2019 - 2021 Transmission Service Questions
Discussion in '2.5 Gen Tundras (2014-2021)' started by 737fixer, May 6, 2021.
  1. May 6, 2021 at 3:35 PM
    737fixer
    737fixer [OP] New Member
    When doing a standard Drain/Fill on the 2019+ transmission there will be three plugs. 1. Drain Plug on pan. 2. Level check plug also on pan. 3. Fill plug on side on transmission.
    Does anyone know the parts numbers for the three gaskets that will be needed on each of these plugs? It seems some of the plugs have changed over the years and I can only find older part numbers.
    I realize many reuse the gaskets but I just don't like to not be ready if something occurs.
    Thanks
  2. May 6, 2021 at 4:44 PM
    mb66l79
    mb66l79 New Member
    They're a crush washer, aluminum if I remember right, not much can happen to them. Losing one is about the only thing. Replacing is best of course, but I've never had an issue with them leaking when reusing in numerous applications through the years.
  3. May 6, 2021 at 6:39 PM
    04rktaco
    04rktaco New Member
    Lee
    California City
    2014 SR5 TRD crewmax 4x4
    All-pro rocksliders RCI aluminum skidplates TRD pro suspension TRD pro exhaust coachman 1inch lift shackles cooper tires
    I think the drain is 90430-A0003 but not positive. I have been looking for all 3 for a while but not much luck. 80,000 miles and check plug just barely leaks so would like to replace all 3 seals next time I drain and fill.
  4. May 7, 2021 at 4:15 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Why not just go to the Toyota dealer and buy the parts there? I would hope they would be able to supply you with the correct parts.
    WILLINH likes this.
  5. May 7, 2021 at 6:22 PM
    04rktaco
    04rktaco New Member
    Lee
    California City
    It’s not worth the hour drive and the higher price.
  6. May 7, 2021 at 6:50 PM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
