Case for staying stock size AT?
Discussion in 'Wheels & Tires' started by farm&forest, May 10, 2021.
  1. May 10, 2021 at 11:07 AM
    farm&forest
    farm&forest [OP] New Member
    2021 Tundra SR5 TRD-Off Road Double Cab
    Dobinsons 2-3" Complete Suspension Kit w/ medium Dobs Leafs, Decked Drawer System, Leitner Forged ACS Rack, Line-Xed bed and Line-Xed Tyger Blade Steps, Wet Okole seat covers, VLED lighting, soon to add Swith Pro and auxillary lights
    Are there any performance advantages to running a larger than stock tire on an all-around use truck? I agree they look great, but my pragmatic self is begging the question.
    I thought I would run my stock 275/65/18 Michelins until they wore out, then ask these questions but at 1500 miles I just poked an unfixable hole through one and I am taking this as a sign of more flats to come.
    I use the truck on pavement, junky gravel roads, moderate 4x4 trails, and snow here in New Hampshire. I am interested in staying as nimble and lean as possible for on road, but would like more confidence in tire durablility off road.
    I am finding a lot of good info here. Just curious if anyone wants to pass on some wisdom/experience. Is there a stock size 10ply or E-rated that anyone likes? Is it a purely aesthetic gain to bump up to 275/70r18...I agree they look better and add a pinch of height but I am picky about adding weight....
  2. May 10, 2021 at 12:25 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I run 275/70-18 E load. Running the E load because that is what you get when installing larger 18 inch tires on a Tundra. They ride harder, even when playing close attention to air pressure. E load is considerable heavier so impact acceleration some, MPG too. I wanted larger tires, so knew the tradeoffs.
    If you don't need larger tires for ground clearance, looks or other reasons, you may be happier with stockish size standard load tires. They will be smoother driving, much lighter, you will get better MPG. The stock sizes in standard load will handle everything the truck can do- towing, hauling, etc. They also cost less vs moving to larger, heavier load tires.
    So, suggest you look at some stock size ATs. There are many great choices out there. With the area you live, look for the 3 peak symbol. You may loose a little MPG going with an AT vs road tires, but nothing like what you will see when moving to larger, heavier E load tires. I dropped about 1.5 MPG with the change.
    One thing I do like about E load, steering input is better. My stock Michelins always felt wallowy in turns. They do look great too and have performed very well.
    It boils down to how you use the truck and if you prefer the best ride/drive or are willing to trade off some of that for the larger meats.
    farm&forest[OP], 15whtrd and Pmac like this.
  3. May 10, 2021 at 12:33 PM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    I run a stock size (275/65R18) commercial tire (Toyo Open Country CT). I think they look decently aggressive/not undersized with the factory suspension and 4x4 clearance. I assume the size is spec’d for various reasons by the engineers but don’t pretend to know;)
  4. May 10, 2021 at 12:43 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Truthfully unless that 1/2 inch ground is ground clearance is going to make a night and day difference off-road or your dead set on the looks of a larger tire I see no reason to go larger. Admittedly they do look better but it DOES affect the performance, braking, and maneuverability of the vehicle.
    Unless you tow constantly or Off-road regularly an E rated tire MAY not be the best way to go...
    farm&forest[OP] likes this.
  5. May 10, 2021 at 12:45 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    When you go larger it takes more to turn those larger, heavier tires. So it could feel sluggish depending on how big you go. I would think a small size increase would not be very noticable. Would take a mpg hit too.
    I'm new to the Tundra world but with Tacomas folks would regear after getting bigger tires.
    My main use for the Tundra is to pull our camping trailer. Getting bigger tires would not help me.
    farm&forest[OP] and Oey12 like this.
  6. May 10, 2021 at 12:59 PM
    frichco228
    Frank
    Virginia
    Here are the 275/70s for comparison and this size fits on a stock truck no issues at all.
    farm&forest[OP] and Pmac like this.
  7. May 10, 2021 at 1:08 PM
    With our lack of mpgs, I wouldn't worry about that small of a weight.
  8. May 10, 2021 at 1:59 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    Lots of good responses, it seems.
    My two cents: the purpose you are using your truck for determines how you set up your truck; you're right about that.
    Example: I use my truck pretty much only for fun trips, weekend getaways, vacations when we take the 4-wheelers.
    Since I am towing, I want to keep my stopping distance down. I run a 275/65/18 stock and went to a 275/70/18 (same width, 1-inch taller) for reasons of VANITY [I like the larger tire size look]. Went e-rated [Falken Wildpeaks/10-ply], so I wouldn't get a flat when pulling the trailer on back roads. Left my rake because the truck handles so much better, and I am going to be taking long, highway runs or short trips of 3-5 hours or so. If I was keeping my truck local, I'd lift it.
