  1. May 8, 2021 at 4:11 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Finally installed another Christmas gift - ESP Long Box. . .
  2. May 8, 2021 at 4:55 PM
    FancyPants
    FancyPants Not my Husband’s truck
    Amber
    Oregon
    ‘19 SUPER WHITE Platinum Crewmax
    Put the CVT RTT on for the Summer
    Rgross2112, THOR's, Ostrich and 19 others like this.
  3. May 8, 2021 at 5:40 PM
    AggiePhil
    College Station, TX
    Installed an el cheapo Tyger brand soft tonneau cover to get me by till RLD Design canopies are more plentiful. WaterPORT even clears it.
    E0332012-2F3A-466E-8C4C-7AE75AA697C6.jpg 2DCE22AB-5AA9-446D-AF69-FB0B78D151C5.jpg
  4. May 8, 2021 at 5:53 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Wheel and tire day!!! ICON Rebound titanium wrapped in 305/70 17 Cooper XLT.
  5. May 8, 2021 at 6:30 PM
    Unstable_Trip
    Unstable_Trip New Member
    Tom
    North MS
    '14 Blue Ribbon SR5 DC 4x4
    Haven't touched the truck much, started to get antsy. Decided to tint my fogs and do the anytime fog mod. Also finally decided to piece together my makeshift TRD intake :thumbsup:
    Ostrich, Hightide, GAknight and 6 others like this.
  6. May 8, 2021 at 7:48 PM
    Rely01
    Rely01 Window Shopping
    Eli
    SW Arkansas
    2016 Silver Sky SR5 CM
    Where did you get your lug nuts from?
  7. May 8, 2021 at 7:49 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Put my new registration sticker on, cleaned the interior (wiped everything down, cleaned windows, washed floor mats, vacuumed), put new black plastic valve stem caps on to replace my old random grey plastic ones. Also removed the TufSkinz insert on the center console. I liked it a lot at first to put my phone in as the cubby is about the perfect size, and the foam stopped it from rattling, but after I got my Pro Clip mount I never used the spot, and the ridges in the foam just collected crap.
    Also put the Eagle Klaw floormat clips in my front passenger mat. Works ok for what it is, just seems like the OEM mats are too thin, and the carpet doesn't sit perfectly flat in the floor pan so it has gaps below. I don't think the mat & carpet is thick enough to support the length of the backer, so the whole thing still kind of floats around. I broke one 'klaw', where I think it bottomed out against the pan and shattered it, the second time I just pushed it through the carpet by hand and seemed to work better. I think it'll fix the mat from moving around, but it's not perfect by any means.
    Astom22, Ostrich, GAknight and 7 others like this.
  8. May 8, 2021 at 7:49 PM
    Rely01
    Eli
    SW Arkansas
    Tha is for the clarification. I'm interested to see how it holds up.
  9. May 8, 2021 at 7:55 PM
    Rely01
    Eli
    SW Arkansas
    Decided to give the Plasti Dip a try on the wheels. Got a kit from Dip Your Car in the color of "Brass Monkey". It's a darker, bronze-ish, brown-ish color. Definitely darker than the picture shows. Need to get some black lug nuts on the way as well.
  10. May 8, 2021 at 8:02 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
  11. May 8, 2021 at 8:05 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    Installed blackout badges and began AMP Power step install. Steps are in but not powered yet. Love the look of the new badges and left the SR5 off for now.
  12. May 8, 2021 at 8:13 PM
    RobertD
    Robert
    DFW, Texas
    Looks awesome! I like that Brass Monkey kit and have been debating it on my TSS wheels.
    Check out ColorLugs for some lug nut covers. They work well and are affordable
    biebs96, WFD473 and Cthulhu like this.
  13. May 8, 2021 at 8:16 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    thanks I guess we will see, have read good and bad. I will get over it if it fails. atleast the surround piece will be starting out white so probably won't be an issue
  14. May 8, 2021 at 8:19 PM
    Cthulhu
    ColorLugs FTW
    biebs96 and RobertD[QUOTED] like this.
