Let me see your truck with stock 18" TRD off-road wheels
Discussion in '2.5 Gen Tundras (2014-2021)' started by GT87, May 7, 2021.
  1. May 7, 2021 at 11:28 AM
    GT87
    GT87 [OP] New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    Hey guys, I'm looking for some inspiration on what route I should go with my '21 crewmax. I want to keep the stock 18" TRD off-road wheels but can't decide what lift/tires I want to go with. Bonus points if you post a white crewmax. Here is what I'm working with...
  2. May 7, 2021 at 1:06 PM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    lifted.jpg 3 inch Toytech lift. 285/75r18 Just a wee bit older though.
    wharto4x4, Y0TA PR0, WFD473 and 7 others like this.
  3. May 7, 2021 at 1:11 PM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    295 70R 18 on stock TRD Wheels
    rapide, Cg13055, WBW and 11 others like this.
  4. May 7, 2021 at 1:38 PM
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    Subscribed. I’m in the same boat, though not sure on whether I want a lift.
    GT87[OP] likes this.
  5. May 7, 2021 at 1:52 PM
    CavBluTundra
    Howard
    6112's top setting front
    5160's rear
    have a shim for 1/2" lean on drivers side, but never installed
  6. May 7, 2021 at 2:21 PM
    CavBluTundra
    Howard
    Removed the plastic mud flaps in front of the wheels and the tire shop had to cut my front skid even with the front sway bar give or take. I think the TRD skid will actually clear. The difference is almost none front to rear. The 1/2" lean bugs the hell out of my OCD, but my wife says she can't see it unless I tell her to look at it a certain way. On my next alignment, I am going to have my tire shop install the 1/4" spacer to the driver side and get rid of the 1/2" lean (at least that is what I have been told and read on the forum here). Other than that, if you want a little rake, set them at second to highest. I think that is 1.9"
    Metro14536 likes this.
  7. May 7, 2021 at 7:29 PM
    wsutundra
    wsutundra 2021 Smoked Mesquite 1794
  8. May 7, 2021 at 7:49 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
  9. May 7, 2021 at 7:50 PM
    NHPig
    NHPig Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
    ReadyLift 3/2, with minor plastic trim, SpiderTraxx spacers 1.25", 295/70R18
    rapide, GT87[OP] and Metro14536 like this.
  10. May 7, 2021 at 7:51 PM
    NHPig
    New Hampshire
    I'll be waiting for my bonus points...
  11. May 7, 2021 at 8:01 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    No lift with LT275/70-18’s. Going to try Bilstein 5100’s as lowest setting soon. Take out some rake and hopefully not squat when towing the boat.
  12. May 7, 2021 at 8:27 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Here’s a clean pic and a dirty pic for ya.
    285/75s
    TRD Fox suspension
    Top pic was taken before I added CB +2 shackles in the rear; the bottom pic was taken after.
  13. May 7, 2021 at 8:54 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Stock wheels painted Granite Metallic
    2-1/2” lift front, 1-1/2” rear
    295/70/18 Nitto Ridge Grapplers
  14. May 8, 2021 at 12:58 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Factory TRD 18” wheels, powdercoated black. E71D9E36-1AE6-45FE-81EA-29EF04A6E5B7.jpg
  15. May 8, 2021 at 5:55 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Stock suspension, 275/70-18
  16. May 8, 2021 at 6:46 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
  17. May 8, 2021 at 6:51 AM
    biebs96
    PA
    What he said ^^
    panicman, Tboh1870, V3N0M and 3 others like this.
  18. May 8, 2021 at 7:01 AM
    RanchTracker98
    RanchTracker98 New Member
    2018 Cement TRD offroad
    Bilstein 5100s set at middle setting with 275/70 BFG KO2s.
    MALIBU1794DC, superdenk and GT87[OP] like this.
  19. May 8, 2021 at 7:43 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Plastidipped black with 295/70/18 and a 1.25" spacer.
  20. May 8, 2021 at 10:28 AM
    15whtrd
    15whtrd Mr. Blonde
    Sorry, the lighting sucks right now. This is about 2 inches of lift in the front, TRD pro Bilstein suspension with coachbuilder +2 in the back. The rake looks exaggerated right now because my driveway is slightly uphill. When I turn it around it looks level ish. 275/70/18 KO2’s 863007A4-D8D4-4A7B-AF33-B99F4ABB0807.jpg 80B0AA4F-82C2-4319-A73F-E787A7A46739.jpg 07F6939B-309B-45ED-B9F1-2BB0150253A9.jpg
  21. May 8, 2021 at 3:37 PM
    Elfine
    Elfine Doing my best to break this beast
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards, RCI Engine/Transmission/Fuel Skid, ICON Stage 5, Rago Bed Stiffener/Ditch light brackets, ARB twin air compressor, 295/70R18 Cooper Evolution M/T, Spydertrax 1.25" spacers
  22. May 8, 2021 at 3:41 PM
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
  23. May 9, 2021 at 7:24 AM
    tundra121
    tundra121 New Member
  24. May 9, 2021 at 7:37 AM
    GT87
    Greg
    Western NY
    Set up? Looks awesome!
    tundra121[QUOTED] likes this.
  25. May 9, 2021 at 7:42 AM
    tundra121
    Thanks
    TRD Pro suspension with 1" block in rear. I have 3/4" bora wheel spacers all around with 295/70/18" falcon at3w tire's
    GT87[QUOTED][OP] likes this.
  26. May 9, 2021 at 11:33 AM
    Crunch527
    Iowa
    For all of the “chasing” that can ensure from an innocent desire to muck with wheels and tires I recommend you powder coat the stock wheels and if anything go to a 275/70/18 (up one size to a 33”-er) tire and call it done.
    The biggest thing to realize is when you go from a 275/65/18 All Season Michelin (44lbs and “grandpa” tread) and dive into the All Terrain (aggressive tread), where tires are 50-62lbs and higher, your truck will feel and perform different.
    Rincon805, DBamaC and Laconian like this.
  27. May 9, 2021 at 1:39 PM
    Terndrerrr
    Music City
    6UR-FE
    Yes. My truck is definitely a hair slower off the line. If I just commuted and did normal truck stuff, I'd be on stock size P-rated tires (I'd switch to Defenders; the factory AT2s throw too many small rocks).
    For how I use my truck, my skinny 35s make sense.
  28. May 9, 2021 at 2:11 PM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Not sure if it helps, but I saved several photos of various set-ups (mostly from good members on this site) when I was searching for the look I wanted for my Tundra. I would have included Tundra121 too, but he already posted some nice pics:
    Mine with 1.5" shackles, TRD Pro suspension, and 1" BORA wheel spacers, 295/70 Cooper Discoverers, and before changing to TRD Pro BBS wheels:
    huntsonora, CCLJ03, GT87[OP] and 2 others like this.
  29. May 9, 2021 at 2:11 PM
    tlr641
    tlr641 New Member
    Robb
    Oregon
    2018 Tundra Sport
    Trd dual exhaust, bilstein 5100’s, tint
    Sport but I kept the wheels from my previous off road
    MALIBU1794DC, GT87[OP] and intr3nsic like this.
  30. May 19, 2021 at 9:25 PM
    2mchfun
    UCA's? Any rubbing?
