Under seat storage for crewmax
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Lunarrockpro, May 2, 2021.
  1. May 2, 2021 at 7:36 PM
    Lunarrockpro
    Lunarrockpro [OP] New Member
    Eugene, Oregon
    2021 lunar rock tundra pro
  2. May 2, 2021 at 7:53 PM
    brown_subaru
    brown_subaru New Member
    Eastern WA
    2021 Tundra SR5 TRD
    I have a 2021 and the 3-bin ESP metal storage fit just fine. You do have to be careful of the wiring harness when cutting out the center hole, but it’s not a big deal. The harness and wiring run along the front edge of the hole (front seat side). I used a linoleum knife and cut the other 3 sides of the hole first, then used a bunch of very light pressure cuts on the front side and broke it off on that side once I was most of the way through.
    I assume the plastic one fits also, especially since ESP’s site says it works for 2021’s.
    Mcarrer91 and Lunarrockpro[OP] like this.
  3. May 2, 2021 at 8:21 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    ^^ what he says, first thing I installed on the truck, it is very useful, I just wish they made one that one giant cubby vs 3 smaller ones.
    Lunarrockpro[OP] likes this.
  4. May 2, 2021 at 9:20 PM
    Wgusler
    Wgusler New Member
    2021 TRD Pro
    20210121_151611.jpg 20210121_151129.jpg yup, they fit and works very well for me.
    Mcarrer91 and RusPro21 like this.
  5. May 6, 2021 at 9:45 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    They do…but it is considerably more $ because they have to also replace the two middle seat mount rails with redesigned ones:
    ToytaUser, Bigboitundra and GODZILLA like this.
  6. May 6, 2021 at 10:18 PM
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    Ooh, I like the look of that. How was the install? It looks a bit thicker than the 3 bin, do the seats sit normally on top of it?
    Also, what seat back organizer is that? :D
    Bigboitundra likes this.
  7. May 7, 2021 at 6:43 AM
    RainMan_PNW
    Casey
    Clark County, WA
    It’s about 3-1/2 deep - because it’s one piece it has to be only as deep as the shallowest part. But you can still put a lot of stuff in there. Yes, the seats sit just in top of the lid.
    install wasn’t bad - definitely was nice to have a second person to get the seats out. But I don’t think it took us 45 minutes start to finish.
    the seat back organizer is just a cheap one off Amazon. I’ve got the actual one linked in my build thread.
  8. May 7, 2021 at 9:11 AM
    Downytide
    GTA
    Didn't know you have to move the rails, I don't need the lock-able lid, I liked how on my old Ram it was just this open space, it hold a lot more than what the ESP cubbies hold, I think I'm picking chicken bones in an egg with it.
  9. May 7, 2021 at 9:26 AM
    RainMan_PNW
    Casey
    Clark County, WA
    The two center rails get replaced with new ones from ESP. I also still have the space behind the box under the seats to put more stuff. I'm hoping to spend this afternoon getting it organized and then post up a picture of what I currently have in there.
    The two black ones in this picture are the replacements. You can also see the antenna for the smart key there in the middle. The long box sits between the two outer rails and runs over the top of these two new inner rails.
    D3VA likes this.