  15. May 8, 2021 at 8:29 PM
    CorsoTundra
    North GA
    Got my dual subs (10" JL Audio) and 5 channel amp from @tech12volts today. Was thinking of installing it on Monday, but then saw how much shit there was and said F this.....as I would surely F it up.
    Gonna drive the 4 hours south and have James do it in a week or 2.
  16. May 9, 2021 at 7:16 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Thats badass !!
  17. May 9, 2021 at 8:02 AM
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    Very awesome. I’m torn between a side by side and a Jeep. My gut says I'd have more fun in a side by side... Just can't get over the cost for a 4 seater.
    mgm16trdpro[QUOTED] likes this.
  18. May 9, 2021 at 8:26 AM
    parkerbows
    Jack
    Can't stop tinkering. just added lights in hood bulge
    Piki, AZ Red Nek, Velocity72 and 16 others like this.
  19. May 9, 2021 at 8:34 AM
    parkerbows
    Jack
    Nice. I once plastidipped my rams tires. My neighbor couldn't believe 2 years later they still looked good
    Rely01[QUOTED] likes this.
  20. May 9, 2021 at 8:40 AM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    When they did the restock on Thursday. I missed it. I was really shocked to see those available on Friday night when I checked.
    Toe404[QUOTED] likes this.
  21. May 9, 2021 at 10:11 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Installed my driver side grab handle, black tail gate inlays and AJT black steering wheel emblem. Gonna do the rest of the dash when the climate knobs arrive
  22. May 9, 2021 at 10:14 AM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    2CF61E47-BE83-4DC0-8B74-72C93C8B9FFC.jpg 2CF61E47-BE83-4DC0-8B74-72C93C8B9FFC.jpg Removed the ecological caps and had the chrome Powdercoated. Installed a set of amber squadron pros and trying to decide the position I want the lp9s.95DB02C8-B715-4ED3-9EE0-845539CD1916.jpg817AD05B-3934-42A6-819F-DC17438F29EC.jpg
  23. May 9, 2021 at 10:15 AM
    point08
    point08 New Member
    Kyle
    I like the wider look of the light position.
    3xYOTA, Sean492, kbark and 6 others like this.
  24. May 9, 2021 at 10:22 AM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    That’s what I’m thinking as well.
    BWPRO likes this.
  25. May 9, 2021 at 10:52 AM
    AlrightAlrightAlright
    AlrightAlrightAlright New Member
    Northwest Arkansas
    2020 SSM DC 4x4 with SR5 Upgrade Package
    RetraxONE MX retractable bed cover TRD Rear sway bar Debadged FabFours Matrix front bumper Smittybilt 9,500# XRC winch Aries 30" light bar (internal bumper mount) Diode Dynamics SS3 3" SAE Fog and Driving lights ConsoleVault RhinoRack crossbars
    This looks great!
    WILLINH likes this.
  26. May 9, 2021 at 10:58 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Finally finished up my drawer system this weekend. Working on staining it now.
    7B19D3B4-B852-4C23-9F5A-FEAE4263E843.jpg E361A108-04F3-4E1A-BA7D-B10498F9C818.jpg DD012A81-F6C4-4383-A012-4A773544722D.jpg
  27. May 9, 2021 at 11:01 AM
    El Two
    El Two I’m only talking to my dog today.
    Lisa
    2018 SR5 Crewmax TRD Off Road
    How much time do you have? . . . . . . . . . . . . . . . . . . . . .......... Eaton rear eLocker, Camburg 1.5” shackles, Rear Seat Delete, S&B CAI, sPOD, Air Bag Helpers w/ Daystar Cradles, RCI engine & fuel tank skid plates, ABS Guards, Job Box Storage, Tailgate Power Lock, Desert Eagle Offroad tranny/cat security skid plate, Added Driver’s Side Grab Handle, VLEDS Footwell & Step Lighting, Anytime Front Camera, Illuminated Ignition Ring, Console Molle Panel, Sound Dampening in Ceiling/Doors/Floor, Yakima Rack, Paracord Grab Handle Wraps, BD Underhood Light, Tuffy Console Safe Insert, WeBoost System, Midland GMRS Radio, Console Interior Lighting, Power Inverter, Custom Center Switch Panel, and Dual Air Compressors
    Been working on the onboard air system. Finished running the under bed air lines to the tank and installed the manifold, water filters, and tire inflation valves. Also relocated the air tank pressure release valve and drain cock to a spot on the passenger side rear fender for easy access.
