protective film. :rocket:
    I’m actually due for inspection soon so when I take it in I’ll see if they’ll take care of it, but if not… it’s not the end of the world.
    NWPirate likes this.
  11. May 11, 2021 at 12:55 PM
    Ebeast
    Ebeast New Member
    2021 Super White Tundra SR5
    Lift Front: Eibach Pro Stage 2 coilovers set at 2.5 Rear: Eibach Shocks. Deavers 3 leaf progressive pack added to stock leafs 1.5 Tires: Falken Wildpeaks AT3 295/70R18 Bed Rack: KB Voodoo High rise bars. RTT: Tuffstuff overland Ranger Tent
    when you do replace it and get a screen protector I used ScreenProtech for the touchscreen and instrument cluster. really good quality stuff.