    I'm pretty sure guys with rakes are impotent, and guys with lifts are all alpha males.
    Just do you.
    Or, if you think something entirely different, that's cool too ...
    15whtrd, farm&forest[OP] and TunBrun like this.
  9. May 10, 2021 at 2:02 PM
    Black
    2014 Tundra Limited CrewMax
    I have found that the 275/70/18 or 275/60/20 is my ideal all purpose truck tire that most mileage is on pavement.
    Decent price, tons of options, and not ridiculously heavy.
    A good tire in these sizes will handle any off-road obstacle the truck is capable of handling while still giving very good road manners.
  10. May 10, 2021 at 2:20 PM
    farm&forest
    Thanks for the helpful input everyone! From the advice given , I’m going to research stock-sized E-rated ATs, and 3 peak rated which I didn’t know about.
    I do prefer the looks of the 275/70r18, however, if I am jumping up from passenger to E-rated, I will compare weight differences to decide what seems right. I will also mention I have a considerable constant bed load ~500lbs and also I am at 2.75” lift so yeah the stocks look puny but I don’t really care -function first for this truck.
    I do think I drive enough sharp gravel and tow enough to justify the E, but even so I went ahead and just ordered the replacement stock Michelin since I don’t wish to drive without spare and don’t wish to rush this decision. Now I can settle in to hours of reading tire reviews for nights on end...unless there is an obvious
  11. May 10, 2021 at 2:30 PM
    farm&forest
    Sorry for the emoji attachment, I don’t know how that got there or how to remove it so...
  12. May 10, 2021 at 2:33 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Here is what I have tried on my truck
    OE michelins
    275/65 bfgs
    275/70 duratracs
    Yes you can feel the extra height if the 275/70’s during street driving. There is plenty of power for the extra height, however they do mess with the shift points of the trans slightly. Which does affect driving experience IMO. Just being real about what to expect. I would have no issue running that size again myself
    10 ply 275/65’s - no change in acceleration, ride is worse. No change in city MPG either from tire weight alone in my experience
    15whtrd and farm&forest[OP] like this.
  13. May 10, 2021 at 2:55 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I stay with stock size 18" Michelin M/S and A/T.
  14. May 11, 2021 at 1:07 PM
    farm&forest
    Has anyone runnjng the OEM Michelins experienced bad luck with flats?
  15. May 11, 2021 at 1:15 PM
    farm&forest
    Hey man, I can appreciate that rake for sure! I have towed a lot of heavy farm/ranch stuff behind 1/2 ton to 1 ton sized rigs. I could never stand sag, especially with live cargo or bumpy roads.
    Pbed85 and BrunoTheRescuePup like this.
  16. May 11, 2021 at 1:17 PM
    farm&forest
    Seems like a 10ply 275/65 might work well for me....is 10ply all E load or are there 10 ply options between passenger and E?
  17. May 11, 2021 at 1:25 PM
    farm&forest
    I agree about the Michelins being wallowy in turns and would value more driver input as you describe. I am transitoning from driving a 1 ton and actually prefer a stiffer ride than most- I like the feedback to an extent and things feel just right when I am fully loaded or towing.
  18. May 11, 2021 at 3:42 PM
    davescarp
    davescarp New Member
    Massachusetts
    '18 DC TRD OR
    275/70s def look better, but weigh a LOT more in most brands, and are quite a bit more expensive. Outside of looks, there is nothing wrong with the stock size and SL rating unless you primarily using your truck for or or towing heavy stuff all the time... YMMV (and will with bigger heavier tires)
    There is another option too
    https://www.tundras.com/threads/a-case-for-265-70-18s.88597/#post-2228037
  19. May 11, 2021 at 3:53 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    That's what I'm running and have no regrets.
  20. May 11, 2021 at 3:56 PM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Another good thing about using the stock tires is a ton of people take them off immediately and sell them super cheap.
    I tow way more than drive offroad so I like the stock tires.
  21. May 31, 2021 at 12:53 PM
    farm&forest
    I’m leaning toward a stock size, E-load AT. If I find time to research I will look into D-load as well.
    For me the stock Michelins are feeling too squishy with my bed load, especially with trailer attached. I really like the aesthetic (and +1/2”) of the 275/70/18 but I’ve decided not to give quarter to my vanity on this one due a deeper desire to keep handling/shifting/mpg as is.
    I’m looking at Coopers, Falkens, and several others listed on here. 3 Peak a must.