    The manifold is mounted to the front edge of the bed using an existing threaded hole. Turns out I was able to reuse the stock bolts that were removed from the center console when the security insert was installed. The leftover bolts fit perfectly and saved me a trip to the hardware store.
    Afraid I didn’t get a very good pic of the water filters (https://www.avsontheweb.com/avs-1-4-water-trap-black-with-drain-cock/). There will be two air compressors once the complete system is installed thus the need for two water filters. The filters did not come with any type of mounting hardware so I used 1.5” stainless steel rubber insulated clamps (https://smile.amazon.com/gp/product/B085RDD25L/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1). The filters are bolted to 1” square aluminum bar, up high close to the bed, and feed into the air tank. Details on the air tank and aluminum bar install can be found on my build thread at post #28.
    I didn’t want the hassle of having to crawl under the truck to drain the water filters or decompress the tank each time it was needed. Instead, the pressure release valve and drain cock were mounted on the fender just forward of the passenger side rear wheel. All fittings are 1/4” NPT.
    An existing hole in the fender was used to mount the brackets. The brackets are leftover parts from another install. There was enough room between the fender and wheel well liner to get the bolt in place without having to remove any clips. Bulkhead unions (https://smile.amazon.com/gp/product/B00BKF979O/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8) with quick connect air line fittings were used to attached the pressure release valve (https://www.viaircorp.com/fittings/safetyvalves) and drain cock (https://smile.amazon.com/VIAIR-9283...ck&qid=1620576766&s=industrial&sr=1-1-catcorr) to the brackets. There wasn’t enough clearance to open and close the drain cock so a 1/2” spacer was added.
    The drain lines from the two water filters are connected using a “T” fitting and run out to the drain cock located on the fender. Because this line goes outside the frame and near the tire, it is more prone to being damaged, or worse, ripped off. To help protect the most exposed line(s), the air line was run inside heavy duty gorilla sleeve loom (https://smile.amazon.com/gp/product/B07YBDYL88/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8). Also, stainless ball valves (https://smile.amazon.com/gp/product/B07GW9B47C/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8) were added to the bottom of each filter in case the drain lines are cut or torn off. If such a thing were to happen, closing the ball valves will allow the tank to hold pressure and the air system to continue working. Another drain cock is on the tank itself if needed to remove water.
    For tire inflation, two Schrader valves were mounted to the outside of the frame at the passenger and driver wheel well areas. See post #56897 for the contraption (don’t know what to call it) that is used to connect to the Schrader valve for dual tire inflation. If anyone has had an older Jeep, you may recognized the brackets used for the Schrader valves. They are the side mirror mounting brackets from a CJ and worked out great.
    Passenger side:
    Driver’s side:
    (It’s bugging me that I didn’t run this line through the gorilla sleeve like on the passenger side. Think I’m gonna have to go back and take care of it.)
  28. May 9, 2021 at 11:14 AM
    El Two
    Lisa
    Agree. The wider positioning looks better.
  29. May 9, 2021 at 12:33 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Very thorough install. I like it!
    Hightide and CappyKD like this.
  30. May 9, 2021 at 12:35 PM
    316KS_Runner
    316KS_Runner There's no place like...
    Along the CT River
    2019 MGM CM Ltd
    Front 6112 @ 1.9 Rear 5160 | Falken Wildpeak AT3W 295/70R18 | TRD Off Road wheels | Compustar Pro R3 remote start | Baja Designs SAE fog lights | VLEDS V6 Triton Extreme (amber) front turn signals | Hot Tails Option A | 6” stubby antenna | Window tint 15% rear / 35% front | WeatherTech side window deflectors | RCI Front Skid | Talons Garage front and rear CAT Protection
    Installed the dual power outlet plate from @Chelly. Worked out perfect, and added a dual Blue Sea USB port alongside the regular 12v power outlet. Worked out perfect using some Posi-Taps into existing wires since I have the console wireless charger.
