Sorry for a stupid question about a audible alert
Discussion in '2.5 Gen Tundras (2014-2021)' started by babyyodacuh, May 7, 2021.
  1. May 7, 2021 at 6:57 AM
    babyyodacuh
    babyyodacuh [OP] New Member
    I have a ‘21 limited (CM if that matters).
    EVERY TIME I GET OUT OF MY TRUCK A STUPID BEEPING NOISE GOES ***DING DING DING *** until I close the door or someone else in the truck opens a door. It is a sound like I left the lights on or have not put my seatbelt on fast enough.
    I have checked everything to make sure nothing is on to drain the battery. All doors are closed. It is in park… I am at a loss and the Owners Manual says nothing. It is not a big deal, just annoying TIA!
  2. May 7, 2021 at 7:00 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Are you talking about beeping that is heard outside of the truck, or beeping that would be heard by passengers in the vehicle?
    Taco-Spike likes this.
  3. May 7, 2021 at 7:04 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Is the truck still running when you open the door, and then you turn off the truck? It’s one of the various warnings related to the smart key. When it does it to me, i just hit the door switch “rubber boot in the dirt jamb) to trigger it to turn off.
    another one is if you leave the truck running, get out, and shut the door behind you with the key not inside the truck (like getting the mail).
    I’ve looked through techstream, but there’s no where to turn those warnings off
    ToyoMafia likes this.
  4. May 7, 2021 at 7:07 AM
    Taco-Spike
    Two Trucks
  5. May 7, 2021 at 7:07 AM
    memario1214
    Colton
    Missoula, MT
    I was hoping that you'd tell me there was... I seriously dislike that the truck gives me like 6 or 8 chirps every time I close a door (while running) and I have the key in my pocket if I'm out of the cab. So stupid.
  6. May 7, 2021 at 7:12 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah. I’ve gotten used to it, but looked and tried several settings but there’s nothing
    Pangaea likes this.
  7. May 7, 2021 at 7:14 AM
    clarkritchie
    clarkritchie New Member
    My '21 does this and it is one of several things that makes me crazy. The bings and bongs warning me that I left the sunroof open is another.
  8. May 7, 2021 at 7:14 AM
    memario1214
    Colton
    Missoula, MT
    I personally think that I am going to disconnect the external audible alarm altogether. I didn't have any audible alerts on my Tacoma, and that went just fine. Just looked for the visual cues of lock/unlock.
  9. May 7, 2021 at 7:25 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    It is really fun when you are getting in and out to hook up/ unhook a trailer.
  10. May 7, 2021 at 7:48 AM
    memario1214
    Colton
    Missoula, MT
    It's settled then. I'll officially go out and nuke it, and let you all know the easiest way I find.
    Tyman likes this.
  11. May 7, 2021 at 9:39 AM
    babyyodacuh
    this was it :bowdown: :facepalm: thank you!
    I really don’t like how they use the same noise for every warning!
  12. May 7, 2021 at 9:42 AM
    babyyodacuh
    Tundra234 and Cpl_Punishment like this.
  13. May 7, 2021 at 10:13 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I've found that if I turn off my truck, but open the door before I take my foot off of the brake pedal, it'll chime until I close the door.
    babyyodacuh[OP] and clarkritchie like this.
  14. May 10, 2021 at 5:42 AM
    Pangaea
    Pangaea New Member
    BC
    2021 Cement Tundra CM TRD Off Road Premium
    Yup. This was driving me nuts too. I always open the door before I turn off the truck. Dealer said there’s nothing you can do. Currently attempting to modify my behaviour.... I like the kicking the rubber boot idea tho.
  15. May 10, 2021 at 6:06 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    This is true. I think the chime is meant to alert you that the truck is still running, but if your truck has been turned off but your foot is still on the brake when you open the door, the chime is there. I've just gotten into the habit of moving my foot off the brake before I open the door.
